1 Hz NMEA-logfiles wanted from real soaring flights
Old October 7th 03, 10:53 AM
Andrea Schlapbach
Default 1 Hz NMEA-logfiles wanted from real soaring flights
I am looking for NMEA-logfiles from real soaring flights with original
1 Hz NMEA output, being interested in the coordinates, track and
ground speed. IGC-files are not sufficient because calculating track /
speed as well interpolating track / speed / coordinates out from a
0.25 Hz IGC-file results in lower precision.
Tnx
Andrea.Schlapbach{at}bluewin.ch
Old October 8th 03, 12:32 AM
dhofstee
IGC log time is dependent on settings in the logger.
For example, the next two lines are from a .IGC file. They show a two
second interval setting.
B1041125216936N01348271EA-002700135115360
B1041145216922N01348319EA-001700145117360
Unfortunately I don't have the time to write a script to filter for
these interval times. A massive number of files can be downloaded from
online contest sites. OLC 2002 in Germany shows about 5442 files. Gtz,
David
NL
Old October 8th 03, 02:42 AM
Dave Nadler \YO\
Typically loggers are set to record less frequently because otherwise
the resulting files are "too large" for some scoring programs. Our logger
frequency was reduced because of such complaints. Some older popular
loggers won't record at 1Hz anyway...
Depending on your application, its not too hard to write a smoothing
model that will produce decent results. What's your application ?
Have you tried interpolation (and with what kind of model) ?
Best Regards, Dave "YO"
"Andrea Schlapbach" wrote in message
om...
Tnx
Old October 8th 03, 05:38 PM
Henryk Birecki
You can use GPS_LOG WinCE, put it in raw data logging mode and record
your own data from a flight. You can get the program and all
information at http://www.soaringpilotsoftware.com
Henryk Birecki
says...
Old October 11th 03, 10:08 PM
Hans L. Trautenberg
Hi ANdrea,
we have some flights at the server of the onlinecontest.org . Try the
following link
http://www.onlinecontest.org/olcphp/...c&igc=39rc3d61
you may replace the 39rc3d61 also by the following igc-filename fragments
35uf76v2,
35uf76v1,36janwi1,37ds0ccc,38180021,38ef3126,38qpa aaj,393f7kh1,39d30923, or
39rc3d61
Best Regards
Hans
"Andrea Schlapbach" schrieb im Newsbeitrag
om...
Tnx
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 08:16 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
Flight instructors as Charter Pilots C J Campbell Piloting 6 January 24th 04 08:51 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
