Tow plane types/mods for high density altitude glider towing
Old August 16th 19, 02:20 AM posted to rec.aviation.soaring
Default Tow plane types/mods for high density altitude glider towing
On Tuesday, August 13, 2019 at 11:38:43 AM UTC+10, son_of_flubber wrote:
What are your favorite aircraft types (and modifications) for glider towing in high density altitude and/or short runways?
eTugs are now certified in Australia and are in production. Tow costs are half avgas powered PA25 - 235 tugs.
Michael
  #32
Old August 16th 19, 03:59 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Michael
Michael, are they producing a two seat version of the eTug?
Cheers,
Craig
  #33
Old August 16th 19, 06:18 AM posted to rec.aviation.soaring
Yes, there is a one and one half seater (single controls) has been converted, but remember the conversions are only of the existing aircraft. Aircraft are not being made from scratch.
Michael
  #34
Old August 16th 19, 07:47 AM posted to rec.aviation.soaring
Per Carlin
If you cant tow your glider behind a Turbo Čmelák, then shoud it not been towed at all
http://www.flugzeuginfo.net/acdata_p...ta_z37t_en.php
  #35
Old August 16th 19, 09:30 PM posted to rec.aviation.soaring
George Underhill
I saw a friend towed (pulled) aloft in a IS28b2 Lark by Steve Wolf in his 450hp Samson biplane at an airshow in Spokane, WA. It was an impressive climb angle, to say the least.
  #36
Old August 22nd 19, 04:50 PM posted to rec.aviation.soaring
2G
I only consume 1/2 gallon to launch my ASH31Mi motorglider to 3kft (the same was true for the 26e and DG400, and most every other self-launcher that I can think of, well maybe not the Space Shuttle). So, for a 4 hour flight my "burn rate" is 1 pint per hour.
Tom
  #37
Old August 23rd 19, 05:30 PM posted to rec.aviation.soaring
son_of_flubber
Self-launch gliders are obviously appealing, but I'm curious about their limitations wrt density altitude and turbulence.
What is your climb rate in your typical density altitude?
Do you ever launch in turbulent conditions with lots of sink?
What density altitude leads you to cancel your flight?
What is the highest density altitude that you have launched in?
  #38
Old August 23rd 19, 05:41 PM posted to rec.aviation.soaring
Dan Marotta
It's not the same with other self-launchers, of course, but my S10-VT
has a turbocharged, 4-cylinder engine rated at 115 (nominal)
horsepower.Â* With the turbo, it achieves its rated power to a very high
altitude, which I haven't seen stated, but it has a published service
ceiling of 33,000' MSL.Â* Density altitude has no effect on it other than
some reduction in propeller efficiency and engine temperature limits.Â* I
imagine the higher true airspeed for a given IAS at takeoff at high
altitude airports makes up for reductions in wing lift.Â* At maximum
power it burns around 5 gallons/hour (about 3.2 gph in cruise at 18,000'
MSL for repositioning flights), so I'd guess I burn less than a half
gallon of gas per normal soaring flight, including taxi and takeoff.
Engine overhaul will cost a few pennies more than with the smaller ships...
Dan, 5J
  #39
Old August 24th 19, 02:47 AM posted to rec.aviation.soaring
son_of_flubber
Also...
How long is your runway? Is it level? Is it paved?
  #40
Old August 26th 19, 04:29 AM posted to rec.aviation.soaring
2G
At 2000 ft DA it is 500 ft/min; at 9000+ DA it is 300 ft/min. Always seeking lift, so this is mixed.
Not with lots of sink - try to launch when there is lift.
None.
9600 ft.
Perlan High Altitude Tow Plane Frank Whiteley Soaring 32 August 25th 18 01:32 PM
Martin B-57 Canberra pics [19/20] - NASA High Altitude Plane.jpg (1/1) Miloch Aviation Photos 0 August 26th 16 12:34 AM
High Altitude simulator accuracy in X-Plane Ghazan Haider Simulators 2 August 16th 05 06:01 PM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
