Lubricant for spar pins
Old January 8th 18, 04:23 PM posted to rec.aviation.soaring
Jim White[_3_]
Default Lubricant for spar pins
At 14:13 08 January 2018, Papa3 wrote:
On Monday, January 8, 2018 at 7:30:07 AM UTC-5, Jim White wrote:
At 23:35 07 January 2018, john firth wrote:
Wot? nobody pushing good old WD 40?
Seriously, surely the meticulous glider pilot must treat load bearing
pins
=3D
Tell me why? I am presently using WD40 specialist spray grease. Very
slip=
py
and easy to apply.
=20
I think most folks view WD40 as the "traditional" water displacement
produc=
t in the blue can which is nothing like the WD40 Spray Grease you're
using.=
If anyone really wants to do the work, you can look at some of the key
t=
ests that should be published on the Technical Data Sheets for whatever
pro=
duct you use to see how it performs. Things like ASTM D2266 2596 etc.
def=
ine critical wear prevention properties. =20
P3
Datasheet says:
4-ball Wear Test 0.5 mm (ASTM D-4172) ,
Dropping Point Temperature 118°C (ASTM D566) ,
Corrosion Protection in salt spray test 0 % rust at 72h (ASTM B-117) ,
Temperature (Continuous) -20°C to +115°C as grease, then to +260°C as
liquid
Is that any good?
Old January 8th 18, 04:29 PM posted to rec.aviation.soaring
Dan Marotta
White lithium grease works fine on my Stemme year round, including wave
flying.Â* When the outboard panels are installed, there are no shear
loads on the pins and they slide smoothly in and out.Â* When they start
to feel sticky, I wipe them off with a paper towel and apply a fresh,
light coating of grease and smooth, easy installation is restored.Â*
There's really no need to use grease from Mars or Uranus...
On 1/7/2018 4:54 PM, wrote:
I have used 100% synthetic Mobil 1 grease for three gliders that I fly in the heat of summer and the very very cold winters. Does not get stiff in the winter or runny in the summer.
Dan, 5J
Old January 8th 18, 05:25 PM posted to rec.aviation.soaring
jfitch
On Monday, January 8, 2018 at 4:42:18 AM UTC-8, wrote:
Hi Eric
I see the Aeroshell 5% molybdenum disulphide grease is now sold as Aeroshell 64. It's widely used in aircraft. I wasn't aware of the Schleicher caution against it, and haven't seen any caution from SH. I wonder where Schleicher got their information. I don't see any problems reported when using it with brass in an internet search. There is a copper-corrosion test in the 21164 mil standard for greases (5% moly grease passes) but the real-world meaning of that test isn't clear to me.
regards
My ASH 26 E manual warns against using molybdenum disulphide grease (Aeroshell 33
contains 5% of it) on the main pins because it can damage the brass bushings in
the wing. So, be sure to check it's compatibility if your bushings are brass.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Dry moly can cause corrosion, as it absorbs moisture from the air and the disulphide turns into sulfuric acid. Any good grease is a concoction of ingredients, some of which are inhibitors to make sure that doesn't happen. I believe the concern is theoretical, more than real.
Old January 8th 18, 05:26 PM posted to rec.aviation.soaring
Kiwi User
pins
=3D
slip=
py
and easy to apply.
=20
produc=
using.=
key
t=
pro=
def=
P3
Datasheet says:
liquid
Is that any good?
I notice that the "Super Lube grease with Syncolon" is available in the
UK in 90mm tubes from Amazon, so have decided that I'll have one before
my Libelle's next annual is due in March: I need to bbuy some grease
before then anyway.
Martin | martin at
Gregorie | gregorie
| dot org
Old January 8th 18, 05:41 PM posted to rec.aviation.soaring
kirk.stant
Come on, the most important quality for main pin grease it that it leave a permanent circular stain on the thighs of your favorite flying pants/shorts - how else will other glider-guiders recognize you as one of the true believers at the field?
Even Pez D. Spencer knew that!
66
Old January 8th 18, 05:56 PM posted to rec.aviation.soaring
WB
On Monday, January 8, 2018 at 6:42:18 AM UTC-6, wrote:
Hi Eric
regards
I have seen molybdenum disulphide grease cause galling in brass parts on some pneumatic equipment. Moly is pretty much an "anti-lubricant" for brass.
Old January 8th 18, 07:33 PM posted to rec.aviation.soaring
Bob Kuykendall
We wax our pins twice a season, usually once before winter storage and again in the spring, mostly for corrosion protection. During the flying season we use whatever slippery comes to hand, usually the same grease as we don't use on O2 system parts.
--Bob K.
Old January 8th 18, 08:32 PM posted to rec.aviation.soaring
--Bob K.
I've used plain old Vaseline petroleum jelly for 40 years or so with no known bad effects.
UH
  #29
Old January 8th 18, 08:38 PM posted to rec.aviation.soaring
Kiwi User
.... the bucket hat?
Martin | martin at
Gregorie | gregorie
| dot org
  #30
Old January 8th 18, 09:10 PM posted to rec.aviation.soaring
Papa3[_2_]
... the bucket hat?
Which my wife fondly refers to as Birth Control. "There's no way you're getting laid wearing that thing".
LS1 F glider - question on spar pins [email protected] Soaring 2 April 29th 13 11:45 AM
Alignment tool for spar pins soartech[_2_] Soaring 5 September 6th 12 05:39 PM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 12:46 AM
"Duke" will receive lubricant funds during prison stay! Vox Populi Naval Aviation 1 December 11th 05 02:02 PM
Best lubricant for Mechanical Tachometer Cable??? RonLee Home Built 3 January 4th 05 12:04 AM
