looking for a set of ASW 19 ailerons
Old February 25th 17, 03:45 AM posted to rec.aviation.soaring
[email protected][_1_]
Default looking for a set of ASW 19 ailerons
None in my barn, unfortunately.
The probable cause of the deformation is the hydroscopi nature of Kevlar. Does the -19 live a humid place?
Old February 25th 17, 04:04 AM posted to rec.aviation.soaring
Kerry Kirby
About the same humidity as PA. and it lives in a well ventilated dry trailer with a solar vent. I am not sure where it lived when it may have first developed the deformations though.
Kerry
Old February 25th 17, 05:21 AM posted to rec.aviation.soaring
I wonder what would happen if you treat it like a dent in a wing skin? Careful application of heat (from a heat gun) to the low spots.
May not do much since there is no foam layer.
If the aileron is considered scrap at this point, may be worth a shot.
Old February 25th 17, 01:11 PM posted to rec.aviation.soaring
No Kevlar in '19 ailerons.
Might possibly have in storage but would have to look next time I'm there.
UH
Old February 25th 17, 03:16 PM posted to rec.aviation.soaring
Dan Marotta
I just spoke with Fidel. He does not have any ailerons for a '19. He
said that, based upon your description, he could repair them but it
would be expensive, though not as expensive as building a new set. Of
course, he would have to see them before he could make a cost estimate.
Good luck in your endeavor - the '19 is a great flying ship.
On 2/24/2017 5:52 PM, wrote:
Your first step is probably to quantify the condition yours are in. From your description they sound pretty bad, but you probably ought to do a rigorous survey of the dips and sags to find how deep the worst ones really are. That way you know what you really have.
Your next step may be to contact the factory and see if they have any leftovers, or perhaps damaged ones from a factory repair. Ailerons that have been broken cleanly are probably easier to fix than the ones you describe.
You should probably also call all the Usual Suspects to see what they have in the rafters:
Eds Hollestelle (Solaire Canada)
Eastern Sailplane
JJ Sinclair
Williams Soaring
Robert Mudd in Moriarty
Fidel in Moriarty
Mark Grubb in Tehachapi
If worst comes to worst, I can show you how to make them; that is allowed here in the US under 14CFR§21.9(a)5, and may be allowed under similar Canadian rules. Basically, we'd take your existing ailerons, profile and paint them so they are nice and pretty, then make a set of splash molds off of those. Then you'd make replacements in the molds. Ideally we'd get the factory lamination plan from Schleicher, otherwise you'd have to tear apart your existing parts to figure out what's on the inside.
Thanks, Bob K.
Dan, 5J
Old March 3rd 17, 01:17 PM posted to rec.aviation.soaring
Hey Kerry, "Glider is in Canada but we would be happy if we found a set in the Artic."
Sooooo, in Canada then?
Old March 3rd 17, 02:28 PM posted to rec.aviation.soaring
Good luck getting a Canadian inspector to allow use of a component that doesn't have paperwork showing complete history including total hours. I had a repaired rudder for a G-102 that I yellow tagged.................not good enough, because I couldn't prove the total hours on the rudder.
BTW, I got the rudder from the Vancover Soaring Club.................buyers?..........the Vancover Soaring Club!
JJ
Old March 3rd 17, 06:47 PM posted to rec.aviation.soaring
UH
Checked the storage spot. No ailerons for '19
UH
Old March 4th 17, 06:18 AM posted to rec.aviation.soaring
JJ
Yeah JJ - I'm still sorry for wasting your time on that one but the only AMO we had to work with at the time just wouldn't let it "fly" sadly. We ended up having to wait for (and pay for) a new one from Lindner in the end.
Old March 4th 17, 02:02 PM posted to rec.aviation.soaring
Yeah, we got some NAZI inspectors down here, too!
BTW, don't believe I mentioned it, but just because a ship is "totaled", by the insurance company, doesn't mean it is "destroyed". Someone in your club told Transport Canada that the G-102 was "destroyed" and they De-registered it. I had to write to Transport Canada ant tell them it the ship wasn't "destroyed", it was only flown through a fence and in fact it had been imported to the US. Requested they tell our FAA about all this. Needless to say, this all took some time, but everything was straightened out by the time I got it back together.
Cheers,
JJ
LS4 Ailerons HL Falbaum Soaring 0 February 18th 07 02:18 PM
spoilers vs. ailerons [email protected] Piloting 36 August 8th 05 11:24 AM
A-330 ailerons M General Aviation 20 March 17th 05 12:56 AM
WTB -Bonanza Ailerons HankL Aviation Marketplace 1 April 28th 04 03:28 AM
Ailerons on Laser Kelvin & Janice Rempel Aerobatics 0 October 26th 03 11:13 AM
