The local FSDO has this form they want submitted before scheduling an
inspection. It asks for (1) "Net empty C.G. range" and (2) "Loaded C.G. limits". Now I know that my C.G. has to fall within 15-28% of chord, and I can easily figure that out. It works out to 77.95 to 84.84 inches aft of datum. This is what I would think is the "Loaded C.G. limits". My empty C.G. is 78.48 which is within the limits. But what the hell is: "Net empty C.G. range"? -Confuzed |
On Wed, 23 Jun 2004 03:13:20 GMT, "Dale Larsen"
wrote: The local FSDO has this form they want submitted before scheduling an inspection. It asks for (1) "Net empty C.G. range" and (2) "Loaded C.G. limits". Now I know that my C.G. has to fall within 15-28% of chord, and I can easily figure that out. It works out to 77.95 to 84.84 inches aft of datum. This is what I would think is the "Loaded C.G. limits". My empty C.G. is 78.48 which is within the limits. But what the hell is: "Net empty C.G. range"? -Confuzed I think you've got it right. have you got a removable fuel tank? the auster has a number of empty weights. belly tank on/off metal/wood prop (involves additional tail ballast for the metal prop) exhaust manifold and rear facing pipe. (involves additional tail ballast as well) may explain it. Stealth Pilot Australia |
That explains it! It most likely does not apply to my aircraft, since I
only have one configuration and one empty weight. Thanks for your help. Dale "Stealth Pilot" wrote in message ... On Wed, 23 Jun 2004 03:13:20 GMT, "Dale Larsen" wrote: The local FSDO has this form they want submitted before scheduling an inspection. It asks for (1) "Net empty C.G. range" and (2) "Loaded C.G. limits". Now I know that my C.G. has to fall within 15-28% of chord, and I can easily figure that out. It works out to 77.95 to 84.84 inches aft of datum. This is what I would think is the "Loaded C.G. limits". My empty C.G. is 78.48 which is within the limits. But what the hell is: "Net empty C.G. range"? -Confuzed I think you've got it right. have you got a removable fuel tank? the auster has a number of empty weights. belly tank on/off metal/wood prop (involves additional tail ballast for the metal prop) exhaust manifold and rear facing pipe. (involves additional tail ballast as well) may explain it. Stealth Pilot Australia |
| Thread Tools | |
| Display Modes | |
| Why 4130 tube? | Leon McAtee | Home Built | 31 | March 28th 04 04:04 PM |
| Pitts S-1 weight and balance | wallyairplanefan | Aerobatics | 2 | March 6th 04 05:09 AM |
| RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 05:08 AM |
| Rebuilding my KR-2 | Forrest | Home Built | 10 | December 9th 03 05:09 AM |
