LS8-18T hydraulic operation
Old October 1st 19, 07:49 PM posted to rec.aviation.soaring
Ross[_3_]
Default LS8-18T hydraulic operation
Depends which version you have.
I had one of the first prototypes in mine.
Was a hydraulic pump, no electrics needed, and also no accumulator
The second version has one.
Old October 2nd 19, 10:02 AM posted to rec.aviation.soaring
Colwyn Darlow
Thanks. I'm looking at viewing a 2002 one a fair distance away. Some
language issues with the seller and can't find a manual or info online
about the
engine operation with pre DG models.
So early ones had a hydraulic hand pump.
Old October 3rd 19, 03:31 PM posted to rec.aviation.soaring
Ross[_3_]
Yes, that is correct.
Mine was 2002/2003 and had no accumulator. Depending where in the world you are you will have some difficulties getting it certified.
If you are US based then it will probably be experimental.
Hydraulic Jumps? Dave Nadler Soaring 15 August 29th 17 04:10 PM
Help identifying a hydraulic fitting larry Rotorcraft 0 May 10th 06 08:55 PM
Help identifying a hydraulic fitting larry Restoration 0 May 10th 06 08:55 PM
Hydraulic Pump [email protected] Aviation Marketplace 2 March 28th 06 05:16 PM
Hydraulic Pump [email protected] General Aviation 2 March 28th 06 06:09 AM
