Iran and GPS etc
Old May 11th 18, 01:14 AM posted to rec.aviation.soaring
Default Iran and GPS etc
The US military built, owns, and controls it, but the user base has kind of gotten out of hand.
They might could turn it off any time they want once, but it might be a career limiting event.
If they caused a wide outage without a good reason, there would be a political backlash from the number of folks that paid for it being inconvenienced or worse.
Old May 11th 18, 02:08 AM posted to rec.aviation.soaring
GPS testing is done from several military bases and that testing can and does involve skewing of signals, denial of service or anything else that may be deemed necessary in the National interest or to evaluate the impact on a battlefield, where enemy combatants may be using US assets to inflict damage on the US or our allies.
Remember that this is a service provided at no charge (except to the US taxpayer) for a benefit that is utilized worldwide. There are other systems (Google Glonass) but the most prevalent and capable system is still the US Air Force administered constellation of satellites that provides reasonably dependable and accurate position data to civilian air traffic, both commercial and private, to the point that airliners and other Instrument rated pilots and aircraft routinely use these data and allow for "GPS Approaches" to the centerline of the runway.
In times of war or other national emergencies, the civilian and/or commercial service may be disrupted or canceled completely either worldwide or in specific areas, while leaving the US military in a situation whereby they can still utilize the signals. GPS jamming is possible by anything from a concerted effort by opposing forces to truckers (or anyone else) on the highway who purchase a cheap signal blocking device to mask their behavior on the road from the home company or other signals analysis entities. (You can buy GPS blockers on eBay.)
I remember a notable presentation at Oshkosh several years ago entitled, "GPS Stole My Brain." Total reliance on this system with no actual physical and mental map reading skill is foolhardy.
As far as people (users) being "inconvenienced" or (administrators) dealing with a "career limiting event," I will side with the US soldier every time..
We deal with GPS testing on a fairly regular basis from Holloman Air Force Base and the White Sands Missile Range. The schedule for testing, the approximated affected area and altitudes are published well in advance and are available from a number of websites. I check the schedule, just I check for NOTAMs and TFRs. I suggest you do the same.
Old May 11th 18, 02:59 AM posted to rec.aviation.soaring
2G
On Thursday, May 10, 2018 at 3:05:30 AM UTC-7, wrote:
Personally, to cheer such utter stupidity says a lot about you. Personally.
Trumo is ruining the US reputation world wide.
Making the US grate again.
You are more than welcome to find the closest "Why she lost" cry party where you might find someone who actually cares about what you think.
Tom
Old May 11th 18, 03:01 AM posted to rec.aviation.soaring
2G
On Thursday, May 10, 2018 at 5:20:52 AM UTC-7, wrote:
Unfortunately - decisions that Trump makes do not just affect the US - but have a ripple effect on the rest of the world too. Just simple things like the sharp increase in oil price following his Iran announcement means my fuel price will go up next month - and I live in South Africa which has nothing to do with the spat with Iran.
Think about what would happen to oil prices if Iran hits Israel with a nuke..
Tom
Old May 11th 18, 03:16 AM posted to rec.aviation.soaring
2G
The US military does not "own" GPS; the US Air Force operates it (it is owned by the US government). Selective Availability was ended in the 1990s by Bill Clinton. Since then, GPS has become a critical resource used by all government agencies, but, most importantly, by the FAA. GPS will only be shut down in the event of a critical national emergency; can you image the impact on airliners using a GPS IFR approach that suddenly went dark? For more info, go to:
https://www.gps.gov/systems/gps/performance/accuracy/
Tom
Old May 11th 18, 03:42 AM posted to rec.aviation.soaring
Jonathan St. Cloud
During the second Clinton administration, the Selective Availability was ended by executive action. If the military doesn't want you to have GPS they jam an area instead of turn the entire GPS network off or to selective availability. Also, as the boys flying the Sentinel over Iran found out GPS signals can be spoofed. Many military weapons systems still use inertial nav only checked occasionally against GPS.
Old May 12th 18, 04:21 AM posted to rec.aviation.soaring
This is one Sean can’t get blamed for...
Game Plan: If Israel Strikes Iran (Retired General Says Israeli Attack to Take Out Iran’s Nuclear Facilities Not Only Possible, the U.S. Should Join In) NOMOREWARS_FORISRAEL Naval Aviation 2 October 20th 09 02:33 AM
Iran Prepares for Global Nuclear War ....Iran will be on the receiving end.... AirRaid[_5_] Naval Aviation 0 April 30th 07 03:56 AM
Iran's deputy interior minister threatens U.S. world interests and Israel if Iran is attacked AirRaid[_4_] Naval Aviation 0 April 26th 07 09:41 PM
The Iran War Theater's "Northern Front" - Azerbaijan and the U.S. Sponsored War on Iran AirRaid[_3_] Naval Aviation 0 April 12th 07 07:07 AM
Nukes in Iran (WAS: Israel to Destroy Iran's Nuke Capacity) Dav1936531 Military Aviation 1 February 20th 04 09:02 PM
