DO YOUR CONTOL CHECKS!
Old April 4th 04, 01:10 AM
Stewart Kissel
Default DO YOUR CONTOL CHECKS!
http://www.ntsb.gov/NTSB/brief2.asp?...0417&ntsbno=CH
I04CA090&akey=1
Old April 4th 04, 01:40 AM
Bruce Hoult
I04CA090&akey=1
That looks more like: "if the manufacturer issues an AD [1], you'd
probably better do it, whether you legally have to or not".
-- Bruce
[1] in this case, installing a locking device onto L'Hotellier
connectors.
Old April 4th 04, 10:58 PM
Martin Gregorie
On Sun, 04 Apr 2004 11:40:06 +1200, Bruce Hoult
I04CA090&akey=1
-- Bruce
connectors.
This is the subject of a BGA AD in 1993 for the ASW-20, so I don't see
where you get the "manufacturer AD" bit from, even though it does
appear in ASW-20 TN-17 on extending the service life beyond 3000
hours.
As the AD in question refers to the requirement for a locking pin in
the Hotellier, I'm a bit gobsmacked that these couplings could ever
have been used without a locking pin or shroud: there's no way you
could inspect the check hole after assembly (other than poking
something through it) on wing control circuits in the ASW-20 and other
gliders. Admittedly you can see the check hole for the elevator, but
that's the only one that is easy to check by inspection on a '20.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old April 4th 04, 11:46 PM
Bullwinkle
I saw this exact thing happen at Stennis field, Bay St Louis, MS, in the
early 80's. The pilot was the best at the field, at least he was the only
one who flew in competitions. He and his wife both flew ASW-20's.
He assembled one day, began his aerotow, nose went up like he was on a
winch/auto tow, and he released at perhaps 40 or 50 feet.
His wife's back was turned, as she gathered dolly, etc that needed to be
stowed. She missed the whole thing. I was sure I was watching a low level
stall/spin happening before my eyes.
Then the nose came down, then back up again, then down again, and at the
bottom of one of these oscillations his wheel touched down, he dumped the
flaps and he got on the brakes and stayed down. Stopped a couple of feet
from the airport fence.
Turns out his elevator hadn't been hooked up, or had popped off between
assembly and tow. He claimed that he had been able to control pitch with the
flaps, but I (personal opinion, no data to back this up) think he just got
incredibly lucky.
The best news: no damage to aircraft or pilot.
The absolute most amazing thing: He walked the -20 back to the launch point,
Inspected it for damage (found none), hooked up the elevator, and promptly
took off. I'd have been shaking for a week after a near miss like that, not
have taken off within 15 minutes.
Long way of saying that I agree: DO YOUR CONTROL CHECKS!
On 4/4/04 2:58 PM, in article ,
I04CA090&akey=1
-- Bruce
connectors.
hours.
demon :
uk :
Old April 5th 04, 12:33 AM
goneill
I know of a case here in NZ exactly the same ,very high hours competition
pilot distracted during rigging, took off and released very quickly and
landed
straight ahead in a paddock using flaps only to control pitch.
The ASW20 seems relatively benign in this mode because I have heard of other
cases
I have an interest in this "because"
My ASW20 will be here soon ,Yippee!!!!
gary
"Bullwinkle" wrote in message
incredibly lucky.
point,
not
I04CA090&akey=1
-- Bruce
connectors.
hours.
demon :
uk :
Old April 12th 04, 07:04 PM
CV
landed
cases
Well, "benign" is perhaps not the word. But that aside I'd expect it
to depend a lot on CG position whether there is a chance to control it
with flaps alone, or not.
CV (also an ASW20)
Old April 5th 04, 10:06 AM
Janos Bauer
I can't believe it! No one asked him to sit down a bit and think about
what he made? The towpilot also could be killed so I think this action
should be investigated a bit more than this...
/Janos
Old April 5th 04, 04:06 PM
Andreas Maurer
On Mon, 05 Apr 2004 10:06:28 +0200, Janos Bauer
I guess he got the message...
Bye
Andreas
Old April 5th 04, 10:19 PM
Mark James Boyd
What is more surprising is that the towpilot
let him hook up again. I sure wouldn't tow him again until
I had at least a long talk and a day later. I wonder
if the tuggie even knew there had been a problem?
/Janos
Mark Boyd
Avenal, California, USA
Old April 5th 04, 10:55 AM
Martin Gregorie
On Sun, 04 Apr 2004 15:46:35 -0600, Bullwinkle
incredibly lucky.
That shows he had read and remembered what's in the POH, which
explicitly says that an ASW-20 can be controlled to in pitch by the
flaps if the elevator control circuit jams and that this control
should be enough to make egress easier or even avoidable.
I'm happy to hear that.
demon :
uk :
ELT Checks Kevin Chandler Owning 28 September 16th 10 03:47 PM
Formation flying Bingo Home Built 21 August 23rd 04 01:51 AM
~ 8 MORE DEAD US SOLDIERS - 93 IN APRIL SO FAR - BUSH CHECKS TURKEY MORRIS434 Military Aviation 0 April 22nd 04 10:44 AM
A couple Questions-Ramp Checks and Experimental Operations Badwater Bill Home Built 48 October 8th 03 10:11 PM
Flight Checks Mark Jackson Instrument Flight Rules 5 September 24th 03 07:39 PM
