GliderLink - New team soaring app for airborne location sharing
Old May 7th 18, 07:16 PM posted to rec.aviation.soaring
Ben Hirashima
Default GliderLink - New team soaring app for airborne location sharing
Interesting idea about Bluetooth to Oudie. Might be possible.
  #52
Old May 10th 18, 02:52 AM posted to rec.aviation.soaring
Ben Hirashima
A couple of people have emailed me asking about a problem with the goTenna disconnecting. I have updated the FAQ regarding this:
https://glider.link/faq/
Basically, update your goTenna's firmware using the official goTenna app:
https://play.google.com/store/apps/d...otenna.gotenna
  #53
Old May 21st 18, 01:57 AM posted to rec.aviation.soaring
Ben Hirashima
I would love to hear from anyone who has been using the app. How is it working for you?
  #54
Old May 21st 18, 03:22 AM posted to rec.aviation.soaring
Tom BravoMike
Ben, I haven't had any opportunity yet, but hope to get to fly within next 8 days and will let you know how it went. I tried out the software on the ground and walked around few blocks. For that purpose I wish I could zoom-in even more, to a more detailed map, but I guess the map range limit will be OK when in flight.
Tom BravoMike
  #55
Old May 21st 18, 03:45 AM posted to rec.aviation.soaring
Ben Hirashima
Thanks, Tom. Looking forward to hearing about it. I would like to allow zooming in more on the map too, but adding just one more zoom level would quadruple the size the map takes up, so it's just not practical. In the air, the current level of detail should be quite sufficient.
  #56
Old May 23rd 18, 03:27 PM posted to rec.aviation.soaring
Bruce
I got the package of 8 goTennas for the club. Haven't got anyone up to speed yet, but I've trialed it with one unit on the ground and one in my glider, my longest contact was 14 miles.
I have 2 reactions. 1. It seems to be very power hungry, and 2. It needs to have a shutdown or exit command, as the power consumption seems to continue after you quit using it. I'm using a Samsung s5 and put it into airplane mode with location and bluetooth on. After I'm done using it the only way I have successfully terminated it is by doing a restart.
I think it has great potential and an interface into nav programs would reduce display requirements.
  #57
Old May 23rd 18, 09:22 PM posted to rec.aviation.soaring
Ben Hirashima
Hi Bruce. I'm surprised to hear GliderLink is consuming a lot of power. It consumes very little power on the four phones I have run it on. It's often difficult to tell how much any one app is using. Just looking at how much the battery went down while you were using the app is not necessarily a good way to tell. It could be any app on the system using up the battery. Some apps will freak out when there's no Internet connection (airplane mode) and constantly try to connect, using up the battery. On most Samsung phones, you can go into the settings to the battery page and it should show how much individual apps are using. Let me know what it says.
  #58
Old May 23rd 18, 09:24 PM posted to rec.aviation.soaring
Ben Hirashima
BTW Bruce, the way to shut down GliderLink is to tap the on/off switch in the upper right corner of the main GliderLink screen.
  #59
Old May 31st 18, 05:54 AM posted to rec.aviation.soaring
Ben Hirashima
Meshing has come to GliderLink! I just published version 1.2.0 to Google Play. This version will broadcast not only your own location, but the locations of up to three other nearby gliders. This increases the range and robustness of the system. This version is backward compatible with older versions, but the older versions will not benefit from or contribute to the mesh network.
Example of extended range: You are glider A. Glider C is far away, out of range. However, glider B is between you and C, and in range of both of you. When C broadcasts its location, B will see it and re-broadcast it, which you can then receive. In effect, you will be able to see gliders that would normally be out of range.
Example of increased robustness: You, glider B, and glider C are all within range of each other. Glider C is thermalling, and when it broadcasts its location, the fuselage happens to be blocking transmission to you, but not to glider B. Glider B sees glider C and re-broadcasts C's location. This time, you are able to receive C's location since your line-of-sight is not blocked to glider B. There is more than one path for C's location to get to you, so the system is more robust. The more gliders there are in range, the most robust the system is. One caveat is that C's location may get to you a bit later, since you have to wait for glider B to broadcast on its usual 20 second cadence.
Some friends and I tested it for three days last weekend, and it worked well. One pilot was able to see me from 70 nautical miles away, thanks to meshing.
  #60
Old May 31st 18, 07:37 PM posted to rec.aviation.soaring
Wit Wisniewski
Folks, please don't confuse PowerFlarm with Flarm.
In my opinion, Flarm should have been chosen as a universal system for worldwide collision avoidance between all aircraft over ADSB-out/in. It wasn't, and Flarm is banned in the US. PowerFlarm is a very low transmit power attempt at salvaging some Flarm capability.
I see many local XC pilots contemplating or already installing ADSB-out to promote safety with respect to non-glider traffic. (Only one of my many close calls was with another glider) With limited money, battery power, and panel space, and with only a minority of gliders/towplanes equipped, I expect PowerFlarm to go extinct.
Your technology may also be a preferred alternative to SPOT and other locator services.
Ben,
Thank you for your effort!!!
Solving the cost, power, and panel space problem in one system is what we need. My wishes/requests for your development a
- Consider adding input from Stratux. Stratux is a $100 1090 and 978 MHz receiver that collects direct ADSB-out, UAT-out, rebroadcast TIS-b, weather, and NOTAM data from aircraft and ground towers, and puts it in a serial stream on a WiFi port. I use it with Avare, an open source EFB/navigation app. Parsing the stream for aircraft positions to be displayed on your map should be relatively easy.
- Adding mesh relay capability with fixed or mobile ground stations to close the gap between gliders too far apart. Internet connected mesh nodes would be desirable where there aren't enough airborne nodes to complete the mesh. I would love to see our club run a ground network for real-time tracking of all gliders in the area. This would give peace of mind to ground crews, knowing who may be landing out and where. Such a network may also save lives by giving a head start on search and rescue by providing undelayed info regarding where a glider went down. (Most gliders don't carry an ELT.)
- Adding internet map server capability to the above mentioned mesh for the piece of mind of airport crews, XC crews, spouses, friends, etc...
Thank you so much,
Wit
Support the U.S. Soaring Team Frank Whiteley Soaring 1 July 13th 14 04:07 PM
US Soaring Team eBulletin 21 John Seaborn Soaring 0 July 21st 05 05:14 PM
US Soaring Team eBulletin John Seaborn Soaring 0 November 20th 04 08:11 PM
GTA pilots on the US Soaring Team chris Soaring 2 September 1st 04 11:14 PM
U.S.A. Soaring Team Web Update John Seaborn Soaring 0 August 17th 04 05:14 PM
