Speaking of cockpits, this one is of a Polikarpov I-16, showing the hand
crank that retracts the landing gear, on the lower right. With 45 turns (some say 75 turns) of the crank, this tedious process meant that most of its flight testing was done with the gear down. |
In article , Byker says...
This is a multi-part message in MIME format. Speaking of cockpits, this one is of a Polikarpov I-16, showing the hand crank that retracts the landing gear, on the lower right. With 45 turns (some say 75 turns) of the crank, this tedious process meant that most of its flight testing was done with the gear down. Hence, the Polikarpov designers warning to the test pilots: "This is Russia...you do not do the Polikarpov I-16...the Polikarpov I-16 does YOU." * |
"Miloch" wrote in message ...
Hence, the Polikarpov designers warning to the test pilots: "This is Russia...you do not do the Polikarpov I-16...the Polikarpov I-16 does YOU." The "flying barrel" seems to have been inspired by the Gee Bee racers. There was a saying in Russian, "If you can fly the I-16, you can fly anything." |
"Miloch" wrote in message ... Hence, the Polikarpov designers warning to the test pilots: "This is Russia...you do not do the Polikarpov I-16...the Polikarpov I-16 does YOU." The "flying barrel" seems to have been inspired by the Gee Bee racers. There was a saying in Russian, "If you can fly the I-16, you can fly anything." Looks like they palmed a few off to the Chinese and let them worry about it. * |
A big engine, with as little airframe as possible to keep it in the air... |
| Thread Tools | |
| Display Modes | |
| Cockpits...file name same as aircraft type [03/21] - A-26 Cockpit.jpg (1/1) | Miloch | Aviation Photos | 2 | June 20th 16 08:47 PM |
| Cockpits...file name same as aircraft type...a few more [11/15] - spitfire-cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 05:09 PM |
| Cockpits...file name same as aircraft type...a few more [07/15] - P51-cockpit-1000.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 05:09 PM |
| Cockpits...file name same as aircraft type [13/21] - F-15C Cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 05:04 PM |
| Cockpits...file name same as aircraft type [12/21] - F4U Corsair Cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 05:04 PM |
