Dennis Fetters Mini 500
Old June 16th 04, 06:21 PM
Dennis Fetters
Brad Mallard wrote:
The guy is dead from a Mini 500.
Brad, That's really putting it in a way that makes it sound like it was
the helicopters fault when it was not. We're all adults, is it to much
to be fair here?
The man is dead because he was attempting to fly a "helicopter" that was
not correctly built, not correctly jetted, and had been modified in a
manner that could have adversely affected it's flight characteristics,
and he did not properly autorotate after he had an engine failure due to
his own failure to follow simple instructions.
That is the proper and fair description. It's sad to see someone die in
a completely preventable accident.
Couldn't that happen in any helicopter design with the same scenario, right?
Sincerely,
Dennis Fetters
"Dennis Fetters" wrote in message
m...
Brad Mallard wrote:
I will put a little two cents in here. I was actually finishing a
Metallurgical Engineering degree at the University of Alabama in
Tuscaloosa
a few years ago when the Areospace Engineering Department actually
bought a
kit as a project for the department.
I was actually following along the process of construction because I had
planned for quite some time to build one as well. I kept notes on the
progress and talked with the select individuals chosen to actually
construct
the craft. The Areospace department had only one instructor that was
helicopter rated and there is only one seat in this chopper, so it was
never
a question of who was going to fly the bird.
According to the FAA report of the National Transportation Board ID #
ATL01A003 it says " On October 3, 2000, at 0856 central daylight time, a
University of Alabama Mini-500 Experimental Helicopter, N6165T, collided
with the ground and burst into flames."
This guy had thousands of logged hours, and numerous aviation ratings
including Commercial Helicopter and a repairman experimental aircraft
builder certificate. My thoughts of building a helicopter quit that
day...
The full report can be read at www.ntsb.gov
"Jay" wrote in message
e.com...
Fetters wrote:
This is a little part of the problem here Brad. People don't tell the
complete story. In that way it will make a point opposite of what really
happened. Why would you do that? Here, lets go into the true, full facts:
On October 3, 2000, at 0856 central daylight time, a University of
Alabama Mini-500 Experimental Helicopter, N6165T, collided with the
ground and burst into flames while on approach to the Tuscaloosa
Municipal Airport, in Tuscaloosa, Alabama. cut
According to the airport control tower operator, the helicopter had
completed three to four circuits in closed traffic to taxiway golf.
While on the downwind leg, the controller believed that the helicopter
had a sudden loss of engine power and began to descend. The tower
received no communications and the helicopters rotor rpm decreased and
appeared to stop before impact. Crash fire rescue trucks were on the
scene and the post-crash fire was extinguished within minutes.
Fetters wrote:
Why did the engine quit? according to our files I do know that the
helicopter did not have all the mandatory AD's installed and should not
have been flying at all. I do know that the helicopter did not have the
mandatory PEP exhaust system installed which eliminated the need of
jetting after ambient temperature changes. I also know that he had left
the stock Rotax jetting in the engine and ignored our instructions to
change it from airplane jetting to helicopter jetting, which would cause
the engine to lean out and seize in a decent, as all of our advisories
and instructions said would happen. He also never even once signed and
returned a single AD notice as required.
cut
According to the aircraft logbook, on September 28, 2000, the pilot had
modified the helicopters horizontal stabilizer by cutting off part of
the stabilizer behind mounting plates number 88 and number 98, and
removed the winglets. The pilot flew 10 traffic patterns in new
configuration. He noted in the logbook "less objectionable side to side
shaking, but balance still indicates vertical 1.5 ips in climb."
However, according to the FAA, this modification was not approved as
required by the experimental aircraft operating limitations.
cut
The National Transportation Safety Board determines the probable
cause(s) of this accident as follows:
The loss of engine power for undetermined reasons, and the pilot's
unapproved airframe modification that resulted in the loss of flight
control during the emergency descent.
Fetters wrote:
OK, now where was this the helicopters fault? The man was flying a kit
helicopter he built that didn't have the up-to-date mandatory upgrades,
he had the wrong jetting and he modified a sensitive part of the
airframe that directly allows proper entrance into an autorotation, and
he did not enter a proper autorotation after the engine quit, if he even
could after the modification. The FAA determined that it was pilot
error, who could disagree?
I hope this clears up any misconceptions from inadequate posting of
partial information.
Dennis Fetters
Old June 16th 04, 06:36 PM
Dennis Fetters
C.D.Damron wrote:
Fetters wrote:
Your answers are well rehearsed.
But true answers. What more would you want? Isn't that what really
matters? Is the facts so hard to swallow? Why do you feel the need to
imply something else?
I'll summarize:
1) Accident reports conclude pilot error, Fetters is not responsible.
2) Builders did not comply with build instructions or AD's, Fetters is not
responsible.
Don't come here for a Baptism, Fetters, you won't get it. A few of us know
the truth.
Nor do I want it from you or anyone else here. Honestly, you don't
deserve to give it. I know the truth, that's all that matters.
A few of you say you know the truth? Well, what is that? Was this last
accident talked about without the full facts the "truth" you say you
know about? The real truth is that there still has been no deaths in a
Mini-500 that was the fault of the design or flight characteristics. For
some reason you may not like that answer, but it is the truth!
I will adjust that statement. Now that there is no factory support, I do
fear that there will someday be accidents due to the lack of sustained
testing that occurred on a daily bases at the factory to stay ahead of
unforeseen problems, thus why we came out with a few AD's in the past.
That is why I recommend all Mini-500 activity be stopped.
Sincerely,
Dennis Fetters
Old June 16th 04, 06:41 PM
C.D.Damron
I'm not implying something else, I'm saying something else.
You parse words with the best of them. You pick and choose among the many
truths related to the record of your aircraft.
Old June 16th 04, 07:12 PM
Dennis Fetters
Pick and choose what? Truth is truth. Facts are facts. Please, please
show me what I omitted that would make what I said untrue or the fault
of the aircraft, in any case or crash. Please show me proof of your
accusation. Please prove yourself right. I sincerely invite you to do so.
The problem I just finished proving again was that some people here do
just what you accuse me of doing. They said a Mini crashed and implied
it was the fault of the aircraft. I showed that was wrong and nor some
of you are upset I did so, and I've done it time and time again, without
distorting or omitting any fact. Please prove otherwise.
Sincerely,
Dennis Fetters
Old June 16th 04, 10:29 PM
Matt Whiting
Really? Sounds like he is dead from not following the manufacturer's
recommendations. It is sad that he is dead, but stupidity can be fatal,
especially when it occurs in relation to aviation.
Matt
Old June 16th 04, 11:11 PM
Rich
Dennis Fetters wrote in message m...
The truth is it's really stupid to design, sell, or fly a helicopter
powered by a small 2-stroke engine.
Anyone dumb enough to fly it kills only themselves.
Anyone dumb enough to design and sell them should feel somewhat
responsible for those who die in them.
Rich
Old June 16th 04, 11:32 PM
Dennis Fetters
Rich
Why? the trouble has never been that one of our Rotax powered engines
quit because it failed from over excursion. Not one Rotax in a Mini-500
failed from the engine wearing out, ever. The only failures that ever
occurred was from failure to jet the engine according to instructions,
using poor fuel below 86 octane, or running out of fuel, or improper
coolant mix or leak, but never the fault of the engine. Nothing beats
the power to weight of a 2-stroke and the ease of maintenance. It was
the right engine.
So where is this the fault of the designer or the aircraft? It was made
plan in instructions, AD's and advisories not to make these mistakes. We
flew the factory helicopters hundreds of hours to prove the design
worked. Sure there were some development problems, but each one was
solved and made available. The truth is that the engine worked well.
Like it or not, your comments are unfounded, uninformed, based on lack
of experience and unappreciated.
Dennis Fetters
Old June 17th 04, 12:41 AM
Blueskies
"Matt Whiting" wrote in message ...
Matt
I think we all need to blame gravity, or maybe the earth, or maybe the adventurous spirit of man. He chose to do what he
did. Freedom is a wonderful thing. It does have its responsibilities though. Ignorance can be bliss, and it can kill
you.
Dan D.
http://www.ameritech.net/users/ddevillers/start.html
Old June 17th 04, 03:16 AM
Kyle Boatright
Rich
the right engine.
Dennis Fetters
Dennis,
Your statement "the trouble has never been that one of our Rotax powered
engines quit because it failed from over excursion (sic)" may be correct,
but I doubt that you have the tear-down reports and expert knowledge to
*prove* the claim. To me, the bigger issue is the one Rich alluded to - 2
stroke engines are notoriously unreliable compared to their 4 stroke
cousins. ALL of the ultralight guys I know with more than a couple of
hundred hours behind 2 strokes have suffered engine events. Seized engines,
partially seized engines, exhaust failures that lead to power loss, etc.
Because of the reliability issue, 2 stroke engines are simply not suitable
for helicopter power plants. You know that, as does anyone else who is
familiar with the history of 2 stroke engines.
Now, if you wanted to build and fly your own 2 stroke powered heli, that's
fine, but kitting the thing and selling it to the dumb masses just isn't
right. Presumably, the target buyer for a 2 stroke powered kit helicopter
is either a big-time risk taker or is simply ignorant of the risks involved.
KB
Old June 17th 04, 04:28 AM
Rich
Rotax Operators Manual, page 4-2 "Warning: This engine, by its design,
is subject to sudden stoppage".
Evidently, you didn't read that far.
Rich
Mini Fly-In Drachten (EHDR) 5-6-7 juni Zier en van de Steenoven Home Built 0 May 28th 04 01:14 AM
fetters or fetter's booster? Cy Galley Home Built 11 March 12th 04 10:46 PM
Mini Imp Randall Robertson Home Built 0 November 25th 03 12:17 AM
mini copter strikes again tim Home Built 4 November 21st 03 12:47 AM
