3,000 hour inspection for Schleicher sailplanes, required in the US?
Old June 21st 18, 08:17 PM posted to rec.aviation.soaring
Chris Snyder
Default 3,000 hour inspection for Schleicher sailplanes, required in the US?
On Sunday, November 12, 2017 at 10:20:27 AM UTC-5, wrote:
I've spent some time reading the FAA's response to the SSA in regards to the IS-28B2 found here, http://www.ssa.org/files/member/FAA%...7%20-%20Signed[2543].pdf
I'm curious how it applies to the 3,000 hour service life extension for say a Schleicher ASW-15 sailplane.
I have the same question about a DG-200. Is a service life extension required in the US?
Old June 22nd 18, 01:37 AM posted to rec.aviation.soaring
The Lark was life limited. It did not have a provision for service life extension. The FAA provided a way to extend life by condition, as I recall.
The other manufacturers do have that provision so owners have to comply with the inspection specified to ensure continued airworthiness.
UH
Old June 22nd 18, 12:44 PM posted to rec.aviation.soaring
Chris Snyder
UH
Thank you for the confirmation. If anyone has gone through the 3000h inspection process for a DG, I'd appreciate any information you can share.
Chris
Old June 23rd 18, 01:40 PM posted to rec.aviation.soaring
UH
For accuracy, as opposed to my recollection with respect to the Lark see:
UH
Old June 23rd 18, 11:57 PM posted to rec.aviation.soaring
Morgan[_2_]
On Friday, June 22, 2018 at 4:44:43 AM UTC-7, Chris Snyder wrote:
The Lark was life limited. It did not have a provision for service life extension. The FAA provided a way to extend life by condition, as I recall..
UH
Chris
Hi Chris,
We did a 3000hr inspection on a DG100G with the assistance of Rex at Williams Soaring. It took about a day to go through everything. Nothing really too difficult or special, just checking and comparing things to their specifications. The hassle of course is paying the service fee and then buying the inspection form. But beyond that, it's just like doing an extensive annual where you're doing some measurement of play in control circuits or throw of ailerons.
Morgan
Old June 24th 18, 02:18 AM posted to rec.aviation.soaring
Charlie Quebec
Wow, you dont do all control throws at every annual, its mandatory here in Oz.
Old June 24th 18, 07:31 AM posted to rec.aviation.soaring
krasw
I did once to a factory new Discus 2 (first annual). Aileron throw was way out of spec. After that measuring these did not seem so important anymore...
Old June 24th 18, 11:39 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default 3,000 hour inspection for Schleicher sailplanes, required in theUS?
in Oz.
Same in the UK.
Martin | martin at
Gregorie | gregorie dot org
Transponder Inspection Not Required? Chip Bearden Soaring 14 May 8th 08 07:38 PM
Mandatory inspection of Schleicher wooden gliders. W.J. \(Bill\) Dean \(U.K.\). Soaring 2 June 7th 05 10:15 PM
Service Manual - 50 hour inspection O. Sami Saydjari Owning 1 April 8th 04 03:17 PM
100 Hour Inspection Question FryGuy General Aviation 59 November 19th 03 04:01 AM
100 Hour Inspection Question FryGuy Piloting 58 November 19th 03 04:01 AM
