TMG around San Diego
Old December 8th 04, 12:08 AM
Steve Hill
I got the self launch endorsement because my insurance required me to for
operating the DG-400...but it sure strikes me as odd that if you have an
ASEL certificate...and a glider rating...that the combination of the two
would not suffice...add to that a high-performance and taildragger sign
off...and I never have understood what the self launch sign off was intended
to accomplish.
Maybe it's me, but it sure seems silly when you have pilots with both power
and glider ratings. I can see the self launch sign-off if you only have a
Glider certificate...
Steve.
Old December 8th 04, 12:36 AM
Larry Dighera
On Tue, 07 Dec 2004 20:25:01 +0100, Stefan
wrote in ::
I may be wrong, but I think the Stemme V10 is legally not a TMG.
But is a remarkable piece of artistic engineering.
http://www.stemme.de/
"The S 10-VT is the easiest to handle and most good-natured open
class sailplane."
The S8 is the TMG: http://www.stemmewest.com/pages/S8_E.pdf
Old December 8th 04, 04:15 AM
Mark James Boyd
It seems like there's really only one thing to train an ASEL pilot
trainsitioning to self launch: if the engine quits on takeoff,
then the extended engine is just a huge airbrake, so your glide
ratio goes to poop and the pitch forces are changed. Recognise this
and make your choice to turn back or
go straight accordingly, not based on regular glide.
I'm not self-launch endorsed, but other than this and the fact your
engine is probably a $10,000 one cylinder chainsaw engine that causes
double vision, I can't figure what is so different...
flame away
to accomplish.
Steve.
Mark J. Boyd
Old December 8th 04, 06:44 AM
Eric Greenwell
ratio goes to poop
It's worse than having the engine retracted, but nothing like having the
airbrakes extended.
Actually, the pitch forces don't change, but the glider does tend to
pitch up a bit with power loss. Like a rope break, the pilot must put
the nose down to maintain airspeed.
Recognise this
For my glider, and I think for most "engine on a stick" gliders, an
extra 100' is _plenty_ over what the pilot would use for a turn-around
height while towing.
Most of the self-launchers use a two cylinder engine. The Russia uses a
single cylinder and probably has the most vibration; the ASH 26 E uses a
single rotor wankel, and has the least vibration.
Even the Russia, at about 28 horsepower, would make one heck of a macho
chainsaw!
that causes
Perhaps the biggest difference is many of them will go up on their nose
if full power is applied right at the start of the roll. Even if they
don't, the reduced weight on the tail wheel can turn a cross-wind
takeoff into a thriller. It only takes once to realize you need to be a
little slower with the throttle at the start.
Taxiing can be a challenge, since your "wheel track" is 25-30 feet wide,
and you don't have differential braking to help you around the corners.
Aside from these, and if the engine keeps running, it's easier than towing.
Eric Greenwell
Washington State
USA
Old December 8th 04, 08:28 AM
Bert Willing
The Stemme is a TMG under German rules.
Bert Willing
ASW20 "TW"
"Stefan" a écrit dans le message de news:
The type category "Touring Motor Glider" does not exist in the US.
I thought so. But the original poster lives in Germany, at least his name
and email address point in this direction. And as he wrote that he would
like to have the TMG rating, I think this question is of interest to him.
Stefan
Old December 8th 04, 07:17 PM
Steve Hill
Mark James Boyd Wrote:
" I'm not self-launch endorsed, but other than this and the fact your
engine is probably a $10,000 one cylinder chainsaw engine"
Well...I'm not sure if this is intended to be flippant or not...but I'll say
my DG uses a two cylinder, dual CDI ignition, dual carburetor Rotax...about
505 cc's. The engine is very nicely mounted on isolation dampeners and
really runs very smoothly, though it does have a slight harmonic in the
4,000rpm range you feel when you shut it down...I think the cost is easily
considered as follows: this years 170 hours of soaring used 4.2 engine hours
( 21 gallons of super unleaded) If I'd average 3 three hours per flight that
would be about 57 tows...say $30 a tow to be safe...around $1700 for the
year...I'll leave out the 8 or 9 retrieves, when I either went straight out
somewhere and landed, or simply got nailed and had to land
somewhere...either way, retrieve costs could easily add up to a substantial
cost, but I just started up and headed home...in my 700 hours of flying the
DG-400 I have only had one very minor engine complication, self remedied,
but trying to be unbiased. I would assert that the dollar per flight hour
vs. freedom from tow lines and the benefit of going when and where I want is
worth the minor investment and I believe it actually pays for itself over a
5 year period.
My Stihl on the other hand..also has CDI igition AND mixes the fuel/oil for
me...I sure wish the DG did that.
Steve
Old December 8th 04, 07:29 PM
Gig Giacona
"Larry Dighera" wrote in message
wrote in ::
class sailplane."
I know nothing about Gliders but I went and looked at the PDF document
above. CS prop, retractable gear, 170 knots. That is impressive.
My question. Can it be flown by a PP-SEL or do you have to have a glider
rating?
Old December 8th 04, 08:51 PM
Mark James Boyd
Steve (and others),
I put a tag for "flame suit on" and a winkey face under this comment,
but it didn't make it to the post.
C'mon, you know I love you engine lovers. I have an engine
myself (well, a continental A-75). Sorry if I offended,
Can I be in the club again?
5 year period.
Steve
Mark J. Boyd
Old December 8th 04, 11:57 PM
Steve Hill
Offended...?? Me..?? man...I got WAY thicker skin than that....you'd have to
be talking about my mama...to offend me...I know...I know...when she sits
around the house....she REALLY sits around the house....
Nah...I just thought I'd set the record straight about my chainsaw
engine...oops...self launcher...
Ciao for now.
Steve.
Old December 9th 04, 01:50 AM
Eric Greenwell
class sailplane."
rating?
In the USA, you need a glider rating with a self-launch enddorsement.
Other countries treat it quite differently.
Eric Greenwell
Washington State
USA
API - San Diego. Approach gremlin mortally wounded... Beav Rotorcraft 0 October 14th 04 12:17 AM
Military jet crashes in San Diego Bay Otis Willie Military Aviation 0 August 28th 04 12:24 AM
What is carrier beside USS John C. Stennis (CVN 74) at San Diego ? Dong Military Aviation 7 January 9th 04 06:58 PM
San Diego Pilots Yahoo Group mutts Piloting 0 October 28th 03 02:32 AM
Good instrument program near San Diego? [email protected] Instrument Flight Rules 1 October 26th 03 03:59 AM
