Needing a Conditional Inspection (west coast)
Old March 28th 20, 01:24 PM posted to rec.aviation.soaring
Default Needing a Conditional Inspection (west coast)
A coin tap test is simply that.
Tap the composite material with a coin. If the noise you here is sharp and solid, so is the material.
If the sound is dull and hollow, the material is compromised in some way.
Old March 28th 20, 03:35 PM posted to rec.aviation.soaring
Dan Marotta
And yes, an Experimental aircraft needs an Annual Condition Inspection
which can be accomplished by any A&P mechanic, though you might like to
have one who is familiar with gliders and/or composite construction.Â* If
you built it yourself, and secured a Repairman Certificate from the FAA,
you can perform your own inspections and repairs on that aircraft only.
An Annual Inspection for a Standard Airworthiness aircraft must be
inspected by an A&P mechanic with Inspection Authorization.
JJDK737 is right on about the coin test.
Dan, 5J
Old March 28th 20, 08:02 PM posted to rec.aviation.soaring
svelusive
Might give John Bentley a call in Bend, Oregon.
Still a 3 1/2 hour drive though.
Available to trailer your glider west coast to east coast Aug. 1-10 [email protected] Soaring 0 July 28th 17 10:43 PM
West Coast Motorglider Fly-in Aug 21-23 jb92563 Soaring 0 July 27th 09 08:50 PM
USS Liberty survivor Phil Tourney to be on Radio Liberty programtoday at 4 PM on the west coast and at 7 PM on the east coast NOMOREWARFORISRAEL[_2_] Naval Aviation 0 September 26th 08 11:24 PM
West coast soaring - where and when? Uros Soaring 14 February 24th 08 01:37 AM
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): [email protected] Naval Aviation 0 January 27th 07 02:18 PM
