source for clips or sleaves for Hotelier linkages
Old August 19th 19, 05:25 PM posted to rec.aviation.soaring
John Foster
Default source for clips or sleaves for Hotelier linkages
On Sunday, August 18, 2019 at 8:01:26 AM UTC-6, JD Williams wrote:
John,
How did you make it? 3D print? Thats a perfect solution!
JD
I ordered 6" lengths of 3/4" Delrin rod off Ebay, and then drilled the end first with the smallest neck diameter, and then the larger ball diameter at the appropriate distance. Then it was hand-shaping with a cone grinding stone in a Dremmel Tool.
  #42
Old August 22nd 19, 01:48 AM posted to rec.aviation.soaring
JS[_5_]
Back to the original problem.
I've now used the white LS sleeves.
They're really simple things. Perhaps could be manufactured from a Delrin rod in the same way John made that tool.
Source for L'Hotellier Safety Clips George Haeh Soaring 23 January 29th 19 12:20 AM
L'Hotelier Fitting Safety Pins Dan Marotta Soaring 20 October 17th 16 01:40 AM
Complete Hotelier Connections For Sale (Brand New) $400 Scott Alexander[_2_] Soaring 2 July 19th 12 10:40 PM
Hotelier safety sleeves [email protected] Soaring 6 August 31st 07 03:41 PM
Lycoming throttle linkages Evan Carew Home Built 0 September 29th 04 01:58 AM
