Cambridge vario audio box wanted
Old May 29th 19, 03:57 PM posted to rec.aviation.soaring
Geoff Minors
Default Cambridge vario audio box wanted
I am looking for the audio box that goes with the Cambridge vario. Anybody got one they can sell me?
Thanks
Old May 29th 19, 06:12 PM posted to rec.aviation.soaring
Any particular vario?
I believe the vario model sorta prelecates the model audio.
Old May 30th 19, 12:59 PM posted to rec.aviation.soaring
Thanks
I think I have one from a previous installation, working when removed. Will take a look and let you know.
mike
Old May 31st 19, 12:24 AM posted to rec.aviation.soaring
Geoff Minors
Thanks
mike
Thanks
Old May 31st 19, 01:16 AM posted to rec.aviation.soaring
JS[_5_]
There was an AU-10 and AU-20. Believe the -20 fixed this problem and by now all have likely been modified, but...
While the unmodified AU-10 will work fine in a glass panel, using it in a metal panel will cause an electrical ground loop (two different paths to ground).
You may notice the vario deflecting when the radio transmits. If that happens, look at the ground trace near the mounts for the AU circuit board to see where to cut.
Just remembered a head-scratcher from 32 years ago?
Cambridge vario audio [email protected] Soaring 2 June 4th 17 02:50 PM
Cambridge Vario audio [email protected] Soaring 1 June 3rd 17 12:59 AM
Wanted: Cambridge Mark IV Vario and Flight Director with Audio [email protected] Soaring 5 May 20th 16 08:15 PM
CAV 11 Audio Vario/no Audio ideas? (Cambridge) Gregg Leslie[_2_] Soaring 3 June 4th 11 12:08 AM
Schematics for Cambridge CVS50 vario and audio unit? Or anyoneselling a similar working audio variometer? Bret Soaring 0 August 30th 10 04:24 AM
