Can someone tell me what the difference is between a "CK" and a "C"
designation on a Sensenich prop? I am looking at a used prop for my Aeronca Champ which currently has a W72CK-44 cruise prop. The used propeller that's for sale is a W72C-42. I have a C-65-8 taper shaft-- will the C work on my engine? Thanks, - Brett |
Aeronca Champ which currently has a W72CK-44 cruise prop. The used propeller that's for sale is a W72C-42. I have a C-65-8 taper shaft-- will the C work on my engine? try calling Sensenich Wood Propeller Co. 2008 Wood Court - Plant City, FL 33563 Phone: (813) 752-3711 jon |
oups.com... Can someone tell me what the difference is between a "CK" and a "C" designation on a Sensenich prop? I am looking at a used prop for my Aeronca Champ which currently has a W72CK-44 cruise prop. The used propeller that's for sale is a W72C-42. I have a C-65-8 taper shaft-- will the C work on my engine? Thanks, - Brett Check the type certificate data sheet for your model Champ at http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet For all models: 1. Wood Propellers - fixed pitch Models 7AC, 7BCM, 7CCM, 7DC Models 7EC,7FC, 7JC 10 lb. (-52) (-54) (a) Sensenich 72C-44 (Models 7AC and S7AC) Sensenich 72CK (Model 7BCM) Sensenich 72CK-44, -45, -46 (Models 7DC, S7DC) Sensenich 72GK-48, -49, -50 (Models 7CCM, 7EC, S7CCM, 7FC, 7JC) (b) Flottorp 72A50, 52 (Models 7CCM, S7CCM, 7EC, 7FC, 7JC) (c) Any other approved fixed pitch wood propeller which is eligible for the engine power and speed and which meets the diameter and static r.p.m. limits specified under "Propeller Limits" for the pertinent model. For an A-65-8: Propeller Limits Static rpm at maximum permissible throttle setting: (For fixed pitch Not over 2250, not under 1960. No additional tolerance permitted. wood propeller) Diameter: not over 72 in., not under 70 in. Hope this helps. It's best to ask these questions at www.aeronca.com or www.aeroncapilots.com. Deb -- 1946 Luscombe 8A (His) 1948 Luscombe 8E (Hers) 1954 Cessna 195B, restoring (Ours) Jasper, Ga. (JZP) |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Constant speed prop oil leak | DP | Piloting | 23 | April 21st 04 11:15 PM |
| Auto conversions & gear boxes | Dave Covert | Home Built | 56 | April 1st 04 07:19 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 08:45 PM |
