A lousy end to what was a beautiful day of soaring, thanks to the USMC
and my own lack of vigilance. Yesterday a cold front was bearing down on Phoenix. While in other parts of the country this makes for winter worries, here the front is a small band of cumulus and a very slight chance of virga. The higher elevations might see some precipitation. The weather was still great, it was 3 pm and I was climbing in decent lift with another glider at the southern end of the Sierra Estrellas-a 15 mile ridge line southwest of KPHX. I heard it first. The sound was of a jet close by. The visibility in the front seat of the Burkhard Grob G103 is excellent, but I could see nothing. Still the sound, but no airplane. Then, from behind a flight of two Harriers flew directly between both gliders and slightly above heading east. As I was at 5500 MSL, and the floor of the Class B wedge just to the east of my position was 6000 MSL, I would guess that the jets were close to but under 6000. The encounter lasted all of 10-15 seconds. I have no idea if they were IFR, nor if they could, should or did comply with the 200 KIAS speed limit under the shelf of the class B. I also have no idea whether either I or the other glider was seen by the lead. After the encounter, I lost my enthusiasm for the flight along with the thermal and worked my way back to the sailport. When I fly with students in this area, I hammer the idea that our piece of the sky is busy due to the natural and man-created boundaries which will force through traffic to overfly our thermal hunting area. So I received yet another reminder that I cannot see everything even part of the time. Were one of the Harriers and me to collide does anyone think that the TV would have the blame anywhere other than me? Let's be careful out there. I think I am, but again I got another chance. Terry Claussen |
It sounds like a scary 10-15 seconds! I know the feeling: I too have had
close encounters with jets. I've been closer than I would have liked to 737's, F-117's, and a B1-b with its wings fully swept back flying Nap-of-the-Earth. With one 737, I saw its shadow flying directly at mine, but it took several seconds for me to find it. The other 737 was pointed out to me by the Approach controller, but neither of us saw each other. The flight of F-117's I'm sure saw me, for they came up from behind and on my right, and overtook me on a parallel course. They got my heart pounding though! But it was the B1-B about 1,000 feet below flying at nearly the speed of sound that scared the bejeezers out of me! Yes, keep your eyes outside 99% of the time. Feel for the lift, listen to the audio vario, and look outside. Not only does this help keep aluminum off of fiberglass, but it improves your piloting technique as well. A couple of points about the Harriers you encountered though: 1.) They may or may not have been in contact with ATC, and even if they were, there would be no separation requirements between them and you. 2.) Military aircraft do not have the 200 knot limitation under the Class B airspace. 3.) Jet pilots tend not to look outside of the cockpit nearly as much as we do, and even if they did, it would be extremely difficult for them to see us. There was a video made of a near-miss a couple of years ago between an F-16 and a Cessna 172. The footage was from the Heads-Up Display (HUD) of the F-16. They missed by 15 feet, and you had to play the video in slow motion to even see the Cessna. I know those points don't give us a warm and fuzzy feeling, but that's the world we live in. The best advice that I have is to either avoid the areas of high risk, communicate with the controlling agency, or work from within the system to keep the aircraft apart from each other through a Letter of Agreement (LOA). Fly safe, Chris Fleming, 'L9' ATP B-767, CFI-G "Terry Claussen" wrote in message ... I have no idea if they were IFR, nor if they could, should or did comply with the 200 KIAS speed limit under the shelf of the class B. I also have no idea whether either I or the other glider was seen by the lead. After the encounter, I lost my enthusiasm for the flight along with the thermal and worked my way back to the sailport. When I fly with students in this area, I hammer the idea that our piece of the sky is busy due to the natural and man-created boundaries which will force through traffic to overfly our thermal hunting area. So I received yet another reminder that I cannot see everything even part of the time. Were one of the Harriers and me to collide does anyone think that the TV would have the blame anywhere other than me? Let's be careful out there. I think I am, but again I got another chance. Terry Claussen |
be interesting to know where you where when you saw the B-1...
do you know if there were any IR or VR routes in your area? or were you inside a MOA and trust me.. when down low and fast.. two sets of eyes are looking outside and forward.. BT "C.Fleming" wrote in message ... It sounds like a scary 10-15 seconds! I know the feeling: I too have had close encounters with jets. I've been closer than I would have liked to 737's, F-117's, and a B1-b with its wings fully swept back flying Nap-of-the-Earth. With one 737, I saw its shadow flying directly at mine, but it took several seconds for me to find it. The other 737 was pointed out to me by the Approach controller, but neither of us saw each other. The flight of F-117's I'm sure saw me, for they came up from behind and on my right, and overtook me on a parallel course. They got my heart pounding though! But it was the B1-B about 1,000 feet below flying at nearly the speed of sound that scared the bejeezers out of me! Yes, keep your eyes outside 99% of the time. Feel for the lift, listen to the audio vario, and look outside. Not only does this help keep aluminum off of fiberglass, but it improves your piloting technique as well. A couple of points about the Harriers you encountered though: 1.) They may or may not have been in contact with ATC, and even if they were, there would be no separation requirements between them and you. 2.) Military aircraft do not have the 200 knot limitation under the Class B airspace. 3.) Jet pilots tend not to look outside of the cockpit nearly as much as we do, and even if they did, it would be extremely difficult for them to see us. There was a video made of a near-miss a couple of years ago between an F-16 and a Cessna 172. The footage was from the Heads-Up Display (HUD) of the F-16. They missed by 15 feet, and you had to play the video in slow motion to even see the Cessna. I know those points don't give us a warm and fuzzy feeling, but that's the world we live in. The best advice that I have is to either avoid the areas of high risk, communicate with the controlling agency, or work from within the system to keep the aircraft apart from each other through a Letter of Agreement (LOA). Fly safe, Chris Fleming, 'L9' ATP B-767, CFI-G "Terry Claussen" wrote in message ... I have no idea if they were IFR, nor if they could, should or did comply with the 200 KIAS speed limit under the shelf of the class B. I also have no idea whether either I or the other glider was seen by the lead. After the encounter, I lost my enthusiasm for the flight along with the thermal and worked my way back to the sailport. When I fly with students in this area, I hammer the idea that our piece of the sky is busy due to the natural and man-created boundaries which will force through traffic to overfly our thermal hunting area. So I received yet another reminder that I cannot see everything even part of the time. Were one of the Harriers and me to collide does anyone think that the TV would have the blame anywhere other than me? Let's be careful out there. I think I am, but again I got another chance. Terry Claussen |
Yeah, I have a published 10nm-wide IR route nearby. It extends from 500 ft
AGL to 7,000 ft MSL. Whenever I head out on cross-countries, I get their status, and plan accordingly. I've seen F-16's and F-117's mostly, but it was the big B1-b that snuck up on me! I try to transit the route as close to 90 degrees and as rapidly as possible. The time with the B1-b had me hit some serious sink 10 minutes before, and I had to thermal in the area; which I never do! The terrain is very rugged (canyons, mountains, and rolling sand dunes), so I have to stay high, usually above 10,000 ft. Chris Fleming, 'L9' El Paso, Texas "BTIZ" wrote in message news:wBETb.7074$IF1.1160@fed1read01... be interesting to know where you where when you saw the B-1... do you know if there were any IR or VR routes in your area? or were you inside a MOA and trust me.. when down low and fast.. two sets of eyes are looking outside and forward.. BT |
"Terry Claussen" wrote in message ... A lousy end to what was a beautiful day of soaring, thanks to the USMC and my own lack of vigilance. Not sure any reasonable amount of vigilance on your part could be counted on to avoid a high speed jet from nailing you from behind when you're running straight in a glider (or other small GA aircraft). I've seen a couple of fighters pass right close behind another Stemme 1/4 mile ahead of me. Asked if he'd seen them, he of course hadn't. I suspect, or at least hope, as in your case too, that the fighters had us and were just doing an exhuberant buzz job. In any case, not very prudent or responsible of them. I fly with a transponder and that has to be a help. I've got a ProxAlert R5 on order (www.proxalert.com), so if they're squawking, I'll have their altitude, range and squawk code too. If their altitude is the same as mine, with rapidly decreasing range, and I don't have joy on 'em, then like a raptor approached by a power plane, they'll get to watch me do a wingover and rather steep spoiler descent. all the best, -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." |
bumper wrote:
"Terry Claussen" wrote in message ... A lousy end to what was a beautiful day of soaring, thanks to the USMC and my own lack of vigilance. Not sure any reasonable amount of vigilance on your part could be counted on to avoid a high speed jet from nailing you from behind when you're running straight in a glider (or other small GA aircraft). I've seen a couple of fighters pass right close behind another Stemme 1/4 mile ahead of me. Asked if he'd seen them, he of course hadn't. I suspect, or at least hope, as in your case too, that the fighters had us and were just doing an exhuberant buzz job. In any case, not very prudent or responsible of them. I fly with a transponder and that has to be a help. I've got a ProxAlert R5 on order (www.proxalert.com), so if they're squawking, I'll have their altitude, range and squawk code too. If their altitude is the same as mine, with rapidly decreasing range, and I don't have joy on 'em, then like a raptor approached by a power plane, they'll get to watch me do a wingover and rather steep spoiler descent. all the best, Bumper, I suspect you're right about the exuberance. But if not, if these guys are flying head down, shouldn't they have radar plenty capable of spotting a glider? Its not like Schempp-Hirth or DG make them intentionally stealthy or anything. Just Curious. Shawn |
Because you were above 5000MSL what was your pressure setting on altimeter,
standard? You mentioned cold front, low pressure? Are you sure about your altitude in standard setting? If fighters were at 6000 on standard setting and also you but because you were using MSL setting just didn't know that? These helps to understand (I hope) why you two were so close to each other and it is good to go through why this could happen. This sounds like I am blaming you, but I don't, as an outsider I am able to see also probably mistakes you have done. Ari |
Transition Altitude in the USA is 18,000 ft., his altimeter setting would
have been QNH, or feet above sea level. Chris Fleming "Ari Paija" wrote in message ... Because you were above 5000MSL what was your pressure setting on altimeter, standard? You mentioned cold front, low pressure? Are you sure about your altitude in standard setting? If fighters were at 6000 on standard setting and also you but because you were using MSL setting just didn't know that? These helps to understand (I hope) why you two were so close to each other and it is good to go through why this could happen. This sounds like I am blaming you, but I don't, as an outsider I am able to see also probably mistakes you have done. Ari |
... and my own lack of vigilance.
Yeah right, Terry! You might be the most vigilant pilot I've known in my brief soaring (but much longer aviation) career. You were in the back seat five of my first eight flights, two hours and eleven minutes if my logbook is correct, and I learned more in those five flights than I can recount with credibility, including a whole lot about vigilance that hopefully will stick with me. If this can happen to you, it can happen to Captain Safety. A heads-up for all of us. -ted p.s. thanks for the nice tow this afternoon. The two hours and twenty-five minutes aloft is my new personal best, and I couldn't even get it up! (Uh, the landing gear on the Pegasus that is. Everything else was clear blue fine...) |
| Thread Tools | |
| Display Modes | |
| Indiana National Guard pilot killed in midair collision | Otis Willie | Military Aviation | 0 | June 17th 04 09:08 PM |
| Aviation Consumer and Collision Avoidance | BHelman | Products | 52 | April 23rd 04 06:35 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| "China blamed in '01 air collision" | Mike Yared | Naval Aviation | 8 | September 15th 03 06:07 PM |
| "China blamed in '01 air collision" | Mike Yared | Military Aviation | 2 | September 14th 03 07:08 PM |
