Need input on wheel brake adjustment for an SZD-55. The wheel brake is
strong, but comes on too soon when opening spoilers. I would like to delay the brake activation some. The cable adjuster at the wheel is already backed all the way out. Do I increase the disk spacing from pads on the wheel assembly by adjustment at the hub first then adjust cable? Any help would be greatly appreciated. Thanks in advance, Wells Morse **remove "55" from email return address** |
I'm pretty sure you need to go the other way with it.... If it is a standard
cable type affair. Regards, Larry "01" USA WDM wrote: Need input on wheel brake adjustment for an SZD-55. The wheel brake is strong, but comes on too soon when opening spoilers. I would like to delay the brake activation some. The cable adjuster at the wheel is already backed all the way out. Do I increase the disk spacing from pads on the wheel assembly by adjustment at the hub first then adjust cable? Any help would be greatly appreciated. Thanks in advance, Wells Morse **remove "55" from email return address** |
hy,
I have the same problem with brake on my szd-55-1. When I pull the air brake to half position, the weel brake too much. Is possibile modificate the system or something? My be replace with disc brake TOST? By Ivo from croatia |
| Thread Tools | |
| Display Modes | |
| Piper 6.00x6 Nose Wheel and Fork? | mikem | General Aviation | 5 | March 6th 04 12:34 AM |
| Piper 6.00x6 Nose Wheel and Fork? | mikem | Restoration | 5 | March 6th 04 12:34 AM |
| Building the Po' Boy Bending Brake | Veeduber | Home Built | 14 | March 1st 04 07:15 PM |
| VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 06:22 AM |
| The Little Wheel in Back | Veeduber | Home Built | 6 | September 8th 03 11:29 AM |
