Akaflieg Karlsruhe AK-X
Old March 2nd 16, 06:55 PM posted to rec.aviation.soaring
Craig Funston
Default Akaflieg Karlsruhe AK-X
On Monday, February 1, 2016 at 8:29:39 AM UTC-8, Jonathan St. Cloud wrote:
Thanks so much for the information. I did see a youtube video of a spin that stopped in one direction and started in the next.
On Monday, February 1, 2016 at 12:11:12 AM UTC-8, Tango Whisky wrote:
Le lundi 1 février 2016 00:43:41 UTC+1, Martin Gregorie a écrit*:
On Sun, 31 Jan 2016 06:07:14 -0800, Tango Whisky wrote:
Many thanks for that description.
I'd wondered how, when 'pecking' had a largely unknown onset condition
and no way known of exiting it, and in addition stalls led to spins that
reversed during recovery, the airframes and pilot(s) survived the years
long test series.
Yours is the first account I've seen to say that this was due to
parachute recovery. Now I can see how all this was possible, so thanks
for that.
I've been a member of Akaflieg Braunschweig during the construction
period of the SB 13. I did write the final eport, and did present the
flight testing on the SSA convention in 1988.
The idea came up because there was the possibility to develop laminar
airfoils with decent pitch stability. So it was guessed that without the
tail boom, there should be 10% increase in performance. At that time,
the SB 12 was the firt standard class glider exceeding 40:1.
During tests with a 1/3 scale model, there was a flutter coming up which
was the result of pitch oscillation coupled to a bending oscillation of
the wing. The solution was to employ - the first time ever in aviation -
high-modulus carbon fibers (instead of high-strength carbon fibers) in
the spar caps. This pushed the bending frequency of the wings well
beyond the flight enveloppe.
Main pain during the construction of the wing structure was the fact
that the wing connection was classic, but the wing was swept back 15
degrees, so that the spar caps would experience torsion. To evacuate the
torsion into the skin of the wings, we had 45 degree fabric layed up
over each layer of rovings. 8 hours of lay-up with a team of 8 for each
spar cap...
The incident during first fligh showed a problem with a swept back wing:
When the glider hit the stationary take-off vortex of the tug on the
runway, the inboard section of the wing stalled and the nose pitched
down. That was mitigated later by a 80 m rope, and by a very gentle
lift-off of the tug. However, whenever the SB 13 hit the propwash behind
the tug, it pitched down into the low tow position- no way to come up
again. So low-tow was standard procedure.
Flight tests showed a strong pitch oscillation for forward CoG
positions, with a frequency of about 1 Herz which are impossible for the
pilot to counter. Moving the CoG aft improved that, but the spin
behaviour was a real bitch. The reason is that the inboard wing stalls
first, and due to the sweep-back, the detached flow rapidly moves
outboard.
Solution to this was putting 2 boundary layer fences on the leading edge
of each wing.
The nose wheels was a very tiny structure (no place to put serious
steel), so any incident directly led to the workshop.
With no tail boom, the SB 13 was prone to receive a spring-operated
recovery system. It was extensively tested with a dummy fuselage and
telemetry, releasing it at various configurations at 200 ft from
underneath a helicopter. It worked pretty well, with 3 canopies of 1200
sqft each.
That recovery system had fixed lifetime of 15 years, so when it was
over, it was decided to stop the flights with the SB 13, and to give it
to a museum (Deutsches Museum in Unterschleissheim, I think).
Will be interesting to see how the AK-X will work around the pitfalls...
Bert Ventus cM TW
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Don't get me misunderstood - the recovery system was extensively tested on the dummy fuselage, and it's final version was mounted into the SB 13. However, this final recovery systems had never to be deployed.
I maybe forgot to mention that the tests showed the descent rate under canopy to be around 5 m/s. Now, for the pilot that would still be a nasty impact, but by all means survivable. For the wings, this impact speed would have been fatal because the high-modulus fibers of the spar caps were known not to stand shock loads. So, if the recovery systems would have been deployed one single time, the SB 13 would have gone to the trash bin.
The pitch oscillation was triggered by any small excitation, but it was stable, i.e. the amplitude did not increase. It was just described as unpleasant.
The spin behaviour was discovered during a demonstration flight at about 1500-2000 ft, and this was the only time that the recovery systems came close to being deployed. Subsequent tests where then done at 7'000-10'000 ft, with the results being impressive, but no longer frigthening. Finally, the boundary layer fences did the trick.
There's a very nice technical article about the AK-X in the current RC Soaring Digest http://www.rcsoaringdigest.com/. Page 27
Translated from German by Google translate it was.
