I've come across some thin (0.008 inches), flexible solar panels that
look like they'd be ideal for gliders. These are the PowerFilm 7.2V 100mA ($30) units, with and without adhesive on the back: http://store.sundancesolar.com/pow72v100maf1.html So, $120 would buy me 4 panels, which would give me 200 ma at 15+ volts, almost enough keep up with my panel (including the transponder) over a full day. By "full day", I'm including the time it's tied out, as it would be at a soaring camp or on a safari, and a five hour flight. Has anyone used these, or know anything about them? Are there any better units than these? I'm aware of the Strobl units from Germany, but they are about twice the cost per amp. -- !Replace DECIMAL.POINT in my e-mail address with just a . to reply directly Eric Greenwell Richland, WA (USA) |
"Eric Greenwell" wrote in message .. . Has anyone used these, or know anything about them? Are there any better units than these? I'm aware of the Strobl units from Germany, but they are about twice the cost per amp. No, I don't know anything about those particular panels, I just want to point out that even with only 200 ma of charge, you will need a charge controller or you risk cooking your battery. Last time I checked, they were a $29.00 item. I ruined several batteries before I learned. Vaughn |
Hi,
I have used flexible solar panel fot 14 seasons. Voltage never drop below 12 volts with one battery 12v 7 amps even after 6-7 hour with all electrics on. Specs a Open circuit voltage 18V Short circuit current 200 m.a, charging 12v 160 m.a., 14v 140 m.a. Max power 3 watts and diode protected prevent flow-back. dept is .5 inch ( today they are thinner) and 10X10 inches on top of my solar panel. Flex to 60 degrees max. I run a L-nav, garmin gps and Microair radio and logger. Regards, Gilles "Vaughn" wrote in message ... "Eric Greenwell" wrote in message .. . Has anyone used these, or know anything about them? Are there any better units than these? I'm aware of the Strobl units from Germany, but they are about twice the cost per amp. No, I don't know anything about those particular panels, I just want to point out that even with only 200 ma of charge, you will need a charge controller or you risk cooking your battery. Last time I checked, they were a $29.00 item. I ruined several batteries before I learned. Vaughn |
Hi,
I have heard that solar panels are rated a bit optimistically (like glider polars). So you may not get as much current as you think you will. But it does sound nice and worth investigating. Let us know how it works for you. Paul Remde "Eric Greenwell" wrote in message .. . I've come across some thin (0.008 inches), flexible solar panels that look like they'd be ideal for gliders. These are the PowerFilm 7.2V 100mA ($30) units, with and without adhesive on the back: http://store.sundancesolar.com/pow72v100maf1.html So, $120 would buy me 4 panels, which would give me 200 ma at 15+ volts, almost enough keep up with my panel (including the transponder) over a full day. By "full day", I'm including the time it's tied out, as it would be at a soaring camp or on a safari, and a five hour flight. Has anyone used these, or know anything about them? Are there any better units than these? I'm aware of the Strobl units from Germany, but they are about twice the cost per amp. -- !Replace DECIMAL.POINT in my e-mail address with just a . to reply directly Eric Greenwell Richland, WA (USA) |
"Paul Remde" wrote in message news:QEpsb.182087$e01.657569@attbi_s02... Hi, I have heard that solar panels are rated a bit optimistically (like glider polars). So you may not get as much current as you think you will. Sometimes the current rating given is into a short circuit, so you get substantially less in practice. I'm sure these particular ratings are for the panel laid flat, pointing directly into the sun, with no cloud cover. Wrapped on a fuselage, frequently pointing away from the sun, the average will be a whole lot less. But it does sound nice and worth investigating. Let us know how it works for you. Paul Remde "Eric Greenwell" wrote in message .. . I've come across some thin (0.008 inches), flexible solar panels that look like they'd be ideal for gliders. These are the PowerFilm 7.2V 100mA ($30) units, with and without adhesive on the back: http://store.sundancesolar.com/pow72v100maf1.html So, $120 would buy me 4 panels, which would give me 200 ma at 15+ volts, almost enough keep up with my panel (including the transponder) over a full day. By "full day", I'm including the time it's tied out, as it would be at a soaring camp or on a safari, and a five hour flight. A full panel these days (with an active transponder) easily draws over 2 amps. The current you'll actually get out of the solar panel would not make a significant difference. You'd be more likely to notice the additional drag due to the turbulence than you would notice a benefit in the electricals. If 36 AH of batteries (with a generator on your engine) isn't enough, you've got other problems. Dave Has anyone used these, or know anything about them? Are there any better units than these? I'm aware of the Strobl units from Germany, but they are about twice the cost per amp. -- !Replace DECIMAL.POINT in my e-mail address with just a . to reply directly Eric Greenwell Richland, WA (USA) |
A full panel these days (with an active transponder) easily draws over 2 amps. The current you'll actually get out of the solar panel would not make a significant difference. You'd be more likely to notice the additional drag due to the turbulence than you would notice a benefit in the electricals. If 36 AH of batteries (with a generator on your engine) isn't enough, you've got other problems. Dave Is that the generator attached to the spare bike pedals for something to do when the pilot gets bored? 8-) But more seriously, would the material of the canopy absorb the frequencies used by the solar panel - if not, would there be a problem with mounting the panel inside the 'glass'. Even mounted outside, I suspect that the joint around the canopy would cause sufficient turbulent layer that the extra 'roughness' would not be noticeable, if the panel were to be mounted behind the canopy. Keith |
Keith W wrote:
But more seriously, would the material of the canopy absorb the frequencies used by the solar panel - if not, would there be a problem with mounting the panel inside the 'glass'. I don't think it is significant, but these particular panels don't have any specifications that would let you know. The Strobl panels the German factories supply on their gliders seem to have the similar ratings when used under a canopy. Even mounted outside, I suspect that the joint around the canopy would cause sufficient turbulent layer that the extra 'roughness' would not be noticeable, if the panel were to be mounted behind the canopy. These panels are attractive in part because they are very thin (0.008 inches), about the same as wing tape. I"d put them on the engine doors where the boundary layer is quite thick, but even behind the canopy might be in a thick enough layer. The further back from the canopy, the less drag. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
David Kinsell wrote:
Sometimes the current rating given is into a short circuit, so you get substantially less in practice. I'm sure these particular ratings are for the panel laid flat, pointing directly into the sun, with no cloud cover. Wrapped on a fuselage, frequently pointing away from the sun, the average will be a whole lot less. These panels are rated at the "maximum power" point; the short circuit current is higher, of course. In any case, the average will be as you point out. So, $120 would buy me 4 panels, which would give me 200 ma at 15+ volts, almost enough keep up with my panel (including the transponder) over a full day. By "full day", I'm including the time it's tied out, as it would be at a soaring camp or on a safari, and a five hour flight. A full panel these days (with an active transponder) easily draws over 2 amps. My panel is not so full, apparently, with a radio, 302 vario/recorder, Aero 1530 PDA, Becker transponder, as it draws about 650 ma while flying (radio on, but not receiving or transmitting; transponder on mode C). This will go up next year if I switch to an Ipaq PDA. The current you'll actually get out of the solar panel would not make a significant difference. The $/ma was good enough, that trying a 200 ma set would give me a good idea of their value, and more could be easily added. The engine doors would hold over an amp's worth. You'd be more likely to notice the additional drag due to the turbulence than you would notice a benefit in the electricals. At 0.008" thick (slightly thicker than wing tape), and placed on the engine doors, I wouldn't expect any extra drag. If 36 AH of batteries (with a generator on your engine) isn't enough, you've got other problems. It's enough for probably 3 typical flights (5-6 hours) with new batteries. The generator doesn't charge at a very high rate, and for the typical 6-8 minute launch, does little more than replace the starting draw. I would go longer if a charge was needed, but it's much more pleasant with the engine off! -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
At 15:12 12 November 2003, G.A. Seguin wrote:
Hi, I have used flexible solar panel fot 14 seasons. Voltage never drop below 12 volts with one battery 12v 7 amps even after 6-7 hour with all electrics on. Specs a Open circuit voltage 18V Short circuit current 200 m.a, charging 12v 160 m.a., 14v 140 m.a. Max power 3 watts and diode protected prevent flow-back. dept is wrote in message news:... 'Eric Greenwell' wrote in message .. . Has anyone used these, or know anything about them? Are there any better units than these? I'm aware of the Strobl units from Germany, but they are about twice the cost per amp. No, I don't know anything about those particular panels, I just want to point out that even with only 200 ma of charge, you will need a charge controller or you risk cooking your battery. Last time I checked, they were a $29.00 item. I ruined several batteries before I learned. Vaughn Howzabout some particulars? |
| Thread Tools | |
| Display Modes | |
