Waht is the best way to glue two piece of phenolic together?
Dan, U.S. Air Force, retired |
(Leon McAtee)
Date: 6/9/2004 7:14 PM Central Daylight Time Message-id: (B2431) wrote in message ... Waht is the best way to glue two piece of phenolic together? Dan, U.S. Air Force, retired In my experience the best way to glue phenolic together is with AN3-X. Most if not all of the epoxy resins we homebuilders use bonds poorly to phenolic. Drilling holes in the phenolic fitting and using cotton flox in the resin as a kind of composite rivet makes for a useable structure. Think encapsulation rather than bonding. ===================== Leon McAtee Q builder I am building and LED indicator lamp holder. I have a 3/8" and a 1/8" phenolic. I want to glue/epoxy them together to make 1/2" thick. Using your idea of encapsulation how would I do this? Dan, U.S. Air Force, retired |
===================== Leon McAtee Q builder Thought you were thinking about structural things like rudder hinges..... For what your considering - I think - just sand well with something like 120 grit sandpaper and use any good epoxy. Whack it with a hammer and it will probably break at the epoxy/phenolic surface but for holding LEDS it should be just fine. I am building and LED indicator lamp holder. I have a 3/8" and a 1/8" phenolic. I want to glue/epoxy them together to make 1/2" thick. Using your idea of encapsulation how would I do this? Dan, U.S. Air Force, retired |
| Thread Tools | |
| Display Modes | |
| Spar gluing | Lou Parker | Home Built | 26 | November 21st 03 09:29 PM |
