flyWithCE news release - April 2004
Old April 7th 04, 08:27 PM
Uros Podlogar
Default flyWithCE news release - April 2004
1. Special offer for Navigator
Check out special spring offer for the Navigator. Now you can order program
for 89 EUR (plus VAT for EU countries). Visit order page for more details:
http://www.flyWithCE.com/order.shtml
You can also get a free 30 days trial licence for the Navigator on the web
site:
http://www.flyWithCE.com/register.shtml
Choose "Navigator trial registration" as the Registration type.
2. New version of Navigator 1.35
2.1. Full support for CUP task files and new waypoint function
In new version support for flyWithCE task files (extension TSK) are no
longer supported. Now program supports SeeYou CUP files with waypoints and
tasks. New waypoint types were also added (mountains top an mountain pass).
With new version you can also add current position as a new waypoint in
default waypoint file.
2.2. Better task and AAT task support
New version enables you to drag task waypoints around. With this feature you
can easily modify normal or AAT tasks. When waypoint is not an AAT waypoint,
than you can modify the waypoint and sector position. When you are flying
the AAT task and you redefined selected sector, than you can change the
position of the waypoint inside sector. With this feature you can easily
change the task length and improve final glide calculation.
2.3. Pan orientation
New is also pan orientation in map window. This orientation is north up and
enable user to change the screen position with Tap & Drag function. This
makes changes in AAT sector easier.
2.4. New altitude MapText box
In addition to the standard altitude MapText box (displays GPS or pressure
altitude) now you can also displays altitude in alternative units (feet
instead of meters and vice versa) or flight level.
2.5. Line sector shape
Line has been added to sector shapes.
2.6. Upper airspace limit
In new version you can hide airspaces which lower limit is higher than user
defined limit. Hidden airspaces will also not generate airspace warnings.
This feature will make flying easier in areas where you have airspaces that
are higher than maximum glider altitude.
2.7. New instruments
New devices in long list:
- LX Navigation LX1600 firmware version 2.0 or higher
- Cambridge Aero 302
Program supports all features of LX1600 instrument and decodes additional !N
sentence of Cambridge Aero 302.
2.8. New user’s manual in PDF format
Now user’s manual is available in PDF format. You can download it from
Navigator web site:
http://www.flywithce.com/navigator.shtml
3. New version of DownLoader 1.27
New version of DownLoader includes support for new release of LX Navigation
LX1600 instrument. If you do not have LX1600 you do not have to download and
install new version.
4. New flyWithCE distributor in United Kingdom
LX avionics Ltd is new distributor for flyWithCE products in United Kingdom.
Web site:
http://www.lxavionics.co.uk/
5. On-line customer support
To improve customer support you can contact me and talk with me on-line
using MSN Messenger. Contact Email address is published on web site:
http://www.flywithce.com/contact.shtml
Regards,
Uros Podlogar
www.flyWithCE.com
16 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 17th 04 01:37 AM
Air Force Print News for April 30, 2004 Otis Willie Military Aviation 0 May 1st 04 11:20 PM
Air Force Print News for April 29, 2004 Otis Willie Military Aviation 0 April 30th 04 10:45 PM
Air Force Print News for April 27, 2004 Otis Willie Military Aviation 0 April 29th 04 05:09 AM
09 Jan 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 January 9th 04 11:05 PM
