Tire pressure monitor
Old August 16th 19, 05:12 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Tire pressure monitor
Steve Koerner wrote on 8/15/2019 4:59 PM:
As it turns out, I just recently addressed this issue for the JS3 tailwheel.. The retractable tailwheel is quite small. The air volume is such that any attempt to put a gauge on it will drop the pressure quit a lot. Also being so small, I found it hard to judge by eye.
The method I came up with uses a machinist outside caliper to measure tire bulge. It's easily understood with these pictures:
https://photos.app.goo.gl/uyt8BgJWRSKKHuj6A
There's a certain skill required to use the machinist caliper -- the key is zero spring pressure. Accuracy is about 5 PSI.
I was able to accomplish the calibration without any reference to dimensional measurements (inches or mm).
Since this was just devised a couple weeks before the OP came on with his question, it hasn't had much field testing. We'll see if this is a good solution after I've used it awhile.
Clever! But, are there solid tire wheels that could replace the pneumatic one? Or
get it filled with foam?
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old August 16th 19, 05:09 PM posted to rec.aviation.soaring
Steve Koerner
I know some owners have talked about having the tailwheel foamed. I don't really know if foam is good enough or not. A key function of the tailwheel tire is to protect the structure against hard impacts. Spring and damping dynamics of foamed tires certainly differ from air. I'm willing to make little design deviations like that only when I'm personally very sure that there won't be adverse consequences.
Old August 16th 19, 05:35 PM posted to rec.aviation.soaring
Bob Kuykendall
One of the best real-world application of the Observer Effect I've heard of in a while.
--Bob K.
Old August 16th 19, 06:01 PM posted to rec.aviation.soaring
Dan Marotta
Another application of Heisenberg's Uncertainty Principle.
--Bob K.
Dan, 5J
Old August 16th 19, 09:15 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Steve Koerner wrote on 8/16/2019 9:09 AM:
A flat tail wheel has different dynamics, too :^)
Perhaps the tail mount is designed to absorb the energy and crumple before the
structure? I'd contact the factory with a list of substitutes (foamed, solid
rubber/urethane, etc) you'd like use, and get their blessing. I suggest a
polyurethane scooter wheel, which are available in several sizes, and work well
with the ASH 26 E steerable tail wheel, based on the owners' group experience:
strong and good shock absorbing.
Old August 16th 19, 11:43 PM posted to rec.aviation.soaring
Steve Koerner
Eric, Quite sure the factory isn't interested in blessing a chinese scooter wheel when the design presently calls for an aircraft wheel with aircraft tire. Anyway, there's no actual problem with the present wheel that I know of, so I haven't a motive for pursuing an alternative. The challenge of measuring air pressure is a small matter and hopefully I've got that put to bed.
Tire Pressure Monitoring Systems for Trailers AS Soaring 6 July 11th 18 04:00 AM
PW-5 Main Tire Pressure? JohnDeRosa Soaring 3 June 23rd 13 09:38 AM
Accurate tire pressure gage? Kurt Thams Soaring 6 September 25th 12 11:17 PM
Tire tread wear vs inflation pressure Ben Jackson Owning 22 October 6th 06 04:35 AM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
