Hi everybody
I would like to gather some information about a passive reflective device which could be used to increase the visibility of a glider. It was described to me as follows, during one of those typical launch point chats: It takes the shape of small sphere, mounted just behind the canopy on the turtle deck The surface is covered with faceted mirrors, like a disco mirror ball Apparently this little ball will sparkle as light from the sun is reflected to the observer, thus making the glider more visible. Now my questions are as follows: Has anybody ever seen or heard of such a device? If yes, how can one obtain these little do-hickeys, i.e. price and point of sale. Do they actually work? Any other suggestions for passive reflective devices will also be appreciated. Suggestions and thoughts on active devices, i.e. strobes will also be handy. Regards Henk Stander |
Henkelize wrote:
It takes the shape of small sphere, mounted just behind the canopy on the turtle deck The surface is covered with faceted mirrors, like a disco mirror ball Are you prepared to pay for the drag it will cost you? Rgds, Derrick Steed |
It does not have to be very big. I'm thinking about the size of a squash
ball. Regards Henk "Derrick Steed" wrote in message ... Henkelize wrote: It takes the shape of small sphere, mounted just behind the canopy on the turtle deck The surface is covered with faceted mirrors, like a disco mirror ball Are you prepared to pay for the drag it will cost you? Rgds, Derrick Steed |
That's still about as much as the width of the glider fuselage - you'd need to design a fairing for it.
Rgds, Derrick. It does not have to be very big. I'm thinking about the size of a squash ball. Regards Henk "Derrick Steed" wrote in message ... Henkelize wrote: It takes the shape of small sphere, mounted just behind the canopy on the turtle deck The surface is covered with faceted mirrors, like a disco mirror ball Are you prepared to pay for the drag it will cost you? Rgds, Derrick Steed Rgds, Derrick Steed |
In article , henkelize
writes Hi everybody I would like to gather some information about a passive reflective device which could be used to increase the visibility of a glider. It was described to me as follows, during one of those typical launch point chats: It takes the shape of small sphere, mounted just behind the canopy on the turtle deck The surface is covered with faceted mirrors, like a disco mirror ball Apparently this little ball will sparkle as light from the sun is reflected to the observer, thus making the glider more visible. Now my questions are as follows: Has anybody ever seen or heard of such a device? If yes, how can one obtain these little do-hickeys, i.e. price and point of sale. Do they actually work? Any other suggestions for passive reflective devices will also be appreciated. Suggestions and thoughts on active devices, i.e. strobes will also be handy. Regards Henk Stander Many years ago I had the same thought. I made up a reflector from 3 polystyrene ceiling tiles arranged at right angles to each other, and covered with kitchen foil. (If you arrange mirrors like this a light ray striking it will be sent back from where it came, it works with radar too.) Then I found there wasn't room in the glider for it. Maritime radar reflectors are available, they are also too big... -- Mike Lindsay |
Mike Lindsay wrote:
Many years ago I had the same thought. I made up a reflector from 3 polystyrene ceiling tiles arranged at right angles to each other, and covered with kitchen foil. (If you arrange mirrors like this a light ray striking it will be sent back from where it came, it works with radar too.) Then I found there wasn't room in the glider for it. Maritime radar reflectors are available, they are also too big... Mike, I think Henk was talking about a reflector for sunlight, not radar transmissions. This means he needs to have the reflector on the outside of the glider so it can be seen by others. The main problem seems to be the drag issue, and then whether it is any use anyway. IMO unless very large, it won't be visible at any useful distance. Even strobe lights aren't that good in bright sunshine after about half a kilometer. Cheers, John G. |
"henkelize" wrote in message ... Hi everybody I would like to gather some information about a passive reflective device which could be used to increase the visibility of a glider. It was described to me as follows, during one of those typical launch point chats: It takes the shape of small sphere, mounted just behind the canopy on the turtle deck The surface is covered with faceted mirrors, like a disco mirror ball Apparently this little ball will sparkle as light from the sun is reflected to the observer, thus making the glider more visible. Now my questions are as follows: Has anybody ever seen or heard of such a device? If yes, how can one obtain these little do-hickeys, i.e. price and point of sale. Do they actually work? Any other suggestions for passive reflective devices will also be appreciated. Suggestions and thoughts on active devices, i.e. strobes will also be handy. Regards Henk Stander A number of years ago, some hang glider pilots in the Owens Valley were using golf-ball sized or tennis-ball sized "mirrored disco balls" attached to the kingpost. You'd get a bright flash occasionally, and it tended to draw the eye. I think it did help some with visibility. Nowadays, the kingposts are mostly gone, and I imagine so are the disco balls. And I'm still not much help, because I don't know where the people that had them, got them. Tim Ward |
using golf-ball sized or tennis-ball sized "mirrored disco balls" attached to the kingpost. You'd get a bright flash occasionally, and it tended to draw the eye. I think it did help some with visibility. Nowadays, the kingposts are mostly gone, and I imagine so are the disco balls. And I'm still not much help, because I don't know where the people that had them, got them. Tim Ward I remember those little disco balls (abour the size of a tennis ball) and I remember that at more than 300 meters or so the flash given off was no longer discernable, probably because of the very small faceted surfaces on them. Mike Z |
Hi everybody I would like to gather some information about a passive reflective device which could be used to increase the visibility of a glider. It was described to me as follows, during one of those typical launch point chats: It takes the shape of small sphere, mounted just behind the canopy on the turtle deck The surface is covered with faceted mirrors, like a disco mirror ball Apparently this little ball will sparkle as light from the sun is reflected to the observer, thus making the glider more visible. Now my questions are as follows: Has anybody ever seen or heard of such a device? If yes, how can one obtain these little do-hickeys, i.e. price and point of sale. Do they actually work? Any other suggestions for passive reflective devices will also be appreciated. Suggestions and thoughts on active devices, i.e. strobes will also be handy. Regards Henk Stander http://mathworld.wolfram.com/topics/...3DApplets.html Pick your shape and have at it. |
Any other suggestions for passive reflective devices will also be appreciated. Suggestions and thoughts on active devices, i.e. strobes will also be handy. Regards Henk Stander Seeing that you are going to be using Lawrence Welk's mirrored ball, you should also attach his perpetual bubble machine, and use it for thermal location. John |
| Thread Tools | |
| Display Modes | |
| Aircraft Deceleration Devices | SteveM8597 | Military Aviation | 10 | April 13th 04 11:01 AM |
| Devices for avoiding VNE? | John Galloway | Soaring | 100 | April 12th 04 09:53 PM |
| GPS and Night Vision Devices | Steve | Products | 0 | February 12th 04 12:34 PM |
| WinPilot-compatible GPS devices | Ted Wagner | Soaring | 21 | January 12th 04 11:27 AM |
| Airdropped Fusion Devices | Blinky the Shark | Military Aviation | 4 | September 17th 03 06:34 PM |
