#21
Winter Care
On Wednesday, December 2, 2015 at 12:08:38 PM UTC-5, Steve Leonard wrote:
On Wednesday, December 2, 2015 at 8:05:02 AM UTC-6, Mice seem to hate moth balls and really hate mint. UH Interesting, Hank. Kansas Mice don't seem to mind them. In fact, they chewed through a sock that was holding them in one sailplane at my field! I tend towards Bounce fabric softener sheets and spring traps if I think I have mice already in the trailer. As with any solution, YMMV. Steve Leonard You gots some bad ass mice out there! UH |
Winter Care
On Wednesday, December 2, 2015 at 10:35:13 AM UTC-7, wrote:
On Wednesday, December 2, 2015 at 12:08:38 PM UTC-5, Steve Leonard wrote: On Wednesday, December 2, 2015 at 8:05:02 AM UTC-6, Mice seem to hate moth balls and really hate mint. UH Interesting, Hank. Kansas Mice don't seem to mind them. In fact, they chewed through a sock that was holding them in one sailplane at my field! I tend towards Bounce fabric softener sheets and spring traps if I think I have mice already in the trailer. As with any solution, YMMV. Steve Leonard You gots some bad ass mice out there! UH I had a pack rat and mouse problem in my Ensign hangar until a rattlesnake moved in. I can recommend them - much better than poison or drier sheets! I have plenty on my lot - free pick-up from Tucson! Mike |
Winter Care
I use these. Work great and hold mutiple rodents. No poison needed. I keep one under my trailer and one inside. If you buy them by the dozen under the commercial tab the are very cheap.
VICTOR® TIN CAT® MOUSE TRAP |
Winter Care
Rattlesnakes... Like
I've heard of guys in colder climates putting a small heater in the trailer of their fiberglass glider during the winter. What are everyone's thoughts on that? Is it necessary? |
Winter Care
On Wednesday, December 2, 2015 at 6:39:18 PM UTC-5, IA DPE wrote:
Rattlesnakes... Like I've heard of guys in colder climates putting a small heater in the trailer of their fiberglass glider during the winter. What are everyone's thoughts on that? Is it necessary? I wouldn't (assuming LCD displays, batteries & water/freezable items were removed beforehand)..... Why? 1-Warm air hold more moisture (thus raising potential relative humidity..... bad thing for corrosion, etc.) 2-More inviting for critters to "show up and winter out"..... why would you do that? Typical "inside trailer temps" would change slowly with weather changes. Thus limiting shock crazing of gelcoat and other materials. Just my thoughts. [Have you ever smelled mothballs?????........ what did you do, spread it's wings?!] sick humor.... sigh..... [sorta a "head nod" to the comment Dennis made.... ;-)] |
Winter Care
On Wednesday, December 2, 2015 at 4:00:43 PM UTC-8, Charlie M. (UH & 002 owner/pilot) wrote:
On Wednesday, December 2, 2015 at 6:39:18 PM UTC-5, IA DPE wrote: Rattlesnakes... Like I've heard of guys in colder climates putting a small heater in the trailer of their fiberglass glider during the winter. What are everyone's thoughts on that? Is it necessary? I wouldn't (assuming LCD displays, batteries & water/freezable items were removed beforehand)..... Why? 1-Warm air hold more moisture (thus raising potential relative humidity..... bad thing for corrosion, etc.) 2-More inviting for critters to "show up and winter out"..... why would you do that? Typical "inside trailer temps" would change slowly with weather changes. Thus limiting shock crazing of gelcoat and other materials. Just my thoughts. [Have you ever smelled mothballs?????........ what did you do, spread it's wings?!] sick humor.... sigh..... [sorta a "head nod" to the comment Dennis made.... ;-)] Your point #1 works in your favor if you can make the trailer slightly warmer than the outside air you avoid having the moisture in the air condense on interior surfaces. Craig |
Winter Care
Rattlesnakes... Like I've heard of guys in colder climates putting a small heater in the trailer of their fiberglass glider during the winter. What are everyone's thoughts on that? Is it necessary? Of course its necessary silly. You need to keep your rattlesnake warm! |
Winter Care
Darn! I just futzed around with a water
pipe heater when I could have just got a reptile hot rock. Remember your rattlesnake won't eat any rodents unless it can find a warm spot to digest. When finished digesting you have to train your rattlesnake to do his business away from the trailer. Good luck! At 19:18 03 December 2015, Dave Nadler wrote: On Wednesday, December 2, 2015 at 6:39:18 PM UTC-5, IA DPE wrote: Rattlesnakes... I've heard of guys in colder climates putting a small heater in the trailer of their fiberglass glider during the winter. What are everyone's thoughts on that? Is it necessary? Of course its necessary silly. You need to keep your rattlesnake warm! |
#29
Winter Care
To minimize openings underneath your sailplane trailer, place a bright lightbulb inside and close the hatches. Works best in a dark hangar or in the evening. Roll under on a creeper with a piece of chalk or marker in hand. Mark anywhere you see light coming through the floor. Caulk or seal as needed. This will minimize the openings for the mice or snakes and reduce the road dust and water inside when trailering.
In my hangars I use Bounce fabric softeners generously (makes the sailplanes smell nice) and it seems to discourage mice. I've never had mice inside my sailplanes at Marfa, Texas, but a few inside my hangar. The Victor "Tin Mouse" humane aluminum box "one-way" trap works well although you need to release the critters at least two miles from your hangar. Recently upon releasing a mouse in the grasslands of the Marfa Plateau a Swainson hawk swooped down for a fast meal about 20 feet away from me! I do not allow any food inside my hangars, ever. Gotta sit outside on my picnic tables for your peanut butter and jelly sandwiches or granola bars. No food trash or empty soda or Gatorade bottles are put in my hangar trash cans and no food inside the sailplanes except a banana or apple which can be tossed overboard in flight. No water bottles are ever left inside the sailplanes as I'm told mice can smell water, even in a container. Paper checklists and FAA aircraft certificates are encased in plastic sleeves. So no mice recently and hopefully no snakes in the hangars but ya never know. Interrupting the food chain seems to work. Gotta go fly now. |
#30
Winter Care
Excellent advice!
On 12/4/2015 7:37 AM, Burt Compton - Marfa Gliders, west Texas wrote: To minimize openings underneath your sailplane trailer, place a bright lightbulb inside and close the hatches. Works best in a dark hangar or in the evening. Roll under on a creeper with a piece of chalk or marker in hand. Mark anywhere you see light coming through the floor. Caulk or seal as needed. This will minimize the openings for the mice or snakes and reduce the road dust and water inside when trailering. In my hangars I use Bounce fabric softeners generously (makes the sailplanes smell nice) and it seems to discourage mice. I've never had mice inside my sailplanes at Marfa, Texas, but a few inside my hangar. The Victor "Tin Mouse" humane aluminum box "one-way" trap works well although you need to release the critters at least two miles from your hangar. Recently upon releasing a mouse in the grasslands of the Marfa Plateau a Swainson hawk swooped down for a fast meal about 20 feet away from me! I do not allow any food inside my hangars, ever. Gotta sit outside on my picnic tables for your peanut butter and jelly sandwiches or granola bars. No food trash or empty soda or Gatorade bottles are put in my hangar trash cans and no food inside the sailplanes except a banana or apple which can be tossed overboard in flight. No water bottles are ever left inside the sailplanes as I'm told mice can smell water, even in a container. Paper checklists and FAA aircraft certificates are encased in plastic sleeves. So no mice recently and hopefully no snakes in the hangars but ya never know. Interrupting the food chain seems to work. Gotta go fly now. -- Dan, 5J |
Similar Threads | ||||
Gelcoat care | Nick Kennedy | Soaring | 16 | November 2nd 13 02:45 PM |
Canopy Care | Guy[_7_] | Soaring | 15 | March 25th 10 04:50 AM |
Any ex-zoomies out there care to comment? | Stewart Kissel | Soaring | 2 | April 14th 05 06:02 PM |
VA Health Care | Steve Mellenthin | Military Aviation | 0 | August 19th 04 05:45 PM |
New Paint Care Suggestions | Nathan Young | Owning | 11 | July 11th 04 11:24 PM |
