Running FS2004 under XP, on a flight in the Baron from Catumbela Angola
(FNCT) to Windhoek (FYWH), I'm getting a sinking feeling about 10 mins into the flight. The air pressure drops, the indicated altitude steps upwards (in several stages), engine performance (as indicated by fuel flow) drops, and so does indicated air speed. Changes are steep enough that I can maintain neither speed nor altitude, and the aircraft sinks out of the sky. Realism is set to high, though reliability is 100% (even if that's not 100% realistic :-) I'm using Real Weather at present, though I will continue to experiment, for example with static weather. Has anyone else noticed weirdness such as this, in West Africa or elsewhere? |
In article , Neil Trotter
said: I'm using Real Weather at present, though I will continue to experiment, for example with static weather. Hmm, using static weather "fixes" it ... so either there is a rogue weather station in the area somewhere, or data for that particular station (or the region) is being processed badly by FS. Still be interested to hear other ideas, experiences, etc. though. :-) |
| Thread Tools | |
| Display Modes | |
| Hire & Fly in South Africa. | Bush Air | General Aviation | 0 | May 24th 04 06:53 AM |
| Hire & Fly in South Africa. | Bush Air | General Aviation | 0 | May 24th 04 06:49 AM |
| gyroplane Safari South Africa | Jan | Rotorcraft | 3 | February 2nd 04 07:52 PM |
| What if we ignored N. Africa and the MTO? | ArtKramr | Military Aviation | 49 | December 14th 03 05:55 AM |
| Hire & Fly. S Africa | Bush Air | Piloting | 0 | July 13th 03 06:42 AM |
