Stall spin during aero tow? Std cirrus
Old August 7th 18, 04:08 PM posted to rec.aviation.soaring
Steve Koerner
Default Stall spin during aero tow? Std cirrus
On Tuesday, August 7, 2018 at 7:52:39 AM UTC-7, Dan Marotta wrote:
Releasing is always an option.Â* I would rather land straight ahead,
maneuvering just enough to avoid any hard things on the ground than
stalling on tow.Â* That will kill you.Â* Taking off the wings between two
cars or tractors or whatever will dissipate most of the energy of the
crash and the insurance company can buy you a new glider. Not to mention
you might also kill the tuggie by hanging on in a losing situation.
On 8/7/2018 8:45 AM, Steve Koerner wrote:
This subject comes up every few years on RAS and that's a very good thing. Long ago there was a death on tow with a heavily watered ship that I'm pretty sure was caused by this.
I have already posted a couple times in the past about my own near death experiences I have had dangling from a slow towplane at a remarkably low stalled tow position while slamming the stick back and forth against the stops in Ventus 1 and in ASW27. When this is happening at a very low altitude (as it was), then releasing is not an option.
Several have pointed up the necessity of communicating with the tow pilot. I think it preferable to communicate in writing. Except at contests, I always make sure that the tow pilot has been handed my written towing instruction when I have water ballast. Here's a link to my little towing instruction sheet: https://goo.gl/PwVu71
Dan, 5J
Dan: You're not fully understanding the situation. If your nose is pointed at the sky and you are at a very low altitude, then you will die or be seriously injured if you pull the release. So this discussion is about trying to make sure this doesn't happen to others. I had to figure this out for myself back before there was RAS. If you have altitude to recover, then of course, pull the release and land. Better yet, make sure your tow pilot knows to keep the speed up.
Old August 7th 18, 04:44 PM posted to rec.aviation.soaring
Jonathan St. Cloud
On Tuesday, August 7, 2018 at 7:45:24 AM UTC-7, Steve Koerner wrote:
This subject comes up every few years on RAS and that's a very good thing.. Long ago there was a death on tow with a heavily watered ship that I'm pretty sure was caused by this.
Several have pointed up the necessity of communicating with the tow pilot.. I think it preferable to communicate in writing. Except at contests, I always make sure that the tow pilot has been handed my written towing instruction when I have water ballast. Here's a link to my little towing instruction sheet: https://goo.gl/PwVu71
Where to start. Believe it or not some places do not have comms with the tow plane other than hand signals. I believe the first place is to properly train tow pilots. A couple years ago at Nephi I had a tug where the pilot basically did a short field takeoff and started to climb! I was screaming at him to stay in ground effect as I had not even lifted off!! On the same tow I got into an argument with the pilot when I asked for another ten knots! "do you really want me to add ten knots".."Yes, for fu@ksakes". Years ago at my home airport we had a spat of extremely poorly trained tow pilots, fortunately now all of them are very well trained. As for written instructions, great idea, but I have yet to have a tow pilot actually read or follow the tow chit, other where I wanted to be released. ON my first tow out of Truckee, I filled out their tow chit and since I had not flown there before I checked the box for no thermaling on tow. I have about 1700 hours of glider time, I have never seen a tow plane bank it up 50 degrees to thermal at 800 feet, we played a game of crack the whip until I could dig the boom mike out from under my arm pit.
Old August 7th 18, 05:31 PM posted to rec.aviation.soaring
Dan Marotta
Steve, you're right.Â* I was considering enough altitude to stuff the
nose down and recover.
Dan, 5J
Dan, 5J
Old August 7th 18, 06:04 PM posted to rec.aviation.soaring
Dave Nadler
On Sunday, August 5, 2018 at 10:49:48 PM UTC-4, wrote:
Have there been stall spins during an aero tow?
Yes, and fatalities.
Safety brief from minute 14 of this video:
https://www.youtube.com/watch?v=WIZW...TSR0IGIvNSG84Q
I think I forgot in this brief:
If the tow-plane starts to kite up as you are still rolling or just off,
RELEASE IMMEDIATELY.
Be safe out there,
Best Regards, Dave
Old August 8th 18, 12:01 AM posted to rec.aviation.soaring
Tom BravoMike
How come nobody mentions positive faps in this discussion? Am I missing sth? Are they useless in situations when the tug is too slow? If so, why? Please illuminate me.
Old August 8th 18, 12:16 AM posted to rec.aviation.soaring
A bit helps, a lot of flaps also adds drag, not exactly what you want......so, balancing act.
Old August 8th 18, 12:39 AM posted to rec.aviation.soaring
Dan Daly[_2_]
On Tuesday, August 7, 2018 at 7:16:30 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
@tombravomike. Many gliders have no flaps. They are great - if you have them. Many do not. The Std Cirrus - which this thread started with - does not.
  #29
Old August 8th 18, 01:42 AM posted to rec.aviation.soaring
Dave Nadler
Flaps add a lot of drag. The first time I had a stall on tow,
I pulled down landing flaps, which recovered the stall and
almost put the towplane in the trees. I eased off the flap
and somehow he sped up without hitting anything.
Please do not try this at home.
Be safe out there,
Best Regards, Dave
PS: I think flaps do have the benefit of improving the lift
distribution on tow, which slightly compensates for the bad effects.
  #30
Old August 8th 18, 02:34 AM posted to rec.aviation.soaring
Tom BravoMike
Be safe out there,
Best Regards, Dave
OK, so we are talking here 'nothing or everything'. Landing flaps are on the extreme end. The Ventus manual tells you to go from '0' to '+1' on take off if necessary (eg. with water). And yes, it does depend how much extra power the tow plane has. The golden middle rule applies...
Stall/spin and ground reference maneuvers Bill D Soaring 55 March 11th 14 04:35 PM
Improved shear/stall-spin alarms KiloKilo[_2_] Soaring 23 June 11th 13 11:55 PM
Another stall spin Jp Stewart Soaring 153 September 14th 12 07:25 PM
Stall/ Spin testing the RV-12 cavelamb himself[_4_] Home Built 3 May 14th 08 07:01 PM
Glider Stall Spin Video on YouTube ContestID67 Soaring 13 July 5th 07 08:56 AM
