Js3 jet catastrophic failure.
Old September 17th 18, 08:54 PM posted to rec.aviation.soaring
BobW
Default Js3 jet catastrophic failure.
Good idea. For a lot of things that rotate, especially large or fast,
never good idea to "stand in the plane of rotation" about 90* to shaft
axis when things are spinning. This goes for lathes, lawnmowers, prop
planes, turbines/jets, etc. When things come loose or fly off, they go
out in direction of plane of rotation.
and winch engine water pump mounted fans
I consider this idea - generically avoiding the plane of rotation of rotating
'stuff' whenever reasonably possible - an aspect of ground-based "situational
awareness."
There's a reason clutch scatter shields were developed for cars, rotating
machinery, etc.
Sure the risk is generally low, and I sure don't lose any sleep from fear of
'rotating stuff,' but why provide Murphy additional opportunity?
Bob W.
This email has been checked for viruses by AVG.
https://www.avg.com
  #102
Old September 18th 18, 04:59 PM posted to rec.aviation.soaring
kinsell
On 09/17/2018 08:35 AM, Chris Esselstyn wrote:
On Monday, September 17, 2018 at 9:21:53 AM UTC-5, Dan Marotta wrote:
Did the exiting parts only damage the removable turtle deck?Â* I would
have expected them to fly in all directions radially.
On 9/17/2018 7:29 AM, wrote:
On Saturday, September 15, 2018 at 9:26:48 PM UTC-5, Mike Borgelt wrote:
The production of Halon ceased January 1, 1994, at least in the States.
Yes but it gets recovered from old equipment and can be used in fire extinguishers in certain applications.
I read a great article once about how the USAF looked into substitutes and there weren't any that did not require twice as much bulk and/or weight for same effect.
Last Friday I went out for a day of soaring. During my assembly I started both turbines for a pre-flight test. Both turbines started and had normal run ups. After tow out I was ready for takeoff. Once again the turbines started without any issues, during my takeoff roll one of the engines catastrophically failed. The rear turbine wheel exploded and shrapnel was radiated thru the exhaust cone onto my removable turtleneck. The damage to the aircraft was primarily cosmetic but the turbine is totaled.
Dan, 5J
The shrapnal pattern was radial. The position of the turbine wheel was aft of the trailing edge of the wing so the wings were not damaged. I found two additional small pieces in the engine bay that were lodged into the fiberglass otherwise the majority of the damage was on the aft edge of the turtle deck. There were two more marks on the fuselage right behind the turtle deck joint.
Thank goodness you're OK. With another engine mounted side by side,
seems like it easily could have failed also.
  #103
Old September 19th 18, 01:54 AM posted to rec.aviation.soaring
Branko Stojkovic
Has anyone else seen the new rotary engine under development by a company called Liquid Piston? If jalf of what they are claiming is true, it will be a perfect engine for self launchers.
Branko XYU
  #104
Old September 19th 18, 03:26 AM posted to rec.aviation.soaring
Emir Sherbi
Very nice engine.
I don't see black magic or crazy claims around how it works.
Also i don't believe that it will have the efficiency claimed, but if it is better than the 2 stroke engine they have a winner.
Durability and emissions will be an issue too, but again it seems to be very cheap to produce and replace.
If it works, we will see the Chinese version in some years.
And if it works (at least the same as a 2T) I want it for all the hybrid projects.
  #105
Old July 16th 20, 10:32 AM posted to rec.aviation.soaring
rianmonnahan
On Thursday, August 30, 2018 at 4:46:35 AM UTC+2, Charlie Quebec wrote:
In the last east issue of Gliding Australia there is an incident report shown below.
During the course of a cross country flight, the pilot elected to start the jet sustainer to self retrieve.
The engine started normally, and the pilot tracked for the home airflield The engine failed catastrophically
830ft. AGL and a safe outlanding was conducted.
Things that make you go hmmmm...
I own and operate an EASA certified JS1 w/ an M&D jet sustainer engine in the Alps. I have found the system very reliable, but I don't trust it to save me from an outlanding or, worse, being trapped down low in an alpine valley.
With one exception I kick myself for this very day, I have always started the engine within easy range of an airport. Often I'll start the motor earlier to avoid a situation where I am forced to fire it up down low, when my only option is a field.
I am perhaps too prudent but I fly over some pretty nasty territory. Even when it looks flat, it's not. And the JS1-21m requires some care to land safely and short.
The nicest thing about the jet vs. classical sustainer is this - if it does not start, you have almost 0% added drag with the thing hanging out the fuselage. The proof is in the pudding...
Shortly after I received the beast, I fired up the motor before a cross-country flight to re-assure myself it would start. I usually don't let the automated system retract the motor when the EGT sensor says the hardware is 50C. I do that manually and usually wait for the equipment to cool to much lower tempertures before stowing it.
I must have been distracted with ATC or something. I was flying around the Lyon TMA that day. I shut the engine system off withough retracting the engine. I managed for fly 650 km with the jet windmilling. I did not even notice.
As for fuel, I usually use BP excellium and Cross T 2 stoke oil. I wish I could buy the Shell Gas-Diesel in my kneck of the woods. I've never noticed any start up issues related to altitude or temperature. Then again, I can't imagine any reason why I might start the beast up at 3000m. I can glide at least 100km on that without the motor.
Yes, the mountains are high in the Alps but the valleys are quite low and the density of airports is more than adequate. I can imagine a high and hot start in South Africa or the Western US. Different conditions.
A+
  #106
Old October 26th 20, 10:32 PM posted to rec.aviation.soaring
I've been digging around trying to find out what the process has been for pilots that have added jets other than the MD-TJ 42. This group seems to have a lot of knowledge on this niche subject. The jets are coming down in price and getting a lot more reliable to start, so it seems it would be a more considered option for a lot of pilots. Are there many self-installs, or are there a handful of companies that specialize in the retrofit?
  #107
Old October 26th 20, 11:04 PM posted to rec.aviation.soaring
AS
You didn't say where in the world you are but for the US, Bob Carlton in Moriarty would be my first choice to call, if I wanted to have 'my ride pimped out' with a jet.
Uli
'AS'
P.S.: Bob - as soon as that lottery thing works out for me, I'll be giving you a call! ;-)
  #108
Old October 27th 20, 12:17 AM posted to rec.aviation.soaring
I'm in the US and familiar with Bob. What he does is fantastic, but I'm more curious about some less expensive, less pimped out options. Everything I've seen of his so far uses PBS engines which are extremely expensive. The Jetcats and some other options are much more affordable and I know there are pilots that use them.. I'm wondering how they went about the retrofit.
  #109
Old October 27th 20, 01:11 AM posted to rec.aviation.soaring
Darren Braun
mmm, on the RC side I'm not sure they are much better since I last posted on this thread couple years back. Since then:
-bad egt probe
-bad glow plug
-newish turbine had stiction on the starter motor but if you could reach in and spin the bendix by hand it would start.
-another with bad starter motor.
But no catastrophies. Above were all fixable for a price.
Darren
  #110
Old October 27th 20, 01:57 AM posted to rec.aviation.soaring
I've been operating the microturbines for about 15 years (only up to the 90lb thrust class) and all those problems have been addressed for much more reliability. The EGT probe sheaths were switched to much higher temperature materials and were moved internal to avoid being deflected in any way that would fatigue the material to a point of breaking. The glow plugs were horrible and failed all the time. They used to be the ones used in RC nitro engines but are now ceramic and have proven to last way beyond multiple service intervals. The starter motors have transitioned from high friction brushed motors to virtually zero friction brushless. Same with the fuel pumps. I'm just addressing Darren's list but there are a lot of other improvements. The biggest issue I ever found consistently with starting the microturbines is variations in the atmospheric conditions that don't jive with the programmed start parameters which are set for a most likely "window" of conditions. But there are operator techniques to remedy even this scenario on the fly.
Obviously I'm biased toward the jets but always looking for the failure stories because it motivates me to figure out how the potential for those situations can be minimized.
Boyer retires - Catastrophic mission failure Skylune Piloting 4 July 9th 08 08:49 PM
Study: High Risk of Catastrophic Runway Collisions in U.S. Airports BarneyFife Piloting 11 December 8th 07 11:46 AM
Study: High Risk of Catastrophic Runway Collisions in U.S. Airports BarneyFife Instrument Flight Rules 0 December 5th 07 08:15 PM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
