Stowing water?
Old May 15th 18, 06:53 AM posted to rec.aviation.soaring
Default Stowing water?
I fly with two 70 oz CamelBaks stuffed behind the headrest on the "luggage shelf."
That's about 9 pounds of water...behind your head. I suspect the biggest difference between getting hit by 9 lbs. of water in a crash and 9 lbs. of lead is that the water will only break your neck while the lead will crush your skull and break your neck.
I assume the headrest is fixed and would help prevent a direct hit but I stow mine of about the same size in a compartment on the left side of the cockpit behind a fixed panel.
Chip Bearden
LS8 water valves Bela[_2_] Soaring 3 June 30th 08 03:48 AM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
