Js3 jet catastrophic failure.
Old August 30th 18, 06:05 PM posted to rec.aviation.soaring
krasw
Default Js3 jet catastrophic failure.
On Thursday, 30 August 2018 10:21:58 UTC+3, Mike Borgelt wrote:
Don't forget that the Solo company makes aero engines ... and garden equipment, so your Solo engined glider has an engine derived from lawnmower and leaf blower
technology and is made by a company that makes those.
They have nothing in common with garden stuff other than name and logo. Would you rather have two stroke engine from manufacturer who has no experience building them for other applications? I would buy sustainer engine from Briggs&Stratton or Honda in heartbeat...
Old August 30th 18, 06:26 PM posted to rec.aviation.soaring
kinsell
On 08/30/2018 12:54 AM, Tango Whisky wrote:
Le jeudi 30 août 2018 06:37:11 UTC+2, kinsell a écritÂ*:
Actually was a JS1. What i've observed from people flying at a 6000 ft
msl airport is those engines will start on the ground, but not in the
air. Makes for a poor sustainer, if you ask me.
Nonsense.
Thank you Mr Anonymous Tango Whisky for your thoughtful in-depth
analysis of the situation. I'm sure every JS1 owner who has ever had
engine start problems greatly appreciates your input. It's people like
you who make R.A.S. such a wonderful community, where information can be
freely exchanged without being rudely interrupted by ignorant bozos, who
can't believe a problem exists unless they personally have experienced it.
Old August 30th 18, 08:32 PM posted to rec.aviation.soaring
Tango Whisky
My name is Bert Willing, and your post was nonsense. I know quite a couple of jet owners, and they never had a problem of starting their engins attention altitude.
Old August 30th 18, 09:05 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Tango Whisky wrote on 8/30/2018 12:32 PM:
altitude.
I agree with Dave, based on being around several people with jet sustainers at
Parowan and Ely, both 6000' msl. Besides the unreliable starting, they don't
sustain well at high altitudes because the power is marginal for high density
altitudes. A little bit of sink, or a mountain in the way ...
We're not saying EVERY jet has a problem, but a substantial fraction seem to.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old August 31st 18, 02:48 AM posted to rec.aviation.soaring
Mike Borgelt[_2_]
You might actually read my post properly. I said I have no problem with the Solo engines. I was referring to the "model aircraft engine" tag. You could apply the same to Solo as a "leaf blower" engine. You are absolutely sure that the Solo engines aren't built in the same factory by the same machines and people as the garden equipment engines? I would hope they are.
I'd rather have a jet engine built by a "model aircraft engine" manufacturer who has nearly 25 years in the business and has built thousands of engines than a "certified" engine built by a manufacturer who doesn't have any previous experience and built what, a few dozens?
Mind you the M&D engine looks to have the same compressor and turbine as an AMT Titan and is the same diameter. Funny that.
This early in the application of jet engines to gliders I believe certification is dangerous and misleading nonsense. This is EXPERIMENTAL aviation. When the major bugs, shortcomings, maintenance and operational procedures (including best fuel to use) have been worked out (in about 10 years, it might be time to certify these things, however little that concept is worth.
Even the authorities in various countries are beginning to realise that certification has hindered any progress towards safer and more efficient aviation at the light end.
Modern, state of the art gliders should all be regarded more like record setting or racing vehicles, unlike certified bugsmashers.
Old August 31st 18, 03:28 AM posted to rec.aviation.soaring
Ramy[_2_]
I personally helped retrieveing a JS1 which got seriously damaged in a landout following jet failure. I also know at least two more JS1 owners who landed out due to jet failures. In fact, I don’t know any JS1 which did not have jet failure at some point. And this is not limited to JS1. I know of couple more non JS1 jet failures. So no. This is clearly not nonsense.. Looks like jet is not any more reliable than piston.
Ramy
Old August 31st 18, 05:03 AM posted to rec.aviation.soaring
Mike Borgelt[_2_]
On Friday, 31 August 2018 12:28:15 UTC+10, Ramy wrote:
I personally helped retrieveing a JS1 which got seriously damaged in a landout following jet failure. I also know at least two more JS1 owners who landed out due to jet failures. In fact, I don’t know any JS1 which did not have jet failure at some point. And this is not limited to JS1. I know of couple more non JS1 jet failures. So no. This is clearly not nonsense. Looks like jet is not any more reliable than piston.
Ramy
Which engines on the non JS1 failures, Ramy? There appear to be only the engine on the HPH 304 Shark jet which appears to be an AMT Titan and the engine on the PSR system which is an AMT Olympus although they appear to be migrating to the Titan which is a good idea. Best thing with the small jets (and large ones) is not to run at 100%. using a larger engine lets you do that.
Old August 31st 18, 01:42 PM posted to rec.aviation.soaring
Emir Sherbi
El miércoles, 29 de agosto de 2018, 23:46:35 (UTC-3), Charlie Quebec escribió:
In the last east issue of Gliding Australia there is an incident report shown below.
During the course of a cross country flight, the pilot elected to start the jet sustainer to self retrieve.
The engine started normally, and the pilot tracked for the home airflield The engine failed catastrophically
830ft. AGL and a safe outlanding was conducted.
Things that make you go hmmmm...
Everything will eventually fail, always.
Even the electric motor, that is almost fail proof, will in in time burn a phase or blow a bearing.
You have to check the statistics, not the accidents in absolute numbers.
Turbines are very "simple" and robust systems.
See if you find ratios like:
Accident/Hours; Start attempts/Starts made, Land outs/hours.
Old August 31st 18, 01:53 PM posted to rec.aviation.soaring
Dave Nadler
Or have electronics failures due to less-than-adequate design and testing, grrr...
It is quite hard to get real statistics.
I certainly know of plenty of jet problems from many owners.
Most recent serious stats I know of he
http://www.nadler.com/public/DeRese_...ilplanes.p df
Hope that helps,
Best Regards, Dave
Old August 31st 18, 04:29 PM posted to rec.aviation.soaring
Dave - those statistics are from 2008 so before jets became popular. I think jets will eliminate many of the problems encountered with traditional systems, but the e-systems may eliminate them completely. It will be interesting for the project to be re-run with a decades worth of improvements to the self-launch and particularly sustainer systems.
Boyer retires - Catastrophic mission failure Skylune Piloting 4 July 9th 08 08:49 PM
Study: High Risk of Catastrophic Runway Collisions in U.S. Airports BarneyFife Piloting 11 December 8th 07 11:46 AM
Study: High Risk of Catastrophic Runway Collisions in U.S. Airports BarneyFife Instrument Flight Rules 0 December 5th 07 08:15 PM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
