Komet trailer axle dillema
Old May 15th 18, 08:25 PM posted to rec.aviation.soaring
Echo
Default Komet trailer axle dillema
Sounds like a good idea to me. Kinda what I've been leaning towards. Thanks for the replies.
Old May 16th 18, 02:51 AM posted to rec.aviation.soaring
George Haeh
Your trailer likely predates AlKo parts. For the price of a replacement AlKo axle and other bits, you may be better off buying a used trailer - after checking out the axle, bearings and brakes.
Old May 16th 18, 12:08 PM posted to rec.aviation.soaring
Tango Eight
Komet used a lot of Knott running gear. Spares available here
https://www.knott-trailer-shop.com/index.php
You don't want to know what it costs to ship an entire axle to US.
Evan Ludeman / T8
Old May 16th 18, 01:20 PM posted to rec.aviation.soaring
Papa3[_2_]
Evan Ludeman / T8
A little late to the game here. I'll echo what a few others said up-stream. If you can make it all work, stick with the original equipment. The mechanical surge brake is elegantly simple and robust - if you do some basic maintenance periodically.
Also, here's a link to an older version of the print catalog for KNOTT. Has tremendous technical detail (exploded views, engineering data, assembly instructions, etc.) While your specific part numbers may not be in there, you can find very close matches that will help with trouble shooting.
https://drive.google.com/open?id=0Bx...UU0cU9EWmZnWW8
Old May 16th 18, 02:21 PM posted to rec.aviation.soaring
Evan Ludeman / T8
Does Knott have a distributor/dealer in the US?
Old May 16th 18, 03:20 PM posted to rec.aviation.soaring
Tango Eight
Evan Ludeman / T8
Maybe.
http://knottbrake.com/categories/axles/
Worth a phone call.
Evan / T8
Old May 16th 18, 03:38 PM posted to rec.aviation.soaring
Evan Ludeman / T8
Maybe.
Worth a phone call.
Evan / T8
Thanks T8 for the lead. Knott has a US distributor for trailer components:
AutoFlex
Fox Lake , Wisc
920-928-6875
Seeking Komet Trailer Axle Marc Henis Soaring 7 May 7th 14 11:26 PM
PIK 20 Trailer Axle Taylor Drake Soaring 7 April 8th 11 06:12 PM
PIK 20 Trailer Axle Taylor Drake Soaring 0 April 8th 11 06:54 AM
Cobra trailer axle Pete Dawson Soaring 1 August 15th 09 01:49 AM
Cobra Trailer - U.S. Axle? Mitch Soaring 8 March 2nd 07 09:16 PM
