The B40 that came with my glider has this curious fault: after
experiencing an updraft of 10 knots or greater, the rapid, high-pitched (i.e. "saturated") audio tone gets "stuck" and continues indicating 10+ knots until the B40 registers a negative value (sink). Has anyone else encountered this problem or know if there's a fix? -ted |
Fly upside down!
--- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.706 / Virus Database: 462 - Release Date: 6/14/04 |
"COLIN LAMB" wrote in message nk.net... Fly upside down! That oughta work, It's Australian, ain't it. Hey, is it true that a glider's polar is upside down when the glider is? Bill Daniels |
(tuno) wrote in message . com...
The B40 that came with my glider has this curious fault: after experiencing an updraft of 10 knots or greater, the rapid, high-pitched (i.e. "saturated") audio tone gets "stuck" and continues indicating 10+ knots until the B40 registers a negative value (sink). Has anyone else encountered this problem or know if there's a fix? -ted Ted I am a Borgelt Dealer in the US, and asked Mike Borgelt about your problem. Richard Pfiffner Craggy Aero www.craggyaero.com The pointer and the audio are driven by the same signal. Every B40 gets tested for full range of the audio and I've never seen this problem in nearly 900 B40's, however examination of the circuit diagram indicates to me that I think there is a problem with the LMC660 quad op amp on the audio board. One of the four amps level shifts and inverts the meter signal so as to drive the audio generator and this is the only place something like this could occur. I suggest the LMC 660 be replaced and I'm pretty sure the problem will go away. We can fix this or any competent avionics tech should be able to perform this fix. Regards Mike Borgelt Instruments - manufacturers of quality soaring instruments phone Int'l + 61 746 355784 fax Int'l + 61 746 358796 cellphone Int'l + 61 428 355784 Int'l + 61 429 355784 email: website: www.borgeltinstruments.com |
| Thread Tools | |
| Display Modes | |
| Question from a new flight student (whopping 7 hours!) | Gary G | Piloting | 90 | October 22nd 04 12:48 AM |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 10:40 PM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
| Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 01:14 AM |
