Simple question I hope.
In respect to pilot seating, is the fuselage on the LS4 the same as LS6a ? Cheers Mark |
The 6 is much narrower then the 4, to reduce wetted area. If you fit in a 6, you will be able to get lost inside a 4 cockpit-or as someone once posted here, 'Carry a bag of apples along with you'. At 23:00 27 October 2003, Mark wrote: Simple question I hope. In respect to pilot seating, is the fuselage on the LS4 the same as LS6a ? Cheers Mark |
In respect to pilot seating, is the fuselage on the LS4 the same as LS6a ? Hi Mark, I measured the difference when we had a 4 and a 6 in the shop. The LS-6 is 2 inches less in width and 2 inched lass in height. JJ Sinclair |
Thanks Stewart and JJ............exactly what I was after.
Cheers Mark (JJ Sinclair) wrote in message ... In respect to pilot seating, is the fuselage on the LS4 the same as LS6a ? Hi Mark, I measured the difference when we had a 4 and a 6 in the shop. The LS-6 is 2 inches less in width and 2 inched lass in height. JJ Sinclair |
how would a LS6 cockpit compare with a Ventus 2a in width and height
thanks Ernie -- "When we come to the place where the road and sky collide" "Throw me over the edge and watch my spirit fly" "Mark" wrote in message om... Thanks Stewart and JJ............exactly what I was after. Cheers Mark (JJ Sinclair) wrote in message ... In respect to pilot seating, is the fuselage on the LS4 the same as LS6a ? Hi Mark, I measured the difference when we had a 4 and a 6 in the shop. The LS-6 is 2 inches less in width and 2 inched lass in height. JJ Sinclair |
"Ernie Schneider" wrote in message news:4%1ob.1795$EY3.1046@edtnps84...
how would a LS6 cockpit compare with a Ventus 2a in width and height thanks Ernie Do some people not know how to use the net or are they just lazy? LS4: 64cm / 83cm LS6,7,8: 61cm / 80cm S-H a: 54cm / 75cm S-H b+c: 62cm / 81cm ASW27+28: 64cm / 80cm |
Ernie,
here's a more qualitative answer from someone 6'2" and 225 lbs: No, they don't compare. I can fly and LS-6 comfortably if I take the seat back out. I can't even close the Ventus 2a canopy. (BTW, the 2bx is very roomy.) Cheers |
Ernie Schneider wrote:
how would a LS6 cockpit compare with a Ventus 2a in width and height As far as I remember (flown a Ventus 2a twice in September, LS6 last Saturday and a lot of other times) there is a little more space in the LS6. The Ventus 2a didn't have an adjustable back rest, so I had to add a cushion behind the parachute. |
thanks Robert, and what would your "size" be ?
I fit comfortably in a LS6(had one for a year) and I am 178 cm/5'10" Ernie -- "When we come to the place where the road and sky collide" "Throw me over the edge and watch my spirit fly" "Robert Ehrlich" wrote in message ... Ernie Schneider wrote: how would a LS6 cockpit compare with a Ventus 2a in width and height As far as I remember (flown a Ventus 2a twice in September, LS6 last Saturday and a lot of other times) there is a little more space in the LS6. The Ventus 2a didn't have an adjustable back rest, so I had to add a cushion behind the parachute. |
Marcel, thanks for the legwork - highly appreciated
Ernie -- "When we come to the place where the road and sky collide" "Throw me over the edge and watch my spirit fly" "Marcel Duenner" wrote in message om... "Ernie Schneider" wrote in message news:4%1ob.1795$EY3.1046@edtnps84... how would a LS6 cockpit compare with a Ventus 2a in width and height thanks Ernie Do some people not know how to use the net or are they just lazy? LS4: 64cm / 83cm LS6,7,8: 61cm / 80cm S-H a: 54cm / 75cm S-H b+c: 62cm / 81cm ASW27+28: 64cm / 80cm |
| Thread Tools | |
| Display Modes | |
| Who can identify this tube frame aircraft fuselage? | Rob de Bie | Home Built | 5 | January 13th 05 10:45 PM |
| Trike wing bolt size | Aaron Smith | Home Built | 0 | September 30th 03 04:02 AM |
| #1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 04:04 AM |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
| Fitting canopy frame to fuselage advice | Deputy Dog | Soaring | 5 | July 27th 03 05:08 AM |
