Hi
Our 302 unit with V2.50 firmware in it will not transfer Flight Logs after bombing out mid-way on a previous transfer. I am using a Windows 2000 PC with Utility V2.55, which has previously downloaded logs without any trouble. Now, when I click on the button to start the transfer, it does not display any logs to choose from. Instead, there is an error dialog box, which says "300_Utility_PC255" on the title bar, and says "Could not get FAT.(A)" and an "OK" button I have tried restarting the PC Utility software to no avail. I also tried switching off the 302 and then recycling the battery power to it. Still, it doesn't work. I can use the other buttons on the PC Utility main menu to transfer the 302's Glider ID and Polar and Instrument Settings OK, so it *IS* communicating. It also seems to be working correctly as a vario, etc, though it hasn't been flown since that time (perhaps when it starts to write a new log it'll clear the old one). Can anyone please advise what course of action I should take, or some remedial steps I should try. I *DO NOT* want to lose the flight logs (there are 107 of them in there, per my efforts BEFORE it bombed) Perhaps this issue is fixed by later firmware ? The CAI web site only shows the release notes for the very latest V2.63 firmware. Is there a set of cumulative firmware change logs kept somewhere ? That's very useful if a user needs to "skip" a few versions. Does upgrading the firmware cause the logs to be cleared ? (I don't want this to happen if at all possible) I look forward to help from anyone out there that may be able to assist with this problem Thanks in advance Jason |
Jason
Reloading the firmware doesn't delete my 302 logs (or settings). A new flight will only clear the oldest logs progressively if the memory is full. There isn't a record of revision chnages that I know of but all the revision changes recently must be software bug issues as there are no noticeable function changes. I'm not particularly computer knowledgable and I don't know what your problem is but I do know that the first thing I would try would be to download the newest firmware for the 302 and also the utility programme and try again. Next step would be to download to a PDA or another PC and after that to contact Cambridge. John Galloway At 04:48 11 July 2003, Jason Armistead wrote: Hi Our 302 unit with V2.50 firmware in it will not transfer Flight Logs after bombing out mid-way on a previous transfer. I am using a Windows 2000 PC with Utility V2.55, which has previously downloaded logs without any trouble. Now, when I click on the button to start the transfer, it does not display any logs to choose from. Instead, there is an error dialog box, which says '300_Utility_PC255' on the title bar, and says 'Could not get FAT.(A)' and an 'OK' button I have tried restarting the PC Utility software to no avail. I also tried switching off the 302 and then recycling the battery power to it. Still, it doesn't work. I can use the other buttons on the PC Utility main menu to transfer the 302's Glider ID and Polar and Instrument Settings OK, so it *IS* communicating. It also seems to be working correctly as a vario, etc, though it hasn't been flown since that time (perhaps when it starts to write a new log it'll clear the old one). Can anyone please advise what course of action I should take, or some remedial steps I should try. I *DO NOT* want to lose the flight logs (there are 107 of them in there, per my efforts BEFORE it bombed) Perhaps this issue is fixed by later firmware ? The CAI web site only shows the release notes for the very latest V2.63 firmware. Is there a set of cumulative firmware change logs kept somewhere ? That's very useful if a user needs to 'skip' a few versions. Does upgrading the firmware cause the logs to be cleared ? (I don't want this to happen if at all possible) I look forward to help from anyone out there that may be able to assist with this problem Thanks in advance Jason |
Andy,
When you say that the slow alarm was interfering with the vario, do you mean that it tended to make the vario sound intermittent? If so, that IS the slow alarm. The slow alarm is not a siren as you might think, but it simply interrupts the vario audio so one might easily think that they have a problem with their vario audio until they find out it's a "feature not a bug". Same thing happened to me by the way. Mark Andy Durbin wrote: I upgraded my 302 firmware before going to Hobbs. It appeared to delete all logs. Suggest you try a different utility version, or a PDA transfer, before you change the firmware. When you have recovered the logs then upgrade the firmware. Cambridge has been doing a poor job of advising customers what has changed in each firmware version. I have asked for change information but have not received any. I upgraded to fix a ballast transfer problem and found I introduced a new problem with the slow alarm interfering with the vario. (that was fixed by setting the slow alarm threshold to a very low value) They have been responsive to specific questions so I suggest you try to contact them. Andy (GY) (Jason Armistead) wrote in message . com... Hi Our 302 unit with V2.50 firmware in it will not transfer Flight Logs after bombing out mid-way on a previous transfer. I am using a Windows 2000 PC with Utility V2.55, which has previously downloaded logs without any trouble. Now, when I click on the button to start the transfer, it does not display any logs to choose from. Instead, there is an error dialog box, which says "300_Utility_PC255" on the title bar, and says "Could not get FAT.(A)" and an "OK" button I have tried restarting the PC Utility software to no avail. I also tried switching off the 302 and then recycling the battery power to it. Still, it doesn't work. I can use the other buttons on the PC Utility main menu to transfer the 302's Glider ID and Polar and Instrument Settings OK, so it *IS* communicating. It also seems to be working correctly as a vario, etc, though it hasn't been flown since that time (perhaps when it starts to write a new log it'll clear the old one). Can anyone please advise what course of action I should take, or some remedial steps I should try. I *DO NOT* want to lose the flight logs (there are 107 of them in there, per my efforts BEFORE it bombed) Perhaps this issue is fixed by later firmware ? The CAI web site only shows the release notes for the very latest V2.63 firmware. Is there a set of cumulative firmware change logs kept somewhere ? That's very useful if a user needs to "skip" a few versions. Does upgrading the firmware cause the logs to be cleared ? (I don't want this to happen if at all possible) I look forward to help from anyone out there that may be able to assist with this problem Thanks in advance Jason |
When thermalling at 60-65kts the vario tone was modulated by what I
can only describe as a cavalry charge bugle call. Yes, this is probably the slow alarm but it should not have been sounding as the slow alarm speed was set to 40kts. It took me most of the practice day flight to figure out what was going on. I don't know if the the problem is fixed in the current firmware. At that time I was one version out of date. Andy (GY) Mark Zivley wrote in message ... Andy, When you say that the slow alarm was interfering with the vario, do you mean that it tended to make the vario sound intermittent? If so, that IS the slow alarm. The slow alarm is not a siren as you might think, but it simply interrupts the vario audio so one might easily think that they have a problem with their vario audio until they find out it's a "feature not a bug". Same thing happened to me by the way. Mark |
I use the slow alarm in my '26E. For an alarm at around 46 knots
indicated, I had to set the trigger pojnt to 40 or so - though it tends to vary by a couple knots from day to day. It does seem to be connected to the G meter, as the tone comes on at a higher speed if I'm pulling more G. The tone is kind of modulated as you describe, but it's still easy to to 'read' the vario strength. I've played with the display in screen 10 of the 302 to compare what it thinks my IAS is vs the mechanical airspeed. It's within a couple knots at 65-90, but below 65 it reads slower than the mechanical. They're tee-d to the same pitot, so without adding a 3rd ASI, I really don't know which is correct. I find that the ship thermals best just a bit under 50 KIAS, and much below 46 is nearly impossible to maintain control. This is why the slow alarm is set there. -Tom (Andy Durbin) wrote in message . com... When thermalling at 60-65kts the vario tone was modulated by what I can only describe as a cavalry charge bugle call. Yes, this is probably the slow alarm but it should not have been sounding as the slow alarm speed was set to 40kts. |
| Thread Tools | |
| Display Modes | |
| GEM 1200 Problem | Jim Kaufeld | Owning | 11 | March 22nd 04 04:54 AM |
| A problem in the Military ? | Nick Jade | Military Aviation | 54 | March 15th 04 08:59 PM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 10:10 PM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 10:10 PM |
| Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 06:29 PM |
