I have a couple of ipaq 3765's and two copies GNII. (yes both paid for and
legal) Both are used on a CAI 302. One is coded to the CAI 302 and the other to the IPAQ I just purchased a navman and I am having trouble getting GNII to work with it. I am using it on the IPAQ coded copy of the software. It detects the gps but just stays in "waiting for GPS" Anyone with any experience with this???? Joe Hyde |
Joe,
I had a NAVMAN before I got my GPS-NAV and GNII. The NAVMAN outputs the NMEA stream on COM 6. I worked with Henryk to get his program, GPS_LOG, to accept the NAVMAN output. You may need to work with Paul Remde to get GNII to recognize COM 6. I haven't tried the NAVMAN/GNII combo. Hope this helps. Bill Richardson 4W Joseph L. Hyde wrote: I have a couple of ipaq 3765's and two copies GNII. (yes both paid for and legal) Both are used on a CAI 302. One is coded to the CAI 302 and the other to the IPAQ I just purchased a navman and I am having trouble getting GNII to work with it. I am using it on the IPAQ coded copy of the software. It detects the gps but just stays in "waiting for GPS" Anyone with any experience with this???? Joe Hyde |
I am having probs with Navman as well is it a navman PIN
"John Galloway" wrote in message ... The newer versions of GN11 software offer the facility to select Com ports 1 to 9 on the PDA Johnn Galloway At 18:30 19 December 2004, wrote: Joe, I had a NAVMAN before I got my GPS-NAV and GNII. The NAVMAN outputs the NMEA stream on COM 6. I worked with Henryk to get his program, GPS_LOG, to accept the NAVMAN output. You may need to work with Paul Remde to get GNII to recognize COM 6. I haven't tried the NAVMAN/GNII combo. Hope this helps. Bill Richardson 4W Joseph L. Hyde wrote: I have a couple of ipaq 3765's and two copies GNII. (yes both paid for and legal) Both are used on a CAI 302. One is coded to the CAI 302 and the other to the IPAQ I just purchased a navman and I am having trouble getting GNII to work with it. I am using it on the IPAQ coded copy of the software. It detects the gps but just stays in 'waiting for GPS' Anyone with any experience with this???? Joe Hyde |
Even once you have selected the correct com port you may have to change the
speed from 4800 to 57600 (I think) for the Navman. Basil "Mal" wrote in message ... I am having probs with Navman as well is it a navman PIN "John Galloway" wrote in message ... The newer versions of GN11 software offer the facility to select Com ports 1 to 9 on the PDA Johnn Galloway At 18:30 19 December 2004, wrote: Joe, I had a NAVMAN before I got my GPS-NAV and GNII. The NAVMAN outputs the NMEA stream on COM 6. I worked with Henryk to get his program, GPS_LOG, to accept the NAVMAN output. You may need to work with Paul Remde to get GNII to recognize COM 6. I haven't tried the NAVMAN/GNII combo. Hope this helps. Bill Richardson 4W Joseph L. Hyde wrote: I have a couple of ipaq 3765's and two copies GNII. (yes both paid for and legal) Both are used on a CAI 302. One is coded to the CAI 302 and the other to the IPAQ I just purchased a navman and I am having trouble getting GNII to work with it. I am using it on the IPAQ coded copy of the software. It detects the gps but just stays in 'waiting for GPS' Anyone with any experience with this???? Joe Hyde |
Hi,
There are 2 issue when using the NAVMAN. First, you must have the correct comm port selected. The number of the comm port depends on the Pocket PC, not the NAVMAN. You can use a free utility called "Crux_View.exe" to determine which comm port is used to get NAVMAN data into your Pocket PC. The utility is available he http://www.cumulus-soaring.com/gps.htm The recent beta versions of Glide Navigator II allow you to select an comm port (1 through 9). The 2nd issue is the baud rate. The NAVMAN sends GPS data at a high rate (57 K I believe) - it does not comply with the NMEA specification for 4800 baud. Glide Navigator II does not currently allow the selection of a high baud rate. It should be easy to add that feature but we haven't yet because every other GPS I've used works at 4800 baud - and I've tested many, many GPS units. Let me know if you need to have us add the 57 k baud rate option to GN II and I'll see what we can do. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "basils27" wrote in message news:1103539678.412728adf97c4f4f9f6ce4046f571aa0@t eranews... Even once you have selected the correct com port you may have to change the speed from 4800 to 57600 (I think) for the Navman. Basil "Mal" wrote in message ... I am having probs with Navman as well is it a navman PIN "John Galloway" wrote in message ... The newer versions of GN11 software offer the facility to select Com ports 1 to 9 on the PDA Johnn Galloway At 18:30 19 December 2004, wrote: Joe, I had a NAVMAN before I got my GPS-NAV and GNII. The NAVMAN outputs the NMEA stream on COM 6. I worked with Henryk to get his program, GPS_LOG, to accept the NAVMAN output. You may need to work with Paul Remde to get GNII to recognize COM 6. I haven't tried the NAVMAN/GNII combo. Hope this helps. Bill Richardson 4W Joseph L. Hyde wrote: I have a couple of ipaq 3765's and two copies GNII. (yes both paid for and legal) Both are used on a CAI 302. One is coded to the CAI 302 and the other to the IPAQ I just purchased a navman and I am having trouble getting GNII to work with it. I am using it on the IPAQ coded copy of the software. It detects the gps but just stays in 'waiting for GPS' Anyone with any experience with this???? Joe Hyde |
| Thread Tools | |
| Display Modes | |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Phoenix AIM-54A (QUESTION) | Krztalizer | Naval Aviation | 10 | February 23rd 04 08:22 AM |
| Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 10:40 PM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
| Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 01:14 AM |
