Will circular runways ever take off?
Old March 23rd 17, 12:40 AM posted to rec.aviation.soaring
JS
Default Will circular runways ever take off?
On Wednesday, March 22, 2017 at 4:53:51 PM UTC-7, Frank Whiteley wrote:
On Wednesday, March 22, 2017 at 11:24:42 AM UTC-6, wrote:
On Thursday, March 16, 2017 at 11:18:32 AM UTC-7, wrote:
I saw this story and it reminded me, has anyone ever tried landing on a curved flat road or something similar to a circular runway?
I supposed the banked sides of this concept help.
BBC story "Will circular runways ever take off?"
http://www.bbc.com/news/magazine-39284294
http://www.endlessrunway-project.eu/project/index.php
SAE paper Flight Operations on a Circular Runway
http://papers.sae.org/660283/
Abstract:
Inherent advantages of an infinitely long runway, optimum technical location at the center of the circle, and safety enhancement by increased directional stability during aircraft ground roll generated interest in the circular runway concept. The Bureau of Naval Weapons originated a project to determine, within the realm of aircraft behavior, the feasibility of flight operations from a circular runway.Utilizing an existing circular track at the General Motors Proving Ground near Mesa, Arizona, tests were conducted with a T28, an A1-E, an A4-B, and a C54. It was determined that pilots readily adapt to operations from a circular runway, that aircraft lateral and directional stability is more positive than on a flat runway, that tangential approaches are no more difficult than approaches to a straight runway, and that low visibility approaches are much simpler than to a straight runway. Flight operations from a circular runway are feasible.
Chris
This might be a good idea for auto towing. We have 2800 ft of straight runway at our gliderport. At 780 ft field elevation with a tow vehicle like a V-8 Chevy Suburban or a V-8 pickup truck, we can get a maximum of about 800ft AGL auto towing a 1-26, and maybe 475ft AGL auto towing a 2-33 with two people in it. Except for the problem of the wind causing a portion of the circle to be towing the glider downwind, a circular runway would seem to be a good way to extend the runway length indefinitely, and get more altitude for a given rope length.
Reverse pulley is what you need.
http://www.coloradosoaring.org/think...ey/default.htm
Isn't the circular runway standard float plane technique on small lakes?
Old March 24th 17, 06:31 AM posted to rec.aviation.soaring
Gert Bass
This can actually be done on any normal glider field in the form of
towing up an down the runway. The towcar doesn't have a very big turning
radius, so no need for even a large (wide) field. And the glider is
already in the air when the towcar reaches the end of the field and can
make a much larger turn - kind of a teardrop reversal. The towcar can
also slow down a lot for the turn because the glider slingshots around
it. Like a waterskier who overtakes the boat turning.
This can be done several times back and forth and if the tow cable can
be lengthened/reeled out it could reach much higher altitudes than with
a winch launch. But it's rather crazy and a bit like below - better one
good straight setup unless you have a really loong field.
Of course very safe on a circular track if available
Yea theoretically it is always discussed and for helos in confined areas
as well. In practice I find it doesn't work.
When do you need it? When you are loaded heavy. That means you use full
power to barely start climbing. The turning actually does use up that
little extra power every time I experimented with it - because you bank
quite a bit as space is tight. So setting up the departure in the
longest straight line possible has always been just as good if not
better and looks a lot more sane
Now, turning slightly into wind or to go over the lowest trees that are
off the straight departure is standard, but is far from spiralling
Old March 26th 17, 05:19 AM posted to rec.aviation.soaring
Regarding the up and down the runway multiple pass auto tow, with the turn around at the runway ends: Have you actually done it, or do you know anyone who has?
Our runway is dirt and is quite wide, at least 200 ft. so a turn around might be possible without slowing the tow car too much. We also have two shorter, narrower runways that meet together and also with the main runway ends, forming a triangle. Not an equilateral triangle, but fairly close to it. I'm wondering if this triangular circuit could be used to make multiple laps around the circuit on auto tow. One thing I thought of is that instead of a payout winch to let out more line, you could just start out with more line laid out in the first place in order to get higher. However, the trade - off with that idea would seem to be that the tow car would be further down the runway at the start of the tow, so the glider would not get as high by the end of the first runway run as you would with less line out at the beginning of a one leg straight auto tow. So the glider would have to make the first turn around(s) at lower altitude that can be reached with one straight run. Hopefully with each pass, you could eventually get higher than the single pass run. We found by trial and error that about 1100 ft of rope seems to work out for the highest auto tows in still air on our 2800 ft. runway on one pass straight ahead auto tows with our 1-26 and 2-33. We have also towed a DG-100 using the same length rope and tow vehicle. The DG was able to get about 150 ft higher than the 1-26, probably due to better, aerodynamic efficiency.
Not a float plane pilot, but I read somewhere that float planes also taxi around on the water in different directions when it's glassy in order to make wakes that allow the floats to break the surface tension on take off and get the plane airborne easier?
Old March 26th 17, 05:22 AM posted to rec.aviation.soaring
Abstract:
Chris
Thanks for the link. It looks like another interesting approach!
Old March 26th 17, 05:35 AM posted to rec.aviation.soaring
Here is another interesting variation on the theme. Hang glider pilots have utilized the "step tow" method to gain higher altitudes when using a pay-out winch. Here is an example: https://www.youtube.com/watch?v=q1d0Jc-EfJ8
RC
Old March 26th 17, 11:35 AM posted to rec.aviation.soaring
The historical evidence, i.e. back issues of Soaring Magazine, indicate that death of the pilot is the reason the practice of reversing an auto tow is not recommended nor endorsed. You have to go back to the '30's and 40's but there are graphic warnings in the letters to the editor. I learned on a winch in the '70's and even the practice of "kiting out the wire" is fraught with potential disruptions and anomalies. Entanglement of the aircraft is probably the chief bugaboo, and I might hazard a guess that with the lighter weight high-strength lines available now, it will be an even greater risk.. 1/8 inch steel has a lot less aerodynamic potential than the "spectra" used for its high tow potential.
Two of my dear friends (both having been instructors and nationally rated pilots), aerotowing a 2-33 in the 80's related how in turbulence the tug surged forward then slowed enough that the rope came back in a loop, wound around the wing and they were only able to extricate themselves by "ruddering" out of the loop a moment before it snapped shut.The rope/wire glider combination has to be kept straight at all times.
Old March 26th 17, 03:57 PM posted to rec.aviation.soaring
No
Old April 5th 17, 03:01 PM posted to rec.aviation.soaring
A curved runway idea!!! What a LAUGH!!
Posted by an email name "Green Eggs and Ham"
Do you like
Curved runways to land?
I do not like them,
Sam-I-am.
I do not like
Curved runways to land!
Would you like them
Here or there?
I would not like them
here or there.
anywhere.
  #29
Old April 6th 17, 07:12 AM posted to rec.aviation.soaring
Bret Hess
I can still remember how mercury feels in the
When are thermals not circular and do thermal helpers assume thatthey are? son_of_flubber Soaring 65 August 20th 13 11:48 PM
Circular runways for airports? Larry Dighera Piloting 15 December 27th 06 12:24 AM
Circular Aircraft Hangar Jeff Home Built 16 October 8th 05 11:44 PM
dedTUNIA: Gegen kreisrunden Haarausfall - Against circular loss of hair - Contre Alopécie Areata Greasy Rider Naval Aviation 0 June 10th 05 12:51 PM
Circular Runway jsmith Piloting 55 April 11th 04 10:22 AM
