gps-nav to ipaq 3600 data and power
Old May 25th 04, 11:16 PM
Rich Chesser
Default gps-nav to ipaq 3600 data and power
I have a gps nav. I have a serial sync cable for my Ipaq 3630. I have
made a connector cable for the gps-nav to the sync cable. I am getting
data transfer.
Power is through the 8 pin on the db9 on the gpsnav. Can anyone
confirm the pin to receive 5 volt power on the db9 sync cable? Also if
5 volts is supplied through the serial cable will the yellow light
blink?
Rich
Old May 25th 04, 11:26 PM
Marc Ramsey
"Rich Chesser" wrote...
data transfer.
blink?
The voltage regulator in the GPS-NAV supplies adequate current for older
PDAs, such as the Compaq Aero 1500. It does not provide enough current for
an iPAQ, particularly if the battery needs charging. You'll probably end up
with a discharged iPAQ and/or a fried GPS-NAV. I'd suggest buying a
separate 5V power supply.
Marc
Old May 26th 04, 03:59 AM
Paul Remde
Hi,
For a long time I was highly recommending a 12V to 5 V power converter when
powering iPAQs with the GPS-NAV. But I've heard from a few customers that
say they have had success without the power converter. Cambridge told me
the current output data on the GPS-NAV and 302 and I created a note on my
Goddard page for GPS-NAV users. I would love to sell a Goddard PS-5a to
every customer, but they may or may not need one. If they keep their iPAQ
charged every night, they might be OK without the power converter. The note
I'm referring to is near the top of the page below.
http://www.cumulus-soaring.com/goddard.htm
However, I should mention that I have one customer that was powering his
iPAQ with his GPS-NAV and he told me that Cambridge said the GPS-NAV was
damaged and needed repair.
I recommend using the power converter to avoid damage to the GPS-NAV, and to
make sure you don't have an incomplete flight log due to the iPAQ pulling
the GPS-NAV down.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
"Marc Ramsey" wrote in message
data transfer.
blink?
for
up
Marc
homemade EFIS system and EMI jcpearce Home Built 75 February 22nd 05 03:07 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 5th 04 12:55 AM
LOP operation Roger Long Piloting 35 April 17th 04 06:29 AM
Ipaq - GPS_Log Help needed (Long) Steve B Soaring 1 September 27th 03 07:00 AM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 04:45 AM
