source for clips or sleaves for Hotelier linkages
Old August 3rd 19, 09:26 PM posted to rec.aviation.soaring
Default source for clips or sleaves for Hotelier linkages
Dental floss is very cheap, works, very available.
Braided small fishing line (NOT monofilament) also works.
Yes, a hot glue dab or small dab of ShooGlue (or similar.....thickened silicone sealant) to hold "string" to both sides is great.
Weak enough to break in a bind, cheap, prevents dropping pins/clips while assembling.
  #32
Old August 3rd 19, 11:41 PM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
Quote:
Originally Posted by Dan Marotta View Post
On 8/3/2019 4:29 AM, Delta8 wrote:
After going the pin route the clips are a god send . You don't need to
tie anything onto them to prevent them from falling into the abyss .
.... Until one slips out of your fingers.
Dan, 5J
See T8's posted pictures . They stay attached to the push rods . There are tiny factory holes in the fitting . The end of the clip is pushed through the hole and bent at a 90 degree angle.
  #33
Old August 4th 19, 01:53 AM posted to rec.aviation.soaring
John Foster
On Saturday, August 3, 2019 at 8:53:11 AM UTC-6, JD Williams wrote:
The phoebus connections are made outside the fuselage, if dropped the pins fall to the ground. I keep mine in an altoid tin along with the pin for the Jesus rod. Gives me one more positive check that pins are in. Box empty, pins in.
Any sources for plastic hemostats (with bent ends)? On the phoebus you have to reach into the wing and pull the brake rod out for hookup. I plasti-dipped a set of pliers but would rather have a plastic set. I was told that using pliers could score the connector ball, not desirable.
JD
JD, I just got done making this tool.
https://photos.app.goo.gl/t8A6Mgw592vHA2dA8
  #34
Old August 5th 19, 03:47 AM posted to rec.aviation.soaring
Dan Marotta
Neat tool!Â* But couldn't you simply move the control surface to gain
access to the rod end?Â* Or am I missing something?
JD
Dan, 5J
  #35
Old August 5th 19, 07:39 AM posted to rec.aviation.soaring
John Foster
JD
Dan, 5J
For the aileron, yes. However, the spoilers when closed, have the end of the rod retracted inside the wing, and you have to pull it out to connect it prior to sliding the wing all the way in. It is a real challenge to pull it out to hook it up. This tool makes it easier. In the past, I have used a bent wire coat-hanger, but I fear that constant use of that could call the ball of the connector.
  #36
Old August 5th 19, 03:03 PM posted to rec.aviation.soaring
Dan Marotta
Excellent!Â* (But a really ****ty design on the glider.)
JD
Dan, 5J
Dan, 5J
  #37
Old August 5th 19, 03:24 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Most Fleabi (Plural of Phoebus) have chipped away finish at the inboard end of the upper surface dive brake. You stick something like a thin screwdriver blade in to pop the spoiler up, then pull it up to fully extended, which puts the control rod end just outside the wing root rib. Then, with the dive brake handle fully deployed in the cockpit, you can just connect the two.
Not too unlike the aileron connections on a Nimbus 3 at the inboard/outboard panel joint.
Steve Leonard
  #38
Old August 8th 19, 02:55 AM posted to rec.aviation.soaring
Charlie Quebec
Before I fitted wedekind sleeves on my DG, I had R clips tied to the pushrods with fishing line.
It was very difficult to fit them, impossible to see whilst fitting. It was also difficult to keep hands free of grease in the process making it harder.
Now, with the sleeves, the whole hookup takes less than a minute, against 10-15 minutes of fiddling.
  #39
Old August 8th 19, 08:52 PM posted to rec.aviation.soaring
John Foster
Fortunately the arrangement of these connections is different with the Phoebus, making the connections outside, between the wing and the fuselage. Lots of room and direct visualization of the connection.
  #40
Old August 18th 19, 03:01 PM posted to rec.aviation.soaring
JD Williams
John,
How did you make it? 3D print? Thats a perfect solution!
JD
Source for L'Hotellier Safety Clips George Haeh Soaring 23 January 29th 19 12:20 AM
L'Hotelier Fitting Safety Pins Dan Marotta Soaring 20 October 17th 16 01:40 AM
Complete Hotelier Connections For Sale (Brand New) $400 Scott Alexander[_2_] Soaring 2 July 19th 12 10:40 PM
Hotelier safety sleeves [email protected] Soaring 6 August 31st 07 03:41 PM
Lycoming throttle linkages Evan Carew Home Built 0 September 29th 04 01:58 AM
