flarm antenna placement
Old July 14th 18, 01:42 AM posted to rec.aviation.soaring
Matt Herron Jr.
Default flarm antenna placement
Still looking to improve my flarm range especially below. I have a Trig T22 fin antenna on the bottom of my 27. Can I somehow incorporate the receive only flarm antenna into this fin? Too close to the transponder?
RF engineers speak up!
Thanks, Matt
Old July 14th 18, 02:15 AM posted to rec.aviation.soaring
JS[_5_]
Thanks, Matt
I'm not an engineer, but have dealt with enough low-powered RF around the World to suggest... Don't do it.
Is your 27 a B model? If not the FLARM and PCAS antennas can go forward of the rudder pedals on the sides of the nose. Peter Kelley published the installation for his 26 and I used that location in 27058.
Old July 14th 18, 05:44 AM posted to rec.aviation.soaring
JS[_5_]
https://www.valleysoaring.net/flight-ops/power-flarm/
By Peter - sorry for the previous typo - Kelly.
Old July 14th 18, 06:00 AM posted to rec.aviation.soaring
Steve Koerner
Thanks, Matt
Matt -
There's no practical way to combine them. In fact, any added flarm antenna should not be placed too close to the Trig antenna.
Personally, I don't worry about the detection below that I've heard other people express concern about. All you really need is a few hundred feet of range below for practical collision avoidance. Even an antenna that you'd think of as pretty well blocked downward, will almost certainly give you sufficient functional range below.
Flarm B and ADSB antenna placement [email protected] Soaring 1 November 17th 16 03:32 AM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 20th 15 12:00 AM
Transponder Antenna & Battery Placement Nimbus or DUO [email protected] Soaring 13 February 25th 09 10:02 PM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 07:53 PM
Nav Antenna Placement Jim Pensinger Home Built 7 October 4th 04 10:55 PM
