Check out the SSA website for the complete info on this petition, and
consider commenting to the FAA (comments due by March 1, via web site, mail, fax, "eRulemaking portal"): SSA Transponder Petition Published By Dennis Wright Posted Thursday, February 19, 2004 The SSA petition asks that SSA members be allowed to operate transponder-equipped gliders with the transponders turned off, when the glider is being operated more than 40 nautical miles from the primary airport in Class B airspace and more than 20 nautical miles from the primary airport in Class C airspace. Currently, Federal Aviation Regulation 91.215[c] requires that all aircraft equipped with a transponder and operating in controlled airspace have the transponder on. ....more on the web site -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
This appeared out of the blue, at least to me. If
approved as it stands, it certainly would be an encouragement to install a transponder. But what is the SSA's position if the FAA comes back at some future date and says 'Yes, but now that you have pointed out that battery-operated transponders are available, there is no reason why ALL non-electric aircraft should not be REQUIRED to have a transponder installed' ? Like the part 103 ultralights, maybe it is best not to tamper with an existing favorable exemption. Ian At 18:48 21 February 2004, Eric Greenwell wrote: Check out the SSA website for the complete info on this petition, and consider commenting to the FAA (comments due by March 1, via web site, mail, fax, 'eRulemaking portal'): SSA Transponder Petition Published By Dennis Wright Posted Thursday, February 19, 2004 The SSA petition asks that SSA members be allowed to operate transponder-equipped gliders with the transponders turned off, when the glider is being operated more than 40 nautical miles from the primary airport in Class B airspace and more than 20 nautical miles from the primary airport in Class C airspace. Currently, Federal Aviation Regulation 91.215[c] requires that all aircraft equipped with a transponder and operating in controlled airspace have the transponder on. ....more on the web site -- ----- change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
I agree Ian... certainly opens a can-o-worms with the.. "if we are far
enough away can we turn it off, because we are exempt any way argument"... They keep it up and we'll be restricted to lower altitudes without a transponder. BT "Ian Cant" wrote in message ... This appeared out of the blue, at least to me. If approved as it stands, it certainly would be an encouragement to install a transponder. But what is the SSA's position if the FAA comes back at some future date and says 'Yes, but now that you have pointed out that battery-operated transponders are available, there is no reason why ALL non-electric aircraft should not be REQUIRED to have a transponder installed' ? Like the part 103 ultralights, maybe it is best not to tamper with an existing favorable exemption. Ian At 18:48 21 February 2004, Eric Greenwell wrote: Check out the SSA website for the complete info on this petition, and consider commenting to the FAA (comments due by March 1, via web site, mail, fax, 'eRulemaking portal'): SSA Transponder Petition Published By Dennis Wright Posted Thursday, February 19, 2004 The SSA petition asks that SSA members be allowed to operate transponder-equipped gliders with the transponders turned off, when the glider is being operated more than 40 nautical miles from the primary airport in Class B airspace and more than 20 nautical miles from the primary airport in Class C airspace. Currently, Federal Aviation Regulation 91.215[c] requires that all aircraft equipped with a transponder and operating in controlled airspace have the transponder on. ....more on the web site -- ----- change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
On 2/21/04 7:31 PM, in article ,
"Ian Cant" wrote: If approved as it stands, it certainly would be an encouragement to install a transponder. But what is the SSA's position if the FAA comes back at some future date and says 'Yes, but now that you have pointed out that battery-operated transponders are available, there is no reason why ALL non-electric aircraft should not be REQUIRED to have a transponder installed' ? ans: Now that battery-operated transponders are available, there is no reason why ALL non-electric aircraft should not be REQUIRED to have a transponder installed. Period. ----- Jack ----- |
you know..I sell transponders and have sold a lot of them to glider
owners....I have however been afraid from the start that once the FAA starts to recognize larger numbers of gliders with transponders it could come back to haunt us all...If we lose the exemption requiring transponders in gliders, and we might now that the FAA sees that they can indeed be operated from our battery power it could be just the straw that breaks the camels back...Soaring as a sport isn't growing even now in the US, adding more cost to owning and operating gliders surely will not help...to many clubs and many owners adding $2000+ to each and every glider plus the added expense to keep them certified and working will certainly take more club type and older gliders off line. Large number of these gliders still today do not even have radios installed. A large number of club gliders are still tied outside, still have no battery installed many don't even have audio variometers let alone radios, (I really do think all gliders should have at least a decent radio and audio variometer for basic safety reasons even at small out-of-the-way airports). I hear a lot of grumbling about near misses while flying in and around approaches to busy metro airports, while flying near military bases and so on.....the simple truth is, if this is happening and I'm sure it is, the answer is not in adding one more piece of electronics, the answer is in not flying in these busy corridors....doing so will eventually cause this airspace to be closed to all non-commercial aircraft and the eventual loss of this and other airspace where traffic is not a problem and before we all know it an end to soaring as we know it today in this country...Public opinion will outnumber the small number of pilots wishing to fly for fun. Let the evening news, 60 minutes or 20/20 run some special on the dangers glider pilots pose to airliners and every politician will support the public opinion polls and side with them to get votes.....the more we depend on electronics the more we are keeping our heads down in the cockpits...with GPS and pocket nav's to guide us, flight computers to calculate for us and transponders to shield (?) us we are also forgetting what we started doing this for to begin with....look outside, there is real beauty to be seen through the clear mecaplex that surrounds us....fly safe, but always fly for fun BTW, I also sell canopy cleaner, but sales of this are on a steady decline.. tim Now that battery-operated transponders are available, there is no reason why ALL non-electric aircraft should not be REQUIRED to have a transponder installed. Period. ----- Jack ----- |
Tim Mara wrote:
you know..I sell transponders and have sold a lot of them to glider owners....I have however been afraid from the start that once the FAA starts to recognize larger numbers of gliders with transponders it could come back to haunt us all...If we lose the exemption requiring transponders in gliders, and we might now that the FAA sees that they can indeed be operated from our battery power it could be just the straw that breaks the camels back First, this cat jumped out of the bag a couple of years ago: the FAA knows about the Becker, and Microair, and they'll know about the Filser and the others, as they become available. ....Soaring as a sport isn't growing even now in the US, adding more cost to owning and operating gliders surely will not help...to many clubs and many owners adding $2000+ to each and every glider plus the added expense to keep them certified and working will certainly take more club type and older gliders off line. Second, I've been told by my director that the FAA is not keen to burden the sport with another requirement; that they understand our situation. snip I hear a lot of grumbling about near misses while flying in and around approaches to busy metro airports, while flying near military bases and so on.....the simple truth is, if this is happening and I'm sure it is, the answer is not in adding one more piece of electronics, the answer is in not flying in these busy corridors. ...doing so will eventually cause this airspace to be closed to all non-commercial aircraft and the eventual loss of this and other airspace where traffic is not a problem These corridors also have general aviation airplanes flying in them, so we'd have a lot of allies if such restrictions were ever attempted. I think losing the use airspace just because transponder equipped gliders are flying in it is most unlikely. The idea that this could somehow lead to losing airspace for general avaiation in areas that AREN'T busy is incredible to me. and before we all know it an end to soaring as we know it today in this country...Public opinion will outnumber the small number of pilots wishing to fly for fun. Let the evening news, 60 minutes or 20/20 run some special on the dangers glider pilots pose to airliners and every politician will support the public opinion polls and side with them to get votes. These doomsday scenarios are so hard to predict, I don't think we should even try. Keep in mind that a there are a lot more general avaition airplanes than there are gliders, and they fly into these busy areas a lot more than we do, yet no one is suggesting they rip out their transponders and just fly in the rural areas. ....the more we depend on electronics the more we are keeping our heads down in the cockpits. Transponder use doesn't do this: turn it on when you turn on the radio, turn it off when you land. You don't look at it, you don't tune it, you don't listen to it. It's just there. ...with GPS and pocket nav's to guide us, flight computers to calculate for us and transponders to shield (?) us we are also forgetting what we started doing this for to begin with....look outside, there is real beauty to be seen through the clear mecaplex that surrounds us....fly safe, but always fly for fun These are worthy issues, but separate from transponders. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
"Eric Greenwell" wrote in message ... SNIP----- ....the more we depend on electronics the more we are keeping our heads down in the cockpits. SNIP------ Eric Greenwell Washington State USA Eric, I think you've been flying gliders as long as I have, but I must strongly disagree with the statement above. I remember flying cross country without a single electronic device - not even a radio. (A good retrieve crew had to know how to set the dwell and adjust the carburetor on a Chevy as well as how to outsmart the phone company with person-to-person, collect calls.) You can't argue that folding maps, scribbling notes on pads and working a "prayer wheel" trying to make navigation by pilotage work when spending half the time flying in tight circles is less distracting. Often you could add trying to get it a pellet vario unstuck at the same time. That was a serious "heads down" situation.(I still carry a well marked sectional and little notebook with all the important facts and numbers.) By comparison, grabbing a quick glance at a computer screen that tells me everything and them returning my gaze outside is vastly safer and easier. The only time "heads down" becomes a problem is when a pilot doesn't know how to work the electronics. The present problem is pilots trying to learn to use avionics in the air instead of on the ground. (A good season prep: go sit in your glider for a couple of hours reading manuals and pushing buttons.) Like it or not, ubiquitous computing is a part of everyday life - including gliding - and the "good 'ole days" weren't all that great. Bill Daniels |
I'd have to disagree about the predictability of airspace loss. It
was predictable when the FAA came into existance. So far, the predictions have been met or exceeded. The predicton is simple. If it is possible to use a rule to restrict those who now use the airspace, it will be used to restrict those who use the airspace. The second corollary is that all rules are restrictions in one form or another. I'm trying to think of an example where the opposite has happened. I can think of no airspace that was unavailable in the past and is now available. The trick is to decide when restrictions are really required. I contend that the airspace rules that were in effect in 1959 were just as safe as what we have now. In article , Eric Greenwell wrote: Tim Mara wrote: you know..I sell transponders and have sold a lot of them to glider owners....I have however been afraid from the start that once the FAA starts to recognize larger numbers of gliders with transponders it could come back to haunt us all...If we lose the exemption requiring transponders in gliders, and we might now that the FAA sees that they can indeed be operated from our battery power it could be just the straw that breaks the camels back First, this cat jumped out of the bag a couple of years ago: the FAA knows about the Becker, and Microair, and they'll know about the Filser and the others, as they become available. ....Soaring as a sport isn't growing even now in the US, adding more cost to owning and operating gliders surely will not help...to many clubs and many owners adding $2000+ to each and every glider plus the added expense to keep them certified and working will certainly take more club type and older gliders off line. Second, I've been told by my director that the FAA is not keen to burden the sport with another requirement; that they understand our situation. snip I hear a lot of grumbling about near misses while flying in and around approaches to busy metro airports, while flying near military bases and so on.....the simple truth is, if this is happening and I'm sure it is, the answer is not in adding one more piece of electronics, the answer is in not flying in these busy corridors. ...doing so will eventually cause this airspace to be closed to all non-commercial aircraft and the eventual loss of this and other airspace where traffic is not a problem These corridors also have general aviation airplanes flying in them, so we'd have a lot of allies if such restrictions were ever attempted. I think losing the use airspace just because transponder equipped gliders are flying in it is most unlikely. The idea that this could somehow lead to losing airspace for general avaiation in areas that AREN'T busy is incredible to me. and before we all know it an end to soaring as we know it today in this country...Public opinion will outnumber the small number of pilots wishing to fly for fun. Let the evening news, 60 minutes or 20/20 run some special on the dangers glider pilots pose to airliners and every politician will support the public opinion polls and side with them to get votes. These doomsday scenarios are so hard to predict, I don't think we should even try. Keep in mind that a there are a lot more general avaition airplanes than there are gliders, and they fly into these busy areas a lot more than we do, yet no one is suggesting they rip out their transponders and just fly in the rural areas. ....the more we depend on electronics the more we are keeping our heads down in the cockpits. Transponder use doesn't do this: turn it on when you turn on the radio, turn it off when you land. You don't look at it, you don't tune it, you don't listen to it. It's just there. ...with GPS and pocket nav's to guide us, flight computers to calculate for us and transponders to shield (?) us we are also forgetting what we started doing this for to begin with....look outside, there is real beauty to be seen through the clear mecaplex that surrounds us....fly safe, but always fly for fun These are worthy issues, but separate from transponders. |
The SSA has been discussing this with the FAA for years. This is the
farthest it's ever gotten. Steve Northcraft, our Regional Director and SSA Government Laison, told me a while ago that the FAA is very aware of the low-power transponders that are available. They didn't have to learn it from us. The issue is: should we be allowed to turn off our transponders when their use has little value? I'm inclined to encourage that approach. Ian Cant wrote: This appeared out of the blue, at least to me. If approved as it stands, it certainly would be an encouragement to install a transponder. But what is the SSA's position if the FAA comes back at some future date and says 'Yes, but now that you have pointed out that battery-operated transponders are available, there is no reason why ALL non-electric aircraft should not be REQUIRED to have a transponder installed' ? Like the part 103 ultralights, maybe it is best not to tamper with an existing favorable exemption. Ian At 18:48 21 February 2004, Eric Greenwell wrote: Check out the SSA website for the complete info on this petition, and consider commenting to the FAA (comments due by March 1, via web site, mail, fax, 'eRulemaking portal'): SSA Transponder Petition Published By Dennis Wright Posted Thursday, February 19, 2004 The SSA petition asks that SSA members be allowed to operate transponder-equipped gliders with the transponders turned off, when the glider is being operated more than 40 nautical miles from the primary airport in Class B airspace and more than 20 nautical miles from the primary airport in Class C airspace. Currently, Federal Aviation Regulation 91.215[c] requires that all aircraft equipped with a transponder and operating in controlled airspace have the transponder on. ....more on the web site -- ----- change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote in message ...
Check out the SSA website for the complete info on this petition, and consider commenting to the FAA (comments due by March 1, via web site, mail, fax, "eRulemaking portal"): SSA Transponder Petition Published By Dennis Wright Posted Thursday, February 19, 2004 ... Eric, Where is it? I went to the SSA web site and did several searches, such as "faa transponder petition", and found nothing. Thanks for pointing this out as I think the current rule may add to discouraging glider pilots from installing transponders, even though many areas, such as Minden, would really benefit from them. I'm lucky in that I have plenty of battery power, solar cells (2 amps worth) and a solid state Becker xponder that doesn't draw much, so I am able to abide by the rule. But most gliders couldn't and it's clearly much better for them to have transponders on in high traffic areas than never. Along the same lines, I'd love to see a rule that would allow gliders to install transponders without a 337. That's another rule that is way over-used. When I changed my German altimeter for an American made one, I needed a 337! Unscrewing three screws, pulling out an altimeter, putting in another, and rescrewing three screws is a major modification to airframe?? Anything we can do to get transponders in more gliders is a plus. When flying in the Minden area and listening to Reno approach on a busy day. I've heard things like: "Southwest 123, descend to one zero thousand, targets at 2 o'clock ten miles, 12 thousand feet, and a swarm of targets, altitudes unknown, from 10 o'clock to 3 o'clock. Presumed gliders." Makes me really happy I'm squawking. I realize I'm lucky to be able to afford the setup I have and rules changes like this would help increase transponder usage for a greater number of people who are on more limited budgets. Martin |
| Thread Tools | |
| Display Modes | |
| VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 05:29 PM |
| Operation without a transponder | flyer | Piloting | 11 | September 14th 04 09:48 AM |
| Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 04:09 PM |
| Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 01:18 AM |
| transponder codes | Guy Elden Jr. | Piloting | 1 | December 2nd 03 06:21 PM |
