Trig TT21 + TN72 TABS ADS-B Out Install working great....
Old February 12th 18, 03:44 AM posted to rec.aviation.soaring
Darryl Ramm
Default Trig TT21 + TN72 TABS ADS-B Out Install working great....
You can do a lot to merge GPS antennas you already have. Personally I would not be doibg that for a GPS source used to drive any type of ADS-B Out.
Old February 12th 18, 03:58 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Great, now if we could get something like that for GPS. I have 3 GPS's now without ADS-B in out or sideways. Flarm, LX and Butterfly.
On Sunday, February 11, 2018 at 6:20:41 PM UTC-8, Richard Pfiffner wrote:
Too many antenna. 4 GPS and 2 FLARM within 30". We need a reliable way to split/share GPS signal off a single antennae.
http://www.craggyaero.com/antennas.htm
Bottom Page
Richard
www.craggyaero.com
Old February 12th 18, 04:07 AM posted to rec.aviation.soaring
George Haeh
So we're looking at:
$350 TN72
$321 GPS Antenna Combiner & cables for Flarm + GPS vario
$671 Total before shipping.
There's just barely enough room under my glareshield for 2 GPS antennae 30"
apart. Without the combiner I'd have to wire the third antenna to my hat.
I'm still entertaining the fantasy of mounting an L2 transponder antenna in
tail battery box of my 27 - and routing a fat enough coax there. I dread
thought of dirtying my 27 with an external transponder antenna.
Old February 12th 18, 05:02 AM posted to rec.aviation.soaring
Steve Koerner
$350 TN72
I've got 5 GPS antenna pucks under the glareshield of my '27. Space them out but don't worry about the 30" bit. That's an exaggerated requirement.
Old February 12th 18, 06:17 AM posted to rec.aviation.soaring
Retting
I had 4 under my glare with no issues. Just a few inches apart.
R
Old February 12th 18, 07:09 AM posted to rec.aviation.soaring
Darryl Ramm
I was going to say the same as Steve. These GPS antenna spacing concerns seem largely folklore. It’s hard to imagine what is going to cause problems there anyhow, back-leakage of local oscillator from inside the GPS electronics back to the antenna??? In some cases I’ve seen confusion between gps antenna to gps antenna and gps antenna to say DME or VHF coms antennas and they may make more sense. Even if it exists as a real problem at all, many many gliders have flown sucesfully with multiple GPS antennas separated at most by a few inches. Including two of mine.
Old February 12th 18, 04:08 PM posted to rec.aviation.soaring
JS[_5_]
In personal experience, GPS position is acquired faster with fewer antennas..
For example: Two antennas and one divider for four receivers acquires faster than four separate antennas behind the already crowded panel.
YMMV, WTFIHTA, etc.
Old February 12th 18, 04:45 PM posted to rec.aviation.soaring
So to confirm what I think I understand: an Experimental airworthiness glider can fully satisfy the 2020 ADS-B mandate using the TT22 + TN72.
A Standard airworthiness glider must use the TT22 + TN70.
(The TN70 is about $1500 more than the TN72).
Is that correct?
Matt
Old February 12th 18, 05:00 PM posted to rec.aviation.soaring
Bob Caldwell (BC)
On Sunday, February 11, 2018 at 4:04:37 PM UTC-7, Darryl Ramm wrote:
I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system.
Here is a screenshot of my portable Stratux ADS-B receiver (as would be used in many GA aircraft) receiving the ADS-B signal from the TT21 over 20 nautical miles away. Yes, it's a wave day out at Williams.
https://drive.google.com/file/d/1Kik...SlslyEyMPo62Mu
And again just an reminder, the TN72 is a ~$350 (+ GPS antenna + install costs) GPS Source that can easily be added to any Trig transponder to deliver ADS-B Out in your glider. (If you need full 2020 Compliant ADS-B Out it's a little more involved). This is low-enough cost that it will likely be a "just do it" choice for owners who already have a Trig transponder, and who especially want to provide more visibility to GA traffic (and it makes your glider visible to PowerFLARM buddies at much longer distances).
So how much of a hassle was it to update the XPDR and head on the TT21? My stuff is buried in the mess of other stuff under my glare shield. Can a local Trig dealer do it or does it have to go to Micro Air in Kansas?
Old February 12th 18, 05:23 PM posted to rec.aviation.soaring
Darryl Ramm
I think just a typo, but to be clear Microair is a different transponder manufacturer (who does not make any Transponder capable of 1090ES Out or TABS, or even basic Mode S) .
If a Trig TT21 or TT22 needs a firmware update they have to go back to MidContinent, the USA Trig service center https://www.trig-avionics.com/support/u-s/. The update is free.
For use with the TN72 a TT21 or TT22 transponders need firmware 2.12 or higher and control head firmware 1.14 or higher.
The possible need to ship hardware back to MidContinent is one reason I have been advertising for a while why it is a good idea to get this done over this winter. Turn around there may only be a few days, call them and check.
Trig TN72 Antenna Andrew Ainslie Soaring 17 April 6th 17 04:21 AM
Trig TT21 for sale [email protected] Soaring 2 April 15th 16 06:35 PM
Trig TT21 transponder for sale Dave Springford Soaring 15 September 7th 12 11:05 PM
Trig TT21 transponder draws only 125 mA! Steve Koerner Soaring 5 March 15th 10 10:59 PM
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
