The regs seem to simply require experience while'towing a glider with an aircraft' and the U.S.regs don't seem to care what kind of aircraftis used. Tow with a blimp? Don'tthose things go something like maybe twentyknots tops? While towing gliders I've been quite concernedabout my 'noodle.' Yes I've been concernedabout catching on a runway light, rope in theprop during taxi, etc. But the idea of therope snapping back and wrapping the elevatoror rudder in flight has been a concern both as a towpilot and as a glider pilot. Prettyremote possibility, but a good reason fora nice weak link at the end of the towrope.Towing in a helicopter? My goodness! Thiswould REALLY scare me. Towrope in the rotor blades? Yikes! Did they have somethingweighty on the end of the towrope?Mark Boyd
I have read a report once in a (danish) gliding magazine, I think it was
from them World chamoinships once held in Lezno, Poland. the glider was a Foka type. the trick is that you start with a tailglide. jens S, bornholm denmark "M B" skrev i en meddelelse ... The regs seem to simply require experience while'towing a glider with an aircraft' and the U.S.regs don't seem to care what kind of aircraftis used. Tow with a blimp? Don'tthose things go something like maybe twentyknots tops? While towing gliders I've been quite concernedabout my 'noodle.' Yes I've been concernedabout catching on a runway light, rope in theprop during taxi, etc. But the idea of therope snapping back and wrapping the elevatoror rudder in flight has been a concern both as a towpilot and as a glider pilot. Prettyremote possibility, but a good reason fora nice weak link at the end of the towrope.Towing in a helicopter? My goodness! Thiswould REALLY scare me. Towrope in the rotor blades? Yikes! Did they have somethingweighty on the end of the towrope?Mark Boyd |
WGC 1995 in Omarama NZ
the ASW24 started behind a Hughes 500 in low tow accelerating to 120km/h after reaching a height of approximately 500m AGL the helicopter transited into vertical climb and the ASW-24 just hanged on its Tost hook (attached to the main wheel) upside down. The glider pilot then released and came to safe airspeed as if he would have lost speed just short of topping a loop. PS: the guys checked with Gerhard Waibel (the designer of the Schleicher glider, if it would be safe to strain the towing hook and the airframe in that way. Chris "Jim Culp" wrote in message ... Who gives or knows of glider aerotows with choppers in US ? or elsewhere ? Where & contact info ? Price for 2000ft tow ? I saw it done by helicopter at Williston Florida (near Gainesville) at airshow April 2003. Nice job, well done. The chopper was the tug aircraft for the glider; taking it to 6000ft for start of glider aerobatic routine. No problemo. Think the helicopter was a Bell47. Not sure. Anyway, I thing I recall it was piston engined. Yes, after vertical liftoff helicopter did rotate forward, for forward propulsion lifting its tailboom, to keep the tail rotor blades out of the towrope. Not a job for an inattentive helicopter pilot. Well, Ok ,,,,would you launch your glider by helicopter aerotow ? Here's a another query, for regulatory pundits: Can a helicopter pilot be qualified for glider aerotow with helicopter by aerotowing in airplane (assuming he is airplane rated) ? Or must his aerotow qualification in airplane be limited to Airplane only ? My thought is that since noone writing the rule requirements in US ever conceived of helicopter aerotows of gliders then there is nothing to prevent an airplane aerotow qualification from being inclusive of and transferable to launching a glider with any type powered aircraft. Thus, if a blimp pilot had an aerotow qualification gained in an airplane, and wth a blimp he wanted to aerotow or gravity launch a glider, then he might do so. He would be compliant with requlations. Yes or no ? Seems to me, for gravity launch of a glider suspended suitably from a blimp or dirigible there would be no launch capability requirement of the lighter than air pilot . The pilot of the lighter than air craft might only need only his pilot certificate privileges in the lighter than air craft (blimp or dirigible) to do the feat. Launching of glider by a lighter than air craft would not be new. The blimp pilot would not be the first to launch a glider, as this was done for the glider pilot (USN) Lt. Ralph S. Barnaby in 1930 at Lakehurst New Jersey with the glider released at 3000ft. It was a successfully done feat. Dancing on clouds, Keep it up! Jim Culp USA GatorCity, Florida Std Libelle |
just as long as it did not back release... "ouch"
"CH" wrote in message ... WGC 1995 in Omarama NZ the ASW24 started behind a Hughes 500 in low tow accelerating to 120km/h after reaching a height of approximately 500m AGL the helicopter transited into vertical climb and the ASW-24 just hanged on its Tost hook (attached to the main wheel) upside down. The glider pilot then released and came to safe airspeed as if he would have lost speed just short of topping a loop. PS: the guys checked with Gerhard Waibel (the designer of the Schleicher glider, if it would be safe to strain the towing hook and the airframe in that way. Chris "Jim Culp" wrote in message ... Who gives or knows of glider aerotows with choppers in US ? or elsewhere ? Where & contact info ? Price for 2000ft tow ? I saw it done by helicopter at Williston Florida (near Gainesville) at airshow April 2003. Nice job, well done. The chopper was the tug aircraft for the glider; taking it to 6000ft for start of glider aerobatic routine. No problemo. Think the helicopter was a Bell47. Not sure. Anyway, I thing I recall it was piston engined. Yes, after vertical liftoff helicopter did rotate forward, for forward propulsion lifting its tailboom, to keep the tail rotor blades out of the towrope. Not a job for an inattentive helicopter pilot. Well, Ok ,,,,would you launch your glider by helicopter aerotow ? Here's a another query, for regulatory pundits: Can a helicopter pilot be qualified for glider aerotow with helicopter by aerotowing in airplane (assuming he is airplane rated) ? Or must his aerotow qualification in airplane be limited to Airplane only ? My thought is that since noone writing the rule requirements in US ever conceived of helicopter aerotows of gliders then there is nothing to prevent an airplane aerotow qualification from being inclusive of and transferable to launching a glider with any type powered aircraft. Thus, if a blimp pilot had an aerotow qualification gained in an airplane, and wth a blimp he wanted to aerotow or gravity launch a glider, then he might do so. He would be compliant with requlations. Yes or no ? Seems to me, for gravity launch of a glider suspended suitably from a blimp or dirigible there would be no launch capability requirement of the lighter than air pilot . The pilot of the lighter than air craft might only need only his pilot certificate privileges in the lighter than air craft (blimp or dirigible) to do the feat. Launching of glider by a lighter than air craft would not be new. The blimp pilot would not be the first to launch a glider, as this was done for the glider pilot (USN) Lt. Ralph S. Barnaby in 1930 at Lakehurst New Jersey with the glider released at 3000ft. It was a successfully done feat. Dancing on clouds, Keep it up! Jim Culp USA GatorCity, Florida Std Libelle |
At 03:42 09 September 2003, M B wrote:
The regs seem to simply require experience while'towing a glider with an aircraft' and the U.S.regs don't seem to care what kind of aircraftis used. Tow with a blimp? Don'tthose things go something like maybe twentyknots tops? While towing gliders I've been quite concernedabout my 'noodle.' Yes I've been concernedabout catching on a runway light, rope in theprop during taxi, etc. But the idea of therope snapping back and wrapping the elevatoror rudder in flight has been a concern both as a towpilot and as a glider pilot. Prettyremote possibility, but a good reason fora nice weak link at the end of the towrope.Towing in a helicopter? My goodness! Thiswould REALLY scare me. Towrope in the rotor blades? Yikes! Did they have somethingweighty on the end of the towrope?Mark Boyd I believe the Royal Navy experimented with towing with a helicopter in the 60's. If I recall rightly the main problem mentioned, apart from maintaining separation between ropes and rotors, was keeping the glider out of the turbulence created by the helicopter. This needed about half a mile of towrope. |
Bob Carlton (Silentwingsairshows.com) is currently doing about three
hellicopter tows a year with his Salto, although it's not as most of you are imagining it. The hellicopter has 10 ft of chain dangling under it which the rope is attached to. He lifts off and flies forwards and the glider does a normal take off followed by a basicly normal tow. -Mitch |
| Thread Tools | |
| Display Modes | |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| helicopter tug glider launch | Buck Wild | Soaring | 0 | September 9th 03 04:30 AM |
| Glider rocket launch | Jim Culp | Soaring | 1 | September 7th 03 08:18 PM |
| Restricting Glider Ops at Public Arpt. | rjciii | Soaring | 36 | August 25th 03 05:50 PM |
