Electronic TE compensation, will this work?
Old February 13th 20, 02:27 AM posted to rec.aviation.soaring
Darryl Ramm
Default Electronic TE compensation, will this work?
On Wednesday, February 12, 2020 at 5:23:35 PM UTC-8, Dave Nadler wrote:
On Wednesday, February 12, 2020 at 4:07:53 PM UTC-5, soaringjac wrote:
https://photos.app.goo.gl/wu5LUibL2KpF9eWZ6
I have no idea what im looking at...
Clearly a Dr. Who rerun.
Attack of the o-ring men?
The Three o-rings?
It's likely an o-ring. But so what. Looking in the hole may not tell you much, well not from a single photo.
Again, take this to an experienced glider A&P and get help. Especially because you are working on a type certificated aircraft and I am guessing you are not qualified to. A competent glider A&P will be able to determine exactly what is going on, what's leaking or cross leaking and then spend time trying to find out where. They should be very experienced at trying to work out if it's a faulty o-ring or probe or mount connection, or whatever and have the right tools to pick out and replace o-rings. maybe correct o-rings on hand, able to cut out and replace the probe mount if that is needed, etc. etc. etc.
You fix problems by fixing them, ideas of leaving TE lines faulty and trying to use them as static are a waste of your time. "running out of time" is the entirely wrong attitude here.
Old February 13th 20, 08:01 AM posted to rec.aviation.soaring
Eric Munk
I think the photo shows the back of the TE attachment fittings. I
would say the tubing has come off. Easy fix. Get drawings, drill a
hole in the side of the fin, reattach and repair the hole according
to repair manual. Would require a licensed A&P to sign off.
=20
The Three o-rings?
you
mu=
Especially
beca=
guessing you
a=
determine
exact=
spend time
tr=
trying to work
o=
whatever and
ha=
o-rings
o=
needed,
etc.=
etc. etc.
and
tryin=
time" is
the entirely wrong attitude here.=20
Old February 13th 20, 10:40 AM posted to rec.aviation.soaring
Thanks Kevin! Do you still have the bad/leaking TE line plugged into the S100 or do you just have it open to the cockpit?
No don't use anything on the TE port if it is bad
Kevin 92
Old February 13th 20, 10:59 AM posted to rec.aviation.soaring
krasw
Just pull the adapter (with tube attached) out of the fin leading edge and install new one:
https://www.esa-systems.com/en/produ...ter-st1r-6-mm/
Should be possible with little effort, the adapter is just glued to place.
Old February 13th 20, 03:09 PM posted to rec.aviation.soaring
soaringjac
Should be possible with little effort, the adapter is just glued to place..
Thanks Krasw
Just got the drawings from Grob (linder). It does look like there is a barbed fitting at the end of the TE socket, and it seem like that is what has broken off based on the photo i took. Seems like having that whole tube replaced by an A&P isn't going to too bad of a process, but who knows, could turn out to be a pain. Really don't want them to have to cut any holes in the skin or have to do any major composite work. Will chat with the A&P and composite shop about this.
Old February 13th 20, 03:11 PM posted to rec.aviation.soaring
soaringjac
=20
The Three o-rings?
you
mu=
Especially
beca=
guessing you
a=
determine
exact=
spend time
tr=
trying to work
o=
whatever and
ha=
o-rings
o=
needed,
etc.=
etc. etc.
and
tryin=
time" is
Thank Eric, this does seem like what has happened, although it seems the tubing is still attached to the barbed fitting but the barbed fitting itself broke loose from its connection to the metal TE tube based on drawings from Grob.
Old February 13th 20, 06:13 PM posted to rec.aviation.soaring
Eric Munk
At 15:09 13 February 2020, soaringjac A four inch dia hole should
suffice for access. Is not a big deal. Done that before.
leading edge
an=
d install new one:
=20
https://www.esa-systems.com/en/produ...ails/mounting-
adapter-st1r-6-m=
m/
=20
to
place=
Thanks Krasw
is a
barb=
what has
b=
whole tube
repl=
knows, could
tu=
holes in
the=
A&P and
co=
Old February 13th 20, 06:44 PM posted to rec.aviation.soaring
Bob Kuykendall
On Thursday, February 13, 2020 at 7:09:25 AM UTC-8, soaringjac wrote:
...Really don't want them to have to cut any holes in the skin or have to do any major composite work. Will chat with the A&P and composite shop about this.
Just as an aside, composite repair isn't really all that hard or complicated. My favorite book on the topic is the Ursula Hanle "five P" guide, the "Petite Plastic Plane Patch Primer." You can find it for free on the web.
  #29
Old February 13th 20, 06:51 PM posted to rec.aviation.soaring
Bob Kuykendall
https://www.dg-flugzeugbau.de/en/wp-...ickfibel-e.pdf
  #30
Old February 13th 20, 10:35 PM posted to rec.aviation.soaring
I have a triple probe mount that was removed from a G-103, picture available..........but I don’t know how to post it?
JJ
Lx9070 V80 and Butterfly electronic and pnuemantic compensation Jonathan St. Cloud Soaring 2 May 5th 16 06:47 PM
Electronic versus Pneumatic compensation (conclusions) [email protected] Soaring 0 September 26th 05 05:02 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 4 September 20th 05 06:21 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 2 September 20th 05 06:04 AM
Electronic versus Pneumatic compensation in LX7000 [email protected] Soaring 8 September 15th 05 02:49 AM
