Too many GPS puck antennas
Old January 11th 20, 02:22 AM posted to rec.aviation.soaring
Charles Longley
Default Too many GPS puck antennas
I just started pimping out my ASW20. I am putting in a LXNAV S100, FLARM and an ADS-B Trig transponder. Thant’s three puck antennas and I haven’t even figured out where to put the FLARM antennas yet! Does anyone have a good solution?
Old January 11th 20, 03:22 AM posted to rec.aviation.soaring
JS[_5_]
I've been using a MECA divider for several years now.
Besides the panel being less crowded, GPS satellites aquire much faster.
Don't use DC blockers. Use a 12v GPS antenna to feed the divider. This way if your primary device fails, you don't lose all of them.
Search for GPS divider in the subject, links were posted on a previous thread.
Old January 11th 20, 03:24 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Charles,
Cables and combiners on the bottom of this page.
http://www.craggyaero.com/antennas.htm
Richard
www.craggyaero.com
Old January 11th 20, 03:59 PM posted to rec.aviation.soaring
Charles Longley
I like your idea best Richard. I’ll give you a call next week.
Old January 11th 20, 02:07 PM posted to rec.aviation.soaring
Too many puck GPS antennas too close together will lead to interference and poor function.
I remember reading somewhere that these puck antennas must be 30 inches apart to help reduce the possibility of such interference.
Old January 11th 20, 05:49 PM posted to rec.aviation.soaring
[email protected][_2_]
What brand/model 12v GPS antenna is being used, reasons?
R
Old January 11th 20, 08:31 PM posted to rec.aviation.soaring
JS[_5_]
R
Linx Antenna Factor
ANT-GPS-SH-SMA (with SMA connector)
ANT-GPS-SH-MCX (with MCX connector)
ANT-GPS-SH-MMX (with MMCX connector)
Each GPS engine provides phantom power, and the voltage from each is added. If you use a standard puck the voltage from 2 or 3 engines will be too high.
The Linx has higher gain with higher phantom voltage (up to 12v).
System Gain: 28dB (typ. includes 4dB
cable & filter loss)
Noise Figu 1.8dB @ fo, 2dB max.
Input Voltage: +2.5VDC to +12VDC
Old January 11th 20, 11:29 PM posted to rec.aviation.soaring
R
Linx Antenna Factor
Dear customer,
Linx Technologies is announcing the end-of-life of the ANT-GPS-SH-SMA, ANT-GPS-SH-MCX and ANT-GPS-SH-MMX Series of antennas, and the launch of the SH2 Series GPS antennas.Key components critical to the design of the SH Series antennas have been discontinued by the IC manufacturer.
SH2 Series are DC 5V
Richard
Antennas! Get yer antennas here! Bob (not my real pseudonym) Aviation Photos 0 March 3rd 11 04:38 AM
Antennas [email protected] Home Built 1 February 19th 09 07:32 PM
Aircraft antennas ccwillwerth Home Built 23 October 26th 06 10:30 PM
Antennas Terry Home Built 3 April 24th 05 06:42 PM
Antennas Terry Home Built 3 April 22nd 05 03:14 AM
