On Wed, 16 Mar 2005 13:59:24 +0000 (UTC), David Lesher
wrote: The ATC screwup I recall was when they vectored the jump plane over Lake Erie and all the skydivers drowned. I've never looked for that NTSB report {It happened in the 60's} but maybe I will. I remember there being a cloud cover such that the pilot, who was above it, did not know where he was and ended up out over lake Erie. Don't remember anything about ATC being involved though. Corky Scott |
"Corky Scott" wrote in message ... I remember there being a cloud cover such that the pilot, who was above it, did not know where he was and ended up out over lake Erie. Don't remember anything about ATC being involved though. From dropzone.com: On August 27th 1967, Bob Karns, who was a pilot working for Ortner Aviation at Wakeman Ohio, was giving a free jump from 20,000 ft + in a B-25 WW II bomber, to some jumpers who had jumped from that aircraft at an air show, for which Karns had been paid. There was so many jumpers showed up at Ortner Field, the plane was overloaded to the extent that the nose wheel came up off the ground. As a result, three or four jumpers were taken from the aircraft, and the rest were to make the jump. The plane took off and began its long climb, disappearing into 100% cloud cover . Cloud base was about 4000 ft and the tops about 6000 feet. A local jumper who should have known better, took off a bit later in a Cessna 180, and was planning to take 35mm still photos of the jumpers as they fell towards Ortner field. Common sense should have made him realize that the jumpers would be passing his Cessna 180 like bullets, and he would not get any usable photos, and if they were far enough away from the Cessna, they would be nothing but tiny specks in his viewfinder. The plane reached altitude, and the pilot (Bob Karns) received confirmation that the aircraft was directly over Ortner field. The radar screen was showing a blip at that spot ( actually it was the Cessna 180) and Karns turned and waved the jumpers out the bomb bay doors. Jimmy Simmons was first to go, and the others followed like they were tied on a long string. There was a total of 18 jumpers, and Bob Coy (one of the survivors) told me later they had a real blast getting together and just flying....until they approached the dark clouds at 6K. As the jumpers came through the clouds, they were faced with a rainstorm and the fact that they were 5 miles out over Lake Erie. They opened the chutes immediately, hoping to make it closer to shore. I believe everyone had Para-Commanders, and although its a great canopy, it doesnt fly like a square...not even close. Few made any headway, and prepared to ditch in the lake, which was 72 degrees F. Norm Allard had two jumpsuits on because of the cold at altitude, but he managed to get them off, except for the altimeter pinning them both to his wrist. Thats how they found him. Bill Onyska had the only piece of flotation gear, which he inflated, but the CO2 went out a small hole that had gone unnoticed in the device...and it was useless. BoB Coy, tried using his packed reserve as floatation, but it soon became waterlogged, and he discarded it, and then he tried to lay on his helmet which had styrofoam inside. That probably saved his life. A search was quickly started, and over the next 5 days, they collected all the bodies from the lake. A boat had been brought alongside a jumper named Johnson, and the boat then drove off leaving him in the lake. It is possible the guy was a smuggler or out for a cruise with someone elses wife and didnt want to get involved. A second boat rescued Johnson. Para Commanders were floating on the lake...with no one in the harness, or near them. Several were cut to pieces by boat propellers and founds later. My best friend, Joe Malarik was the last to be found. Oddly enough, Joe had been in a bar the night before with his girldfriend Barb and another guy, and he said that when he died, he would prefer to drown. He did so the very next day. When Joe was a young boy, he drowned in a swimming pool, but was revived. He thought it would be the best way to go. The B-25 aircraft, made another circuit, and again was told by Oberlin Tower that it was directly over Ortner Field, and Larry Hartman and Al Olmstead jumped, wearinmg oxygen masks and bottles. The Cessna hand landed by this time, and the B-25 was in fact, over the target area. Hartman noticed through a small hole in the clouds, one of the airport runways, and he pointed to it for Olmstead. They tracked over, and landed on the airport. By this time, the accident was known, and everyone got involved in the search. Dale Gates of the Parkman DZ, flew his Cessna a few feet above the choppy waves of the lake, trying to spot survivors, but none were seen. In all 16 jumpers died that day. |
Corky Scott writes:
On Wed, 16 Mar 2005 13:59:24 +0000 (UTC), David Lesher wrote: The ATC screwup I recall was when they vectored the jump plane over Lake Erie and all the skydivers drowned. I've never looked for that NTSB report {It happened in the 60's} but maybe I will. I remember there being a cloud cover such that the pilot, who was above it, did not know where he was and ended up out over lake Erie. Don't remember anything about ATC being involved though. I do not recall any details beyond the USG settling with the widows, etc. Hence my interest in looking it up... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
That is a poor example of the kindof bs that is "killing" GA. It
seems pretty clear to me that an ATC screw-up caused this one. ATC incompetence would have to be way down at the bottom of the list of things killing GA... if it would even be on the list. |
A.Coleman wrote:
Please read this. This is what's killing GA and we ought to do something about it. http://www.cdapress.com/articles/200...ews/news04.prt I've read the accident reports on this one. The controller screwed up big on this. Yes you can take the philosophy that the controller is always trying to kill you and question every instruction he gives you, but there's no indication that doing that is inherently safer in the long run either. |
Yes, the controller errored in not following procedure on the altitude
snitch alarm (it's there for more than just dinging us pilots for busting an altitude), but interestingly we have no information about why the other airplane did not question who else answered to his tail number... And how did the other airplane get down if he didn't take the controllers instructions?... In controlled airspace I try to be alert to similar tail numbers... And, don't be too worried about Uncle Sam getting sued, he's got your money to pay it with... denny |
"Denny" wrote in message oups.com... Yes, the controller errored in not following procedure on the altitude snitch alarm (it's there for more than just dinging us pilots for busting an altitude), but interestingly we have no information about why the other airplane did not question who else answered to his tail number... And how did the other airplane get down if he didn't take the controllers instructions?... In controlled airspace I try to be alert to similar tail numbers... That was not the only ATC error. When similar callsigns are on the frequency the controller is supposed to use full callsigns and alert each pilot of the situation. |
Steven P. McNicoll wrote:
That was not the only ATC error. When similar callsigns are on the frequency the controller is supposed to use full callsigns and alert each pilot of the situation. I've had fun with that. My club owns Archer 17AV. There is also a Archer 117AV in the area. One day I'm just about to call up NY Approach returning to HPN when 117AV beats me to it and checks in, same destination. It took me a while to get the controller to understand that he hadn't just heard the callsign wrong, and there really were two of us. |
Denny wrote: Yes, the controller errored in not following procedure on the altitude snitch alarm (it's there for more than just dinging us pilots for busting an altitude), but interestingly we have no information about why the other airplane did not question who else answered to his tail number... snip Simple, the abbreviated callsign used by the controller was the correct one for both airplanes (four papa alpha). How would either airplane know which one the controller was talking to. In the accident pilot's defense, he did read back with his full callsign and the controller missed that as well. I'd say the controller had some responsibilty in this one. As for the Jacksonville crash, I've read the NTSB report on that one and I agree with the OP. It was a money grab. The pilot lost it on missed approach at 1,000 ft. supposedly it was caused by the tower controllers giving the pilot an altimeter setting that was .03" Hg off. John Galban=====N4BQ (PA28-180) |
Hey, you can sue anyone for anything, doesn't mean you'll win. Take for
instance the Washington state family suing Caterpillar because an Israeli bulldozer driver ran over their daughter who was standing in front of a Palestinian house that was to be demolished. The bulldozer worked as designed, the death occured because their protesting daughter was too stubborn to move and the driver was too stubborn to stop. Squish. Yep, sounds like Caterpillar's fault, doesn't it? If they had only put a disclaimer on the front of the bulldozer that said, "Caution, standing in front of this bulldozer as it bears down on you can result in severe injury or death.", they would be off the hook. Now you know where all those silly product warnings come from... |
Similar Threads | ||||
What kind of pod is it? | [email protected] | Naval Aviation | 12 | February 23rd 05 08:53 AM |
This is why we train (kind of long) | SD | Piloting | 38 | January 20th 04 04:06 PM |
A different kind of extreme runway | David Megginson | Piloting | 26 | November 4th 03 09:15 PM |
What kind of plane is this? | Roy Smith | General Aviation | 10 | October 29th 03 06:23 PM |
New kind of helicopter? | John Ross | Piloting | 10 | August 15th 03 03:26 AM |
