Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Outside loops in a Decathlon
Old March 2nd 05, 05:59 PM
Doug Carter
yupyupxav wrote:
DOug,
I just arrived on this forum, but something really important is not to
pull too much positive G immediately after gone negative. -3 to +5 is
physiologically more difficult than 1 to 9. (loss of conciousness)
Xav
Great point! I suppose that the negative G load causes the blood
vessels to swell and if you go hard positive you are going to gray out
at a lower G load. I can really feel this difference.
Old March 8th 05, 05:50 PM
Andrew Boyd
Suggested training program:
Exercise #1: from level upright, 1/2 roll inverted, pause,
then push to 45 up inverted. Pause. 1/2 roll to upright
45 up. Gently lower nose to level upright again. Descend
to regain airspeed. Repeat.
Exercise #2: from level upright, 1/2 roll inverted. Push
past 45 up to vertical upline. Hammerhead to vertical
downline, pull level. Repeat.
Exercise #3: from level upright, 1/2 roll inverted. Push
past 45 up, past vertical to level upright, completing
1/2 outside loop up. Pause without sagging. Descend to
Exercise #4: from level upright, 1/2 roll inverted. Push
past 45 up, past vertical, past level upright to 45 downline,
upright. Pause. Pull level. Not much different than #3, really.
Exercise #5: from level upright, 1/2 roll inverted. Push
upright. 1/2 roll inverted on 45 downline. Push to level
inverted. Repeat - you can skip 1/2 roll on entry. You
are now doing a full outside 1/2 cuban-8.
Exercise #6: from level upright, 1/2 roll inverted. Push
past 45 up, past vertical, past level upright, past 45 downline,
past vertical downline - don't hesitate - to level inverted.
You've just completed your first solo outside loop!
As others have mentioned, a pull right after a push is a
sure-fire G-loc trap.
ATP www.pittspecials.com/images/takeoff.jpg
"Contests? We don't need no stinkin' contests!"
Old March 8th 05, 07:14 PM
Thanks Andrew, looks great.
Info regarding Super Decathlon Markus Feyerabend Aerobatics 10 September 4th 04 07:03 AM
inverted spin recovery explanation Alan Wood Aerobatics 18 August 19th 04 03:32 PM
Snaps in the Decathlon Dave Russell Aerobatics 12 April 14th 04 06:14 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 07:27 AM
