CFI-G
Old September 30th 18, 09:55 PM posted to rec.aviation.soaring
Mike Reid
Default CFI-G
I just took the add on CFI - G test. You want to ask for test code AFG. You will also need an endorsement from a CFI-G if you do home study. Burt's math is off a little - you can miss seven and still pass.
Mike Reid
Old September 30th 18, 11:31 PM posted to rec.aviation.soaring
Tango Eight
Default CFI-G
Whole ball o' wax:
https://www.faa.gov/training_testing...ing_matrix.pdf
T8
Old October 2nd 18, 12:08 AM posted to rec.aviation.soaring
Default CFI-G
On Friday, September 28, 2018 at 7:50:50 PM UTC-7, Joe Rizzo wrote:
Hi folks. Passed my Commercial Glider check ride today.
I'm currently a CFI-A. Do I need to take a written test before taking the CFI-G checkride?
Joe
Joe,
You might want to check out my online course "Guide to Becoming a CFI-G". The information in this course can also be a useful reference for new, or even experienced CFI-Gs. The course provides links to all of the reference material an instructor will need, including FARs, ACs, FAA Manuals, Endorsements, Progress Records, Phase Tests, Training Checklists, and Flight Review materials. In addition, you can download over 180 illustrations that you can use for teaching both the flight and knowledge areas to your students.
The course covers:
Requirements
Instructor Responsibilities
Record Keeping
Reference Materials
Advice for New Instructors
Instructional Materials
Flight/Knowledge Training including lesson plans
Performing Flight Reviews
Using IACRA
If you are interested, you can follow this link to learn more.
https://academy.gliderbooks.com/cour...coming-a-cfi-g
-Russell Holtz
Old October 2nd 18, 12:22 AM posted to rec.aviation.soaring
Default CFI-G
What about the other way around? Im a CFIG and a PPSEL, what do I have to have for a add on CFI A?
Old October 2nd 18, 01:53 AM posted to rec.aviation.soaring
Mike Reid
Default CFI-G
First you'll need a commercial pilot certificate and instrument rating, then you can take the 25 question AFA (Additional Flight Instructor Airplane) written when you have the required endorsement.
Old October 2nd 18, 05:45 AM posted to rec.aviation.soaring
Default CFI-G
Basically your CFIG means nothing going power. A little flight time, but I believe no tests or anything else counts.
Old October 2nd 18, 11:58 AM posted to rec.aviation.soaring
Tango Eight
Default CFI-G
Only IACRA knows for sure... BWAHAHAHAHAHAHA (semi sarcasm, in fact, you aren't going to get very far with your IACRA application if you don't have the right material to feed it.)
Burt had the best advise.
That said, I'm trying to improve my own understanding.
It looks like:
You don't have to take FOI.
You must pass CAX (ref https://www.faa.gov/documentLibrary/...er_8080.6H.pdf)
You must pass AFA. Odd that this isn't called out in 8080.6
T8
Old October 2nd 18, 03:42 PM posted to rec.aviation.soaring
Default CFI-G
On Tuesday, October 2, 2018 at 12:45:16 AM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
One bonus of having the CFI-G is he will have a wider range of examiners to choose from for the CFI-A as it isn't initial CFI ride.
Old October 20th 18, 08:40 PM posted to rec.aviation.soaring
Joe Rizzo
Default CFI-G
Thank you for the info folks!
Old December 9th 18, 02:11 PM posted to rec.aviation.soaring
Joe Rizzo
Default CFI-G
Good to see the folks who write the soaring magazine are reading this. Nice Article, thank you.
