https://en.wikipedia.org/wiki/Consolidated_PBY_Catalina
The Consolidated PBY Catalina, also known as the Canso in Canadian service, was an American flying boat, and later an amphibious aircraft of the 1930s and 1940s produced by Consolidated Aircraft. It was one of the most widely used seaplanes of World War II. Catalinas served with every branch of the United States Armed Forces and in the air forces and navies of many other nations. During World War II, PBYs were used in anti-submarine warfare, patrol bombing, convoy escorts, search and rescue missions (especially air-sea rescue), and cargo transport. The PBY was the most numerous aircraft of its kind and the last active military PBYs were not retired from service until the 1980s. In 2014, nearly 80 years after its first flight, the aircraft continues to fly as a waterbomber (or airtanker) in aerial firefighting operations all over the world. The PBY was originally designed to be a patrol bomber, an aircraft with a long operational range intended to locate and attack enemy transport ships at sea in order to disrupt enemy supply lines. With a mind to a potential conflict in the Pacific Ocean, where troops would require resupply over great distances, the U.S. Navy in the 1930s invested millions of dollars in developing long-range flying boats for this purpose. Flying boats had the advantage of not requiring runways, in effect having the entire ocean available. Several different flying boats were adopted by the Navy, but the PBY was the most widely used and produced. Although slow and ungainly, Catalinas distinguished themselves in World War II. Allied forces used them successfully in a wide variety of roles for which the aircraft was never intended. They are remembered for their rescue role, in which they saved the lives of thousands of aircrew downed over water. Catalina airmen called their aircraft the "Cat" on combat missions and "Dumbo" in air-sea rescue service Specifications (PBY-5A) General characteristics Crew: 10 — pilot, co-pilot, bow turret gunner, flight engineer, radio operator, navigator, radar operator, two waist gunners, ventral gunner Length: 63 ft 10 7/16 in (19.46 m) Wingspan: 104 ft 0 in (31.70 m) Height: 21 ft 1 in (6.15 m) Wing area: 1,400 ft² (130 m²) Empty weight: 20,910 lb (9,485 kg) Max. takeoff weight: 35,420 lb (16,066 kg) Powerplant: 2 × Pratt & Whitney R-1830-92 Twin Wasp radial engines, 1,200 hp (895 kW each) each Zero-lift drag coefficient: 0.0309 Drag area: 43.26 ft² (4.02 m²) Aspect ratio: 7.73 Performance Maximum speed: 196 mph (314 km/h) Cruise speed: 125 mph (201 km/h) Range: 2,520 mi (4,030 km) Service ceiling: 15,800 ft (4,000 m) Rate of climb: 1,000 ft/min (5.1 m/s) Wing loading: 25.3 lb/ft² (123.6 kg/m²) Power/mass: 0.034 hp/lb (0.056 kW/kg) Lift-to-drag ratio: 11.9 Armament 3 .30 cal (7.62 mm) machine guns (two in nose turret, one in ventral hatch at tail) 2 .50 cal (12.7 mm) machine guns (one in each waist blister) 4,000 lb (1,814 kg) of bombs or depth charges; torpedo racks were also available |
| Thread Tools | |
| Display Modes | |
| UK2 JX635 Consolidated Catalina ex USN 44253 to VH-EAX.jpg | Joseph Testagrose | Aviation Photos | 0 | May 11th 14 03:48 PM |
| Consolidated PBY-5A Catalina 02 | CharlieH[_2_] | Aviation Photos | 3 | August 17th 13 09:54 AM |
| UK2 AH562 Consolidated Catalina.jpg | Joseph Testagrose | Aviation Photos | 0 | February 3rd 13 01:53 PM |
| UK1 W8492 Consolidated Catalina 1941-03.jpg | Joseph Testagrose | Aviation Photos | 0 | January 9th 13 02:48 PM |
| UK2 FP530 Consolidated Catalina ex USN 04990 PBY-5A to TF-ISJ Prestwick KeithCookPhoto.jpg | Joseph Testagrose | Aviation Photos | 0 | July 29th 12 02:38 PM |
