Refinishing Ventus b Fuselage
Old October 16th 18, 03:41 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default Refinishing Ventus b Fuselage
On Monday, October 15, 2018 at 10:57:20 PM UTC-7, Ian wrote:
On 2018/10/16 01:54, Richard Pfiffner wrote:
Rolled on two coats of Duratec Vinyl ester surfacing primer, sanding tomorrow.
Pictures:
http://www.craggyaero.com/ventus.htm
Nicely documented project. I hope you don't get "arithmetic fatigue"
adding up all the hours.
Please advise the weight of the fuselage before you started verses that
when you finished. Also the moment arm balance for the rudder, before
and after. Be kind to the next owner and make sure it is fully
documented in the log books. This is always the "unknown" when looking
at a refinished glider.
I have all the weights before the refinish.
Richard
www.craggyaero.com
Old October 16th 18, 06:05 PM posted to rec.aviation.soaring
What did you mean by this?
"6 hrs Epoxy and glass beads to fair vertical stabilizer and rudder."
Were you filling low spots, or did you build up a lip at the trailing edge of the vertical stabilizer to make a fairing to cover the leading edge of the rudder?
Thank you for documenting this project. I prefer to soar, but I also love working on gliders and may take on a refinish project someday. Just like teaching the next generation to fly, we need to spread this skill too.
-Doug.
Â*
Old October 16th 18, 07:13 PM posted to rec.aviation.soaring
-Doug.
Â*
Faired the surface with epoxy and glass beads. When you takeoff the coating you will find not all is flat.
Richard
www.craggyaeo.com
Old October 16th 18, 09:19 PM posted to rec.aviation.soaring
Primer is rolled on to force it into the million pinholes left after sanding. If the first coats are sprayed many pinholes are bridged and show up again after the first sanding. How smooth it is doesn't matter too much.
UH
Thanks for telling me what does not matter to me. I had no idea!
I assisted UH in refinishing my ASW 24 wings last winter. I, too, was a little concerned with rolling anything on the wings we had so carefully templated before we started. Surely spraying was necessary to get the accurate profile we were after.
He's right; the rolling imperfections sanded out relatively quickly. I'm not sure how many more pinholes would have shown up if he hadn't been so diligent about forcing the primer-filler into the structure. But the relatively few that remained were a pain to touch up individually, especially as we kept finding more at each subsequent stage. The finished wings justified his approach and after three long contests this year, I couldn't be happier with the performance.
Chip Bearden
Old October 17th 18, 09:33 PM posted to rec.aviation.soaring
On Tuesday, October 16, 2018 at 1:19:04 PM UTC-7, wrote:
Primer is rolled on to force it into the million pinholes left after sanding. If the first coats are sprayed many pinholes are bridged and show up again after the first sanding. How smooth it is doesn't matter too much..
UH
Chip Bearden
More progress, sanding next step spray 1 coat of vinyl ester surfacer.
Richard
www.craggyaero.com
Old October 18th 18, 08:41 PM posted to rec.aviation.soaring
Ian[_2_]
Are you sanding wet or dry?
How do you keep the floor so clean?
And when do you find time to spend on RAS ;-)
Old October 18th 18, 09:07 PM posted to rec.aviation.soaring
Sanding dry, vacuum up the floor.
Richard
www.craggyaero.com
Old October 18th 18, 09:27 PM posted to rec.aviation.soaring
Richard
www.craggyaero.com
Richard, please don't throw away the fuselage mount/rotating system before checking with me? I might do mine someday...
  #29
Old October 23rd 18, 12:38 AM posted to rec.aviation.soaring
Richard
www.craggyaero.com
More progress sprayed hopefull the last coat of vinyl ester surfacing primer. Therapy sanding tomorrow.
Richard
www.craggyaero.com
  #30
Old October 23rd 18, 01:26 PM
POPS POPS is offline
Member
First recorded activity by AviationBanter: Dec 2010
Quote:
Originally Posted by Richard Pfiffner[_2_] View Post
Pictures and process for refinishing a ventus b fuselage. Work in progress pictures and process as work is completed.
Richard
www.craggyaero.com
Yo, that's a great pic log. I know you said you'd never do it, but when your all finished you could roll your old trusty-rusty all-terrain tow vehicle in there, hook it onto that lazy-susan contraption and put the spit shine to that sucker!
Just think how Gooood yud look coming and going!
Just think about it...
refinishing Ventus 2cm- wing profile [email protected] Soaring 20 November 6th 11 12:15 AM
refinishing Stig Pedersen Soaring 1 November 27th 05 04:50 PM
refinishing Stig Pedersen Soaring 1 November 26th 05 09:16 PM
Second speaker in Ventus 2b/c fuselage [email protected] Soaring 3 September 14th 05 05:41 PM
REFINISHING Ventus B Soaring 32 December 3rd 03 10:14 PM
